I am new to python and also to raspberry pi, I have connected the High-Precision AD/DA Board to the RPI 3 model B, and I am looking to change the sampling time of the ADC and I am not sure if I need to change the RPI reading time as well, I have found some code such as
byte drate_reg = 3; // Choosing Data Rate register = third register.
byte drate_data = 0b11000000; // 11000000 = 3,750SPS
SPI.transfer(0x50 | drate_reg);
SPI.transfer(0x00); // 2nd command byte, write one register only
SPI.transfer(drate_data); // write the databyte to the register
delayMicroseconds(10);
However when I run the sudo ./ads1256_test to verify if it is properly reading, I am getting this random voltages that are not changing even though I have run with no error the line byte drate_data = 0b11000000; // 11000000 = 3,750SPS. The reading I am getting are:
