deliloy
My Pi 3 hacked
Tue Sep 18, 2018 6:09 pm
Hi mates, I think that my pi 3 has been hacked. My question is how can I get it back as I do not have physical access to it, however, I can connect to it from local network via TeamViewer. I also have ftp login as normal user(not admin privileges). SSH has been removed so ssh is not possible. Any suggestion will be helpfull.
topguy
Re: My Pi 3 hacked
Wed Sep 19, 2018 11:33 am
If you really have been hacked the only safe way is to replace (or reformat) the SD card.
Did you or the "hacker" remove SSH service ?
RaTTuS
Contact: Twitter YouTube
Re: My Pi 3 hacked
Wed Sep 19, 2018 11:42 am
and ftp is so insecure as to be stupid to have enabled
Covfefe
LTolledo
Re: My Pi 3 hacked
Wed Sep 19, 2018 12:45 pm
..... is to replace (or reformat) the SD card.
... and flash a new copy of raspbian (lite? desktop?), or make a new install using NOOBS/PINN.
in the new installation make a new set of passwords (dont use any of the passwords from your old compromised setup).
Some people be like:
Paul Webster
Contact: Twitter
Re: My Pi 3 hacked
Wed Sep 19, 2018 1:03 pm
However, if you do not have physical access to it then it will be much harder than usual to rewrite the SD card.
Is it a Pi that supports booting from the network instead of the SD card?
What is preventing your physical access?
hippy
Re: My Pi 3 hacked
Wed Sep 19, 2018 2:10 pm
Perhaps you could enrol the assistance of someone who does ?
Re: My Pi 3 hacked
Wed Sep 19, 2018 2:59 pm
Unless the RPi SBC is booted from a Server, having physical access is the only solution :shock:
HawaiianPi
Re: My Pi 3 hacked
Mon Sep 24, 2018 6:18 am
How do you not have access to a computer on your local network?
rpdom
Re: My Pi 3 hacked
Mon Sep 24, 2018 6:27 am
Local network does not always mean physically local. TeamViewer is remote VPN type access.
Re: My Pi 3 hacked
Mon Sep 24, 2018 10:46 am
I have a local network of 4 units that are at the top of tall masts and communicating via WiFi. Actually getting up there to tweak them would require calling the service guys to go up there with a cherry picker. Which is expensive an time consuming.
Return to “Raspberry Pi OS”
