FreezeTile
The composite video's gone all funny
Wed Oct 31, 2018 12:37 pm
Here's a Halloween horror for you - I'm trying to get composite video working on my Pi so I can use it on an old CRT TV, but when I plug it in, all I get is this.
Any ideas?
Re: The composite video's gone all funny
Wed Oct 31, 2018 1:07 pm
Wrong mode or your signal and ground are swapped.
The RPi defaults to NTSC 480i unless you tell it to do otherwise.
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
rpiMike
Wed Oct 31, 2018 1:20 pm
Set sdtv_mode=2 in /boot/config.txt for PAL
https://www.raspberrypi.org/documentati ... t/video.md
FreezeTile
Wed Oct 31, 2018 3:32 pm
DougieLawson wrote: Wrong mode or your signal and ground are swapped.
rpiMike wrote: Set sdtv_mode=2 in /boot/config.txt for PAL
The cable I bought was advertised as being compatible with the Pi, so that can't be the problem. I tried changing the config file:
Screenshot 2018-10-31 at 15.17.36.png (120.73 KiB) Viewed 307 times
but I'm still getting the same fuzzy picture. What now?
Wed Oct 31, 2018 3:36 pm
Check that cable with a continuity checker (or a multimeter on resistance).
https://www.raspberrypi-spy.co.uk/2014/ ... ideo-jack/
Burngate
Wed Oct 31, 2018 6:39 pm
Composite video has sync pulses that are blacker-than-black
That first picture is showing white sync pulses - the broad vertical white stripe is the line sync, the narrow horizontal white stripe is the vertical sync
So your cable isn't compatible, whatever the advert says.
drgeoff
Wed Oct 31, 2018 9:22 pm
+1. Absolutely, definitely, certainly, without a doubt the cable is not wired appropriately for the TRRS socket on a RPi.
FreezeTile
Wed Oct 31, 2018 9:25 pm
Bugger! >:-(
Oh well.
