WillBoxOwO
Fullscreen PS1 emulator?
Sat Oct 06, 2018 5:36 pm
Hello there. I followed this tutorial to install a PS1 emulator on my full Raspbian Desktop:
http://blog.sheasilverman.com/2012/09/b ... pberry-pi/
The only thing is: the window is really small. Combinations of F11+Whatever or simply F11 didnt make the window fullscreen...
How could I achieve a fullscreen window? It is not resisable and it doesnt use OpenGL (I heard it was hard to fullscreen an OpenGL thingy :lol: ).
Cheers.
I like cats
scruss
Re: Fullscreen PS1 emulator?
Sun Oct 14, 2018 9:22 pm
You're following really old instructions. Anything about Raspberry Pi more than a couple of years old will be misleading.
Anyway, PCXSR is in the repos, and can be installed using:
sudo apt install pcsxr
In the Configuration / Screen option, you can set full-screen.
Pronouns: he/him
WillBoxOwO
Sun Oct 14, 2018 11:44 pm
Cool! Only thing is, it runs really bad. Im getting 0.5fps just when im trying to boot spyro the dragon ***IN WINDOWED MODE :(***. Tried with Crash 1 & 3 and I get similar results. Any tips? The tutorial I followed is giving me a nice 60fps!
I like cats
scruss
Mon Oct 15, 2018 12:10 am
One of the pcsx_rearmed source links here: https://retropie.org.uk/docs/Playstation-1/ ?
(please don't bump posts. We're not holding anything from you - if no-one here has answered within a couple of days, no-one here knows what you're asking. The Raspberry Pi is a learning computer: you've got to do some research yourself)
Pronouns: he/him
WillBoxOwO
Mon Oct 15, 2018 9:37 pm
How am I supposed to run this on full Raspbian? I know it had something to do with the "build from source" thing (probably) but again im gessing. Any tips? :) And thanks for the quick reply.
I like cats
WillBoxOwO
Tue Oct 16, 2018 12:55 am
I found how to fullscreen Minecraft Pi:
https://www.minecraftforum.net/forums/m ... -screen#c7
Is there a way to make it work for pcsx_rearmed?
I like cats
WillBoxOwO
Wed Oct 17, 2018 10:43 pm
...but again im gessing.
I like cats
scruss
Thu Oct 18, 2018 1:06 pm
no, that's a source modification in the Minecraft code, so it won't work for the PS1 emulator.
Pronouns: he/him
WillBoxOwO
Sun Nov 04, 2018 7:58 pm
Hello there.
I managed to generate a preview of the window here:
Isnt that the proof that we can make it fullscreen? Is there a way to make the preview fullscreen..?
EDIT: If you type ALT+F11, the window gets undecorated and changes positions to top left up. It made Minecraft Pi fullscreen tho! :)
I like cats
scruss
Mon Nov 05, 2018 5:56 pm
That's proof that SimpleScreenRecorder knows how to capture window content. Not much else, sorry.
Pronouns: he/him
rpiMike
Tue Nov 06, 2018 4:09 pm
PCSX-ReARMed allows full screen using F11
https://github.com/notaz/pcsx_rearmed
I used the following to build on my Pi3B+:
cd ~
git clone https://github.com/notaz/pcsx_rearmed
sudo apt-get install libpng-dev libsdl1.2-dev
cd ~/pcsx_rearmed/
git submodule init && git submodule update
CFLAGS=-march=armv7-a ./configure --sound-drivers=sdl
make
./pcsx
scruss
Fri Nov 09, 2018 3:55 am
TIL that the commercial PlayStation Classic uses PCSX-ReARMed.
Pronouns: he/him
WillBoxOwO
Sat Nov 10, 2018 12:26 am
cd ~
cd ~/pcsx_rearmed/
make
./pcsx
Oh my god. Been searching all over the internet for an answer and here it is. Works fantastic on my Pi3B. Thank you. Imma do an update video on this! :)
I like cats
WillBoxOwO
Sat Nov 10, 2018 6:38 pm
Here it is: https://www.youtube.com/watch?v=N9HO_ciyVrA
Hope this helps. :)
I like cats
rpiMike
Sat Nov 10, 2018 6:56 pm
Nice video, thanks for the acknowledgement 😃
Might be a nice touch to see a game playing at the end.
WillBoxOwO
Sun Nov 11, 2018 2:51 am
Your right, but since it nows uses OpenGL to run fullscreen, I couldnt get SimpleScreenRecorder to record the screen :P
Im now trying to make a shortcut to open Spyro the dragon from my start menu.
I tried:
./pcsx --load "/home/pi/EMU/Spyro the Dragon.bin"
With no luck. Any tips? The error message in the logs told me it was missing some kind of -cdfile parameter. It also said I could load PSX EXEs? :lol:
I like cats
WillBoxOwO
Wed Nov 21, 2018 1:48 am
Im still trying all sorts of combinations without luck. I even tought about writing a program in python to brute force try to run the game from the terminal :lol:
Is there a way to do this?
I like cats
rpiMike
Wed Nov 21, 2018 10:39 am
PCSX ReARMed help shows the following:
[email protected]:~/pcsx_rearmed $ ./pcsx -h
PCSX-ReARMed r22-24-gbebe989
 pcsx [options] [file]
	options:
	-cdfile FILE	Runs a CD image file
	-cfg FILE	Loads desired configuration file (default: ~/.pcsx/pcsx.cfg)
	-psxout		Enable PSX output
	-load STATENUM	Loads savestate STATENUM (1-5)
	-h -help	Display this message
	file		Loads a PSX EXE file
I tried ./pcsx -cdfile '/home/pi/Gran Turismo 2 (Simulation Mode) (v1.2).bin' initially but noticed the following messages:
menu_load_config: failed to open: ./.pcsx/pcsx.cfg
note: running with HLE BIOS, expect compatibility problems
and the game would only partially run.
I then ran ./pcsx selected 'Options','Save global config','Exit'
Then ./pcsx -cdfile '/home/pi/Gran Turismo 2 (Simulation Mode) (v1.2).bin' worked and I did not see the previous messages.
WillBoxOwO
Sun Nov 25, 2018 5:56 am
Thank you Mike! My game menu is full of games now :P
I just got my PS3 controller from a friend of mine. Managed to connect it after many attemps via bluetooth! The emulator works great. No input latency whatsoever.
I also managed to install Quake 3 alongside, but it seems to require some key mapping to work with the controller. Is there a piece of software out there that can translates my button inputs from the ps3 controller to keyboard keystrokes?
Ex:
< = a
> = d
etc.. :mrgreen:
Edit: I found this http://qjoypad.sourceforge.net/#download
Im going to try and compile it myself, ill post updates
I like cats
WillBoxOwO
Sun Nov 25, 2018 4:48 pm
I came up with the following:
tar xzvf qjoypad-4.1.0.tar.gz
cd qjoypad-4.1.0/src
./config --plain_keys
But it gave me this error:
Error: you will need libxtst to compile this program
I then tried to install the required package using apt-get but it told me that it was "unable to locate package libxtst"
Edit: used sudo apt-get install libxtst-dev to install the package
New error:
Error: you need at least Qt version 4.2 to use this program
i then got to trolltech s website but it seems to be broken- gave a quick google at trolltech s qt and accessed the "qt.io" website. Seems ill need to build from source their piece of software. Maybe im wrong, can we install it using apt-get?
Edit no2
Found this cool guide: https://doc.qt.io/archives/4.3/install-x11.html
Im going to build this thing later on in the day. :)
I like cats
tvjon
Sun Nov 25, 2018 5:03 pm
You can try synaptic like this or
sudo apt install libxtst6
HTH
jdonald
Thu Dec 27, 2018 5:08 pm
Much of notaz's stuff for openPandora is tied to Mesa GLES, but I see this one has support for the legacy brcm driver on these lines: https://github.com/notaz/pcsx_rearmed/b ... #L444-L453
Curious as to how you guys find the performance when those lines are commented out and the beta driver is enabled.
altharic
Thu Jan 03, 2019 7:58 pm
Instead of giving an error it works in windowed mode but won't go full screen.
rpiMike
Thu Jan 03, 2019 8:08 pm
I'm assuming you're talking about PCSX ReARMed - pressing f11 should toggle full screen.
KoolDud3
Fri Jan 11, 2019 7:14 am
cd ~
cd ~/pcsx_rearmed/
make
./pcsx
Whenever I paste this, it just says "Do you want to Continue? [Y/n]" I type y because its probably "yes" then it it says "abort" then i click n, and i get the same problem
I exist
Return to “Gaming”
