OS: Rasbpian Lite, latest release, fully updated. Firmware updated.
I have been using the same Pi for years now and the attached USB flash drives worked without problems.
The SSD disk is recognised and I can format it as EXT4 without problems. I can mount it (manually or in fstab) and it mounts as expected.
mount shows it mounted as rw
However, when I try to write anything to the disk, even only with touch, the filesystem is immediately changed to ro
The disk and adapter are both completely new and I can see no issues when plugged to a PC via the same adapter (SMART data look OK, reading and writing works without problems).
I tried adding max_usb_current=1 to /boot/config.txt, but the problem is the same. The adaptor powering the Pi is marked as 5V 2A.
Any help would be greatly appreciated.
The system log output is as follows:
when mounting the partition:
Sep 30 11:48:42 raspberrypi kernel: [ 4136.654904] JBD2: Clearing recovery information on journal
Sep 30 11:48:42 raspberrypi kernel: [ 4136.661396] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
Sep 30 11:48:42 raspberrypi kernel: [ 4136.661419] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x5 [current]
Sep 30 11:48:42 raspberrypi kernel: [ 4136.661434] sd 0:0:0:0: [sda] tag#0 ASC=0x24 ASCQ=0x0
Sep 30 11:48:42 raspberrypi kernel: [ 4136.661453] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 08 01 04 08 00 00 00 08 00
Sep 30 11:48:42 raspberrypi kernel: [ 4136.661465] print_req_error: critical target error, dev sda, sector 17041408
Sep 30 11:48:42 raspberrypi kernel: [ 4136.661478] Buffer I/O error on dev sda1, logical block 2129920, lost sync page write
Sep 30 11:48:42 raspberrypi kernel: [ 4136.661532] JBD2: Error -5 detected when updating journal superblock for sda1-8.
Sep 30 11:48:42 raspberrypi kernel: [ 4136.663599] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
Sep 30 11:48:42 raspberrypi kernel: [ 4136.663618] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x5 [current]
Sep 30 11:48:42 raspberrypi kernel: [ 4136.663632] sd 0:0:0:0: [sda] tag#0 ASC=0x24 ASCQ=0x0
Sep 30 11:48:42 raspberrypi kernel: [ 4136.663648] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 08 00 00 08 00 00 00 08 00
Sep 30 11:48:42 raspberrypi kernel: [ 4136.663659] print_req_error: critical target error, dev sda, sector 2048
Sep 30 11:48:42 raspberrypi kernel: [ 4136.663671] Buffer I/O error on dev sda1, logical block 0, lost sync page write
Sep 30 11:48:42 raspberrypi kernel: [ 4136.670183] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
when trying to write to the mounted partition (with “touch”):
Sep 30 11:48:49 raspberrypi kernel: [ 4143.591651] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
Sep 30 11:48:49 raspberrypi kernel: [ 4143.591704] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x5 [current]
Sep 30 11:48:49 raspberrypi kernel: [ 4143.591724] sd 0:0:0:0: [sda] tag#0 ASC=0x24 ASCQ=0x0
Sep 30 11:48:49 raspberrypi kernel: [ 4143.591749] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 08 01 04 08 18 00 00 08 00
Sep 30 11:48:49 raspberrypi kernel: [ 4143.591766] print_req_error: critical target error, dev sda, sector 17041432
Sep 30 11:48:49 raspberrypi kernel: [ 4143.591792] print_req_error: critical target error, dev sda, sector 17041432
Sep 30 11:48:49 raspberrypi kernel: [ 4143.592107] Aborting journal on device sda1-8.
Sep 30 11:48:49 raspberrypi kernel: [ 4143.593104] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
Sep 30 11:48:49 raspberrypi kernel: [ 4143.593128] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x5 [current]
Sep 30 11:48:49 raspberrypi kernel: [ 4143.593142] sd 0:0:0:0: [sda] tag#0 ASC=0x24 ASCQ=0x0
Sep 30 11:48:49 raspberrypi kernel: [ 4143.593159] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 08 01 04 08 00 00 00 08 00
Sep 30 11:48:49 raspberrypi kernel: [ 4143.593172] print_req_error: critical target error, dev sda, sector 17041408
Sep 30 11:48:49 raspberrypi kernel: [ 4143.593186] Buffer I/O error on dev sda1, logical block 2129920, lost sync page write
Sep 30 11:48:49 raspberrypi kernel: [ 4143.593256] JBD2: Error -5 detected when updating journal superblock for sda1-8.
Sep 30 11:48:50 raspberrypi kernel: [ 4144.316144] EXT4-fs (sda1): previous I/O error to superblock detected
Sep 30 11:48:50 raspberrypi kernel: [ 4144.317146] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
Sep 30 11:48:50 raspberrypi kernel: [ 4144.317166] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x5 [current]
Sep 30 11:48:50 raspberrypi kernel: [ 4144.317180] sd 0:0:0:0: [sda] tag#0 ASC=0x24 ASCQ=0x0
Sep 30 11:48:50 raspberrypi kernel: [ 4144.317198] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 08 00 00 08 00 00 00 08 00
Sep 30 11:48:50 raspberrypi kernel: [ 4144.317209] print_req_error: critical target error, dev sda, sector 2048
Sep 30 11:48:50 raspberrypi kernel: [ 4144.317223] Buffer I/O error on dev sda1, logical block 0, lost sync page write
Sep 30 11:48:50 raspberrypi kernel: [ 4144.317495] EXT4-fs error (device sda1): ext4_journal_check_start:61: Detected aborted journal
Sep 30 11:48:50 raspberrypi kernel: [ 4144.333462] EXT4-fs (sda1): Remounting filesystem read-only
Sep 30 11:48:50 raspberrypi kernel: [ 4144.342752] EXT4-fs (sda1): previous I/O error to superblock detected
Sep 30 11:48:50 raspberrypi kernel: [ 4144.343736] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
Sep 30 11:48:50 raspberrypi kernel: [ 4144.343757] sd 0:0:0:0: [sda] tag#0 Sense Key : 0x5 [current]
Sep 30 11:48:50 raspberrypi kernel: [ 4144.343771] sd 0:0:0:0: [sda] tag#0 ASC=0x24 ASCQ=0x0
Sep 30 11:48:50 raspberrypi kernel: [ 4144.343790] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x2a 2a 08 00 00 08 00 00 00 08 00
Sep 30 11:48:50 raspberrypi kernel: [ 4144.343801] print_req_error: critical target error, dev sda, sector 2048
Sep 30 11:48:50 raspberrypi kernel: [ 4144.343814] Buffer I/O error on dev sda1, logical block 0, lost sync page write
