hal58
Brother HL-L2300D Printer on Pi
Fri Jul 24, 2015 11:11 am
Newegg just had a special on these Laser printers for $49.99 and I picked one up to use as a network printer from a Raspberry Pi2. Unfortunately, Brother only fully supports MS-Windows and Mac and a token i386 driver for Linux. They claim that their binary portion of this driver is proprietary and apparently won release the source, so I went digging and thanks to Peter De Wachter found success. With a little tweaking to his instructions, his sources are compilable on the Pi2 and seem to work well.
First, download his ZIP file at https://github.com/pdewacht/brlaser and unzip it. It creates a directory called brlaser-master. in your current directory. ´cd´ into it. Next you will need to install the tools to compile source code and some other files to use as input. Get these with:
sudo apt-get install cups build-essential libcups2-dev libcupsimage2-dev automake-1.11
The last file in this list was missing from the original instructions and removed some errors.
Next, begin the configuration and compilation process. After each step, you _should_ receive no errors but if you do, try to correct them before moving on.
./autogen.sh
./configure
make
sudo make install
If there were no errors when you get here, then the driver is installed and you are ready to configure the printer driver. By default, version 3 of this driver (which is the one currently available) supports three Brother printers:
* Brother DCP-7030
* Brother DCP-7055
* Brother DCP-7065DN
First reset the CUPS driver so that these new choices are available
sudo service cups restart
Then open a browser (Epiphany is the new default) and navigate to:
http://localhost:631
select the ´Administration´ tab and ´Add Printer´. You will be prompted for your username and password. Step through the options selecting one of the available drivers with ´brlaser´ in it. Just to make sure that it is working, select the ´Maintenance´ tab and print a test sheet. If it comes out Ok, then you are good to print.
Enjoy and thanks to Peter for doing the hard work.
PhotonX
Re: Brother HL-L2300D Printer on Pi
Thu Dec 03, 2015 7:52 pm
Hi, are you still able to use your HL-L2300D on the Raspi? I've followed your HowTo (big thanks for it!) but ran into some strange problems: viewtopic.php?t=127401
Ridgeland
Tue Feb 02, 2016 10:42 pm
Thank you!
I now have a Raspberry Pi with SSH and VNC working as a WiFi local print server. My printer is a DCP7065DN. Brother's download did not work, neither did the listed ones from jessie. I have tightvncserver in /etc/rc.local on the Raspberry Pi so any time it's on I can access it from my PC using vncviewer. I'm using Xubuntu 14.04.3 at my PC.
The automake-1.11 crashed - use just "automake" as now it's at 1.14 I think.
jhansx
Wed Jun 13, 2018 4:14 am
I think the text is wrong on the automake-1.11.
[email protected]:~ $ sudo apt-get install cups build-essential libcups2-dev libcupsimage2-dev automake-1.11
Reading package lists... Done
Building dependency tree
E: Unable to locate package automake-1.11
E: Couldn't find any package by glob 'automake-1.11'
E: Couldn't find any package by regex 'automake-1.11'
BUT ;) when I use ths
sudo apt-get automake1.11
I get a normal install...
The following packages were automatically installed and are no longer required:
  lxkeymap python-gobject python-xklavier
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  autoconf autotools-dev libsigsegv2 m4
Suggested packages:
  autoconf-archive gnu-standards autoconf-doc libtool gettext m4-doc
  autoconf automake1.11 autotools-dev libsigsegv2 m4
0 upgraded, 5 newly installed, 0 to remove and 34 not upgraded.
Need to get 1,160 kB of archives.
After this operation, 4,026 kB of additional disk space will be used.
Do you want to continue? [Y/n]
I haven't completed the install yet but it looks promising./
FINALLY A PRINTER ON RPI... maybe.
Wed Jun 13, 2018 6:45 am
Suggested packages:
Unfortunately Brother support for Linux ARMHF is abysmal....
adieu
joshlicht
Sun Sep 23, 2018 9:02 pm
I am having trouble after downloading the zip file. i used this command [ sudo apt-get install cups build-essential libcups2-dev libcupsimage2-dev automake-1.11 ] but it gave an error saying it couldn't find it. so i used [ sudo apt-get install automake1.11 ] and it downloaded. but now when i try to do the next step [ ./autogen.sh ] [ ./configure ] [ make ] [ sudo make install ] it says no such file or directory.
can anyone help?
PhotonX
Mon Sep 24, 2018 6:14 am
Looks like you need to cd into the directory where you unpacked your zip file.
joshlicht
Wed Sep 26, 2018 4:03 pm
how would i cd into the file?
PhotonX
Wed Sep 26, 2018 6:30 pm
Well, as usual, via
cd /path/to/extracted_folder
Most probably the folder is somewhere in your home folder, so it would be
cd ~/extracted_folder
Of course "extracted_folder" is just a placeholder, you need to find out its name, most probably it is starting with "brother...".
joshlicht
Fri Sep 28, 2018 9:59 pm
I tried
cd/path/to/brlaser-master
which is my file name but it still gave me
 bash: cd/path/to/brlaser-master: no such file or directory
do you have any other suggestions? did i unzip the file improperly?
PhotonX
Sat Sep 29, 2018 6:21 am
Two things:
1. /path/to is also just a placeholder. It could be something like your home folder /home/pi or /home/joshlicht or just ~/ as shorthand notation. It could be also your desktop folder, ~/Desktop. Or any other folder - you have to know where exactly you extracted the zip file.
2. You need a space between the cd command and the folder you want to jump to. So it is
cd something
not
cdsomething
joshlicht
Sat Sep 29, 2018 6:07 pm
ok I cd into the files thanks to your help. now i'm on to the last steps i think.
./autogen.sh
./configure
make
sudo make install
when i try the
./autogen.sh
i end up with the same "no such file or directory" do they stand for something in the file i just cd into? any more suggestions? Also thanks for helping me out. you are the best.
PhotonX
Sat Sep 29, 2018 7:10 pm
If you have a GUI installed on your Raspi, you can just use the file manager and check where the files are located. Otherwise, you can view the contents of any folder with
ls -l /path/to/your/folder
or just
ls
if it is the current folder. You can then jump to any folder with
cd /path/to/your/folder
This way you can make sure that
autogen.sh
is there and you are in the folder where it is located.
joshlicht
Sun Sep 30, 2018 12:14 am
i am in the proper file of the brlaser-master and it still cant find
./autogen.sh
i tried it in
cd /home/pi/Downloads/brlaser-master
and
cd /home/pi/Downloads/brlaser-master/test
and
cd /home/pi/Downloads/brlaser-master/src
and it still said no such file or directory. i'm not sure how to get it to work.
PhotonX
Sun Sep 30, 2018 5:25 am
Ok, now I looked into the building instructions. Where do you have this autogen.sh thing from? ;) On the brlaser page it says
cmake .
make
sudo make install
See https://github.com/pdewacht/brlaser
Sun Sep 30, 2018 7:31 am
cmake .
make
sudo make install
Maybe the driver is available from the Raspbian Stretch Repositories ??
sudo apt update
sudo apt install printer-driver-brlaser
https://packages.debian.org/stretch/pri ... er-brlaser
adieu
PhotonX
Sun Sep 30, 2018 6:56 pm
Well, if there are packages, it's even easier! :)
joshlicht
Tue Oct 02, 2018 1:21 am
yes the package worked!!! thank you guys so much for the help. :D
salsaman
Tue Jan 15, 2019 5:03 am
sudo apt update
WOW. My HL-L2340DW is working now, or at least as much as I need it to. This was so much simpler than I thought it would be in the end.
THANK YOU!
