taylorkh
Ubuntu Mate 18.04???
Wed Sep 05, 2018 8:51 pm
Please pardon me if this is the wrong place to ask this question. I have been looking around various forums and have not come across an answer...
Does anyone have any idea when Ubuntu Mate 18.04 will be available for the Pi? I have three Pi computers running Ubuntu Mate 16.04 (1 3B and 2 3B+). 16.04 works fine and is a long term support release but I would like to try 18.04 on at least one of them. apt-get on the 3B recently gave me a message about a new release being available but I did not try to upgrade as this machine is the firewall/router/DHCP/shared VPN for my LAN and I really don't want to try the upgrade in production.
I guess I could swap one of the 3B+ machines in place of the 3B and then see what happens on the 3B if I do the release upgrade but...
If someone has any good information on the status, I would be grateful.
TIA,
Ken
MaxVMH
Re: Ubuntu Mate 18.04???
Wed Sep 05, 2018 9:03 pm
If you just want to try it out, I made images (EDIT: of Ubuntu Mate 16.04) last April to test some stuff, I haven't used them since so YMMV, use at own risk, updating may break the OS, etc. ... I don't recommend using them for anything important.
(If you prefer to make an image yourself, click here for instructions.)
Webserver stack: 2x Pi 3B | 1x Pi 3B+ ||| Pi Zero W for fooling around
Working on a soccer prediction web app:
https://github.com/MaxVMH/mijnscore
Attempt at writing up-to-date tutorials on making a Raspberry Pi webserver:
http://blog.mijnscore.be/
taylorkh
Wed Sep 05, 2018 9:18 pm
Thanks MaxVMH,
I trust that as you have a USB image these images are suitable for the 3B+ ? I am pulling the torrent now for the SD card and will give it a try.
Thanks again,
Ken
MaxVMH
Wed Sep 05, 2018 9:43 pm
Thanks MaxVMH,
Thanks again,
Ken
I just realized it's Ubuntu Mate 16.04 for the 3B+, not 18.04. Sorry if I wasted your time :roll:
I suggest you head over to the Ubuntu Mate forums and ask for support for 18.04 on the 3B+, it's the only way they'll know that there's demand.
taylorkh
Wed Sep 05, 2018 11:25 pm
No problem MaxVMH. The torrent was still downloading - now canceled.
Thanks for the links DirkS. That is the same sort of dismal stuff I have been seeing.
Ken
taylorkh
Fri Sep 07, 2018 7:28 pm
I don't know if Ubuntu Mate 18.04 is available for the Pi or if the project is "dead" as some post think but...
It sure looks like I have it running on one of my Pi 3B+ machines. I made a backup image of the SD card just in case and then ran sudo do-release-update. After a couple or 3 hours (thought I was updating Windoze :-) and a reboot I see the 18.04 green background etc. And...
ken@taylor24:~$ lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 18.04.1 LTS
Release:	18.04
Codename:	bionic
I have not tried out various programs but so far, so good.
Ken
Fri Sep 07, 2018 7:43 pm
Release:	18.04
Codename:	bionic
Ken
There are several post regards Ubuntu 18.04 by the poster 'feelslikeautumn' he appears to have undertaken much work on getting it running on a 3B+:
https://www.raspberrypi.org/forums/sear ... 1&sr=posts
taylorkh
Fri Sep 07, 2018 8:55 pm
Thanks fruitoftheloom,
So far I have found that the Network Manager Applet is missing (networking works OK) and, more importantly, the time sync with an NTP server does NOT work. This is sort of a killer as the Pi has no battery backup clock.
Ken
taylorkh
Sat Sep 08, 2018 6:30 pm
It gets better and better. I fired up the Pi 3B+ on my upgraded to 18.04 SD card. Just like magic the time sync is now working :D A little searching provided a fix for the notification - or lack thereof - issue. Basically change the Panel in Mate-Tweak from "Familiar" to something else and then back again. I had to redo my panel - change to the old style Menu Bar and add back a few icons. All works well and the network manager applet is back. :D :D And the best news of all... FIrefox installed during the upgrade and IT WORKS :D :D :D
Ken
MaxVMH
Sat Sep 08, 2018 7:05 pm
What distribution did you upgrade from? The Ubuntu Mate 16.04 image I made or another image?
taylorkh
Sat Sep 08, 2018 10:23 pm
I started with the "official" Ubuntu Mate 16.04 image and installed it on a Pi 3B. I then did the "sudo BRANCH=stable rpi-update" trick. This allowed the image to run on the Pi 3B+. I had run that for a few weeks, added a few packages etc. I then upgraded that working image to 18.04. The only program I "lost" - at least that I have found so far - is the Midori browser. This I think was somewhat obsolete and now that Firefox works... no big deal.
Ken
mrdone
Tue Sep 25, 2018 7:33 pm
Hi Ken! I did exactly the same as you: flashed SD card with ubuntu mate 16.04, did the rpi-update on RPi 3B with working WiFi and then plugged the card to RPi 3B+. Everything seems to work fine except wifi. I tried to reconfigure WiFi in Network Manager but no luck. Did you do anything else and do you have any idea how can I try to fix this wifi problem on 3B+?
taylorkh
Tue Sep 25, 2018 8:10 pm
Hello mrdone,
I do not think that WiFi works in Ubuntu on the Pi3B+. I have read that WiFi works in Raspbian on the 3B+ but I have not tried it. I have also read, I think, that some wireless related files could be copied from a Raspbian install to Ubuntu to fix the problem. I have not tried this either as I do not need WiFi at the moment.
If I get a chance I may look into this option. Please let me know if YOU find out how to do it.
Thanks,
Ken
MaxVMH
Wed Sep 26, 2018 2:34 pm
Hello mrdone,
Thanks,
Ken
Copy the contents of /lib/firmware/brcm/ from the latest Raspbian root partition to your Ubuntu Mate root partition.
Then make sure to run the following command:
sudo rfkill unblock wifi
And reboot (through GUI or with the following command):
sudo reboot
taylorkh
Wed Sep 26, 2018 5:00 pm
Thanks MaxVMH ,
There appear to be ONLY three files which need to be added to Ubuntu to get the WiFi card running on the 3B+. Those are:
brcmfmac43455-sdio.bin
brcmfmac43455-sdio.clm_blob
brcmfmac43455-sdio.txt
I have copied them from a new Raspbian install. They are also described in this wiki https://wiki.ubuntu.com/ARM/RaspberryPi. I added them to a Ubuntu Mate 16.04 install and to my home done upgrade to 18.04 install. WiFi works on both :D I did of course have to create the WiFi connection, using the gui, as my wireless network is hidden.
Ken
mrdone
Thu Sep 27, 2018 6:32 am
taylorkh wrote: There appear to be ONLY three files which need to be added to Ubuntu to get the WiFi card running on the 3B+. Those are:
MaxVMH and taylorkh , thanks worked like a charm! After upgrade to 18.04 Ubuntu seems to become more responsive so I am quite happy.
MaxVMH
Fri Sep 28, 2018 2:18 pm
@taylorkh: thanks for the additional information & @mrdone: glad to hear you got it to work :)
taylorkh
Fri Sep 28, 2018 3:39 pm
Thank YOU both for helping to motivate me to figure this out. I was not planning on using WiFi on my Pi computers but at least now I have it available should I decide to do so. And with 18.04 I should be good for support until 2023 :mrgreen:
Ken
cjan
Sat Sep 29, 2018 2:05 am
just saw Wimpy is back in mate forum
  • I have started preparing PI images based on Ubuntu MATE 18.04.1. I've hit more issues than in the past and I have not had as much free time recently which is delaying the release.
cjan
Tue Oct 09, 2018 8:21 am
fresh install bionic sounds good, but /opt is empty.
search ubuntu wiki, they miss libraspberrypi-dev?
and 'http://ppa.launchpad.net/ubuntu-raspi2/ppa/ubuntu bionic/main' is too old.
does libraspberrypi-dev replaced by others?
code_exec
Tue Nov 06, 2018 4:43 pm
For those wanting to upgrade to Ubuntu MATE 18.04 you can follow my instructions.
viewtopic.php?f=56&t=223749&p=1371614
Return to “Other”
