Cr4z33
Need explanation of the BUTTON 4 PINs connector Voice HAT v1
Sun Nov 04, 2018 1:22 pm
I want to use a LED strip instead of the LED button so I was wondering if I can reuse two of the four BUTTON PINs?
Does anybody know what does EXACTLY do each of those four PINs?
Also any ground pinout I can connect to on the Voice HAT (v1)?
B.Goode
Re: Need explanation of the BUTTON 4 PINs connector Voice HAT v1
Sun Nov 04, 2018 2:49 pm
Maybe there are other sources of this information, this is one found following the links in this sub-forum.
See https://aiyprojects.withgoogle.com/voice/
There is a section headed HARDWARE EXTENSIONS
You will find a diagram showing GPIO pins used by the Voice Bonnet (highlighted pins are used)
Cr4z33
Sun Nov 04, 2018 2:55 pm
Thank you I already looked at it and it explains EVERYTHING but the button PINs. :lol:
Anyway I found out by myself like 10 minutes ago!
mahjongg
Sun Nov 04, 2018 11:30 pm
I should have immediately deleted your double post, double posting is not allowed here, for etc. the express reason demonstrated here.
please don't do it again.
Cr4z33
Mon Nov 05, 2018 3:48 pm
Sorry for crossposting! :oops:
It won't happen again.
Return to “AIY Projects”
