GFC420
More than one connection to gpio and speaker/mic problem
Thu Nov 08, 2018 7:55 am
Hello
I am now to pri so i have a question. Can you connect more than one wire to same gpio data pin or power pin and how to connect mic+speaker to 4.5mm jack?
Re: More than one connection to gpio and speaker/mic problem
Thu Nov 08, 2018 12:47 pm
Hello
The Raspberry Pi SBC 1B+ / 2B / 3B / 3B+ has a 3.5mm output jack TRRS4
https://www.raspberrypi-spy.co.uk/2014/ ... ideo-jack/
There is no input for microphone without additional hardware !
Retired disgracefully.....
GFC420
Thu Nov 08, 2018 2:52 pm
Thanks to what hardware wpuld i need to add and how to connect a mic to a for pole audio jack
mahjongg
Thu Nov 08, 2018 3:06 pm
The PI does NOT have any audio input hardware.
Common solutions, an USB or I2S microphone.
GFC420
Thu Nov 08, 2018 3:52 pm
Ok then but what about connecting one or more wiert to the same gpio pi like in case of 2 sensors needing same pin?
B.Goode
Thu Nov 08, 2018 4:00 pm
If the sensors use a 'bus' technology like 1-wire or I2C then that will be taken care of by the bus protocol itself.
If the sensors simply signal by an on/off state that won't work: the RPi will have no way of knowing which external device has changed the state of the signal: you will need to redesign your project so that different sensors use different gpio pins.
GFC420
Thu Nov 08, 2018 4:08 pm
Ok thanks and last question can electret mic be used in i2s bus and what circutry would i need?
LTolledo
Fri Nov 09, 2018 10:17 am
if you want mic input to RPi, better use a USB sound dongle with analog out and mic in ports. Those same ones that you can use on a windows pc (like the SoundBlaster X-Fi Go). Even those cheapo USB dongles work with the RPi
the program/app you want to use must be able to identify and access the mic port on the USB sound dongle.
me have of those dongles, use only for sound output, I have no use for the mic input (nor will ever try it).
Some people be like:
GFC420
Fri Nov 09, 2018 12:57 pm
I fond solutions and i have a mini 0.25w speakers so no problem thanks to everyone for help
