cjan
Re: Tutorial: Compile VLC with HW acceleration - Stretch, RPi 2/3
Sun Nov 18, 2018 10:15 am
gkreidl wrote:
Sun Nov 18, 2018 10:05 am
cjan wrote:
Sun Nov 18, 2018 10:02 am
gkreidl wrote:
Sun Nov 18, 2018 9:36 am
start_file=start_x.elf
fixup_file=fixup_x.dat
in /boot/config.txt
no go.
Did you reboot?
Check the file with mediainfo to get the codec being used.
sorry, its VP9.
maybe is ffmpeg too old or someyhing did not enabled?
in Alarm ffmpeg-mmal & mpv-rpi can play without start_file=start_x.elf fixup_file=fixup_x.dat.
gkreidl
Sun Nov 18, 2018 10:25 am
no go.
Did you reboot?
sorry, its VP9.
Software codec, I suppose.
Minimal Kiosk Browser (kweb)
cjan
Sun Nov 18, 2018 10:40 am
Did you reboot?
sorry, its VP9.
kodi-17 can not play while kodi-18 can.
so, thinking is ffmpeg issue.
dom
Sun Nov 18, 2018 6:38 pm
gkreidl wrote:
Fri Nov 16, 2018 5:08 pm
I have tested a lot today and it really works well for video. But there is a problem with audio files: they need a lot of time to start (tested mp3 and flac)
Is this a general problem with vlc on pi, or is this an issue purely in the new accelerated version included in raspbian?
MartinLaclaustra
Sun Nov 18, 2018 8:01 pm
dom wrote:
Fri Nov 16, 2018 1:40 pm
Raspbian now includes an even more accelerated VLC.
This uses mmal for video decode and the new hvs component for resize, yuv->rgb conversion and composition of subtitles.
Let us know if there are any improvements or regressions compared to the VLC version that has been used here.
@dom thank you for paying attention to VLC. Would it be possible to include in the repository version also the "OpenMAX IL video output" module that @gkreidl has been kindly working on for years now? That option has proved to work well for years and it should be kept available.
Full screen performance of the "OpenMAX IL video output" available in this thread is better, and it also allows software decoding of MPEG2 using the VLC software routines and relying on hardware acceleration for rendering. The repository version completely hampers that software decoding.
@gkreidl Thank you for all your work in this area. Please do not abandon your version until the "official" version in the repositories provides full funtionallity.
Martin
ShiftPlusOne
Sun Nov 18, 2018 8:51 pm
If there is something you would like in the repo version of VLC, send me a patch or tell me the appropriate configure options to pass and we can look into it.
Edit: Also it would be good to a have a description of what advantages it offers over what's already enabled.
gkreidl
Mon Nov 19, 2018 1:49 am
I have started a new topic to discuss the HW accelerated VLC 3.0 version from the repository. This should should not be continued in this thread, please: viewtopic.php?f=66&t=227185
@dom and MartinLaclaustra : I've answered to your posts in the new thread.
MikeOffenbach
Contact: Skype
Mon Dec 24, 2018 4:18 am
Thank you very much for your tutorial.
A pleasure to conclude that everything was working as in your description.
'make' took 45 minutes, 'make install' another 15.
I am using a pi 2 with 4.14.79-v7+, Stretch lite, kde-desktop.
It is configured to use the openGL driver by setting dtoverlay=vc4-fkms-v3d in /boot/config.txt.
In case of using that driver one needs to verify that the entry
  • gpu-mem=xxx is commented out in /boot/config.txt.
  • all entries in /etc/dphys-swapfile except CONF_SWAPFILE=/var/swap are commented out
In my case VLC works with video is set to 'auto', it even runs in a window.
You might add a hint to set auto update on hold (to prevent disappointments next morning :D)
see https://askubuntu.com/questions/18654/h ... ic-package
By using a wlan connection via my cellphone (~500 kB/s) I can play video-streams from anywhere. When using a browser these streams are frequently choppy, with VLC all is smooth!
cheers
Return to “Raspbian”
