210338jim
installing Mu
Mon Oct 15, 2018 4:14 pm
Trying to install Mu on rpi - advised to go to Preferences then Recommended Software but there is no Recommended Software under Preferences
B.Goode
Re: installing Mu
Mon Oct 15, 2018 4:17 pm
What Operating System is running on your RPi?
If it is the Raspberry Pi Foundation recommended and supported Raspbian Operating System, what named or dated version?
gkaiseril
Re: installing Mu
Mon Oct 15, 2018 6:57 pm
See Pi blog MU, A NEW PYTHON IDE FOR BEGINNERS for the announcement and the link to the guide Getting started with Mu. It looks like you only need to apply the current dist-update to Raspian. Then it will be listed in the Recommended Software menu item.
f u cn rd ths, u cn gt a gd jb n cmptr prgrmmng.
DirkS
Re: installing Mu
Mon Oct 15, 2018 7:33 pm
Both 'recommended software' and 'mu' are only available for Raspbian Stretch.
It needs more than just an update if you're running Jessie (or older)
fbe
Re: installing Mu
Mon Oct 15, 2018 7:52 pm
... and if you installed Raspbian Stretch from an image before 2018-06-27, you may need to install the rp-prefapps package to get the Recommended Software menu item under Preferences.
gkaiseril
Re: installing Mu
Mon Oct 15, 2018 8:21 pm
Installing Mu on Linux for the command line. To add it to the menu, you can use the menu editor.
mxwll1011
Re: installing Mu
Mon Oct 29, 2018 4:23 am
I did not get the "recommended software" drop-down menu after update/upgrade...
sudo apt-get update
sudo apt-get dist-upgrade
SO, I tried to install mu editor via the command line terminal...
pip3 install mu_editor
THIS is the result...
Downloading/unpacking mu-editor
Downloading mu_editor-1.0.1-py3-none-any.whl (1.9MB): 1.9MB downloaded
Downloading/unpacking pyserial==3.4 (from mu-editor)
Downloading pyserial-3.4-py2.py3-none-any.whl (193kB): 193kB downloaded
Downloading/unpacking qscintilla==2.10.7 (from mu-editor)
Could not find any downloads that satisfy the requirement qscintilla==2.10.7 (from mu-editor)
Cleaning up...
No distributions at all found for qscintilla==2.10.7 (from mu-editor)
Storing debug log for failure in /home/pi/.pip/pip.log
SO, the step-by-step instructions at https://codewith.mu/en/howto/install_raspberry_pi ... didn't work. Any thoughts?
hippy
Re: installing Mu
Wed Oct 31, 2018 5:02 pm
That guide says -
You can also install Mu from the command line using the command:
sudo apt-get install mu-editor
You didn't do that. You used pip3.
mxwll1011
Re: installing Mu
Thu Nov 01, 2018 2:48 am
"E: Unable to locate package mu-editor"
DirkS
Re: installing Mu
Thu Nov 01, 2018 8:46 am
You're very conservative with giving information.
You should tell us the exact command you used and the full error msg.
And I don't think you have told us which OS + version you're using...
Important to know in this case.
Return to “Beginners”
