I'm running raspbian stretch on about 6 or 7 pis (both pi2 and pi3s). I have an iscsi lun for each pi. Each lun has 3 partitions all ext4 which I use for mounting / /var and /home. They all run using only /boot on a microsd card and all other data stored on iscsi partitions.
The problem i have is when i upgrade the raspberry pi kernel and bootloader which happened today. It successfully upgrades all the packages. After its done that i run:
/usr/sbin/mkinitramfs -v -o /boot/initrd.img
It says the ISCSI driver was not found, but i thought that would be built into the initramfs when i do the mkinitramfs call above.
Any pointers you can give me to debug this and put it right would be really fantastic - tearing my hair out at the moment.
===CUT===
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.69-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1141 SMP Mon Sep 10 15:2
6:29 BST 2018
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 8 MiB at 0x3ac00000
[ 0.000000] percpu: Embedded 17 pages/cpu @ba348000 s38720 r8192 d22720 u69632
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240555
[ 0.000000] Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem
.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 modules=iscsi_tcp ip=192.168.0.189:192.168.0.10:192.168.0.1:255.255.255.0:pid
esktop:eth0:off rw rootfs=ext4 root=UUID=45ab2db0-3eae-414c-bf1b-ec4888d24eb7 fsck.repair=yes cgroup_enable=cpuset cgroup_enable=memory elevator=deadline
rootwait panic=15
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 933300K/970752K available (7168K kernel code, 575K rwdata, 2076K rodata, 1024K init, 706K bss, 29260K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
[ 0.000000] lowmem : 0x80000000 - 0xbb400000 ( 948 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x80800000 (8160 kB)
[ 0.000000] .init : 0x80b00000 - 0x80c00000 (1024 kB)
[ 0.000000] .data : 0x80c00000 - 0x80c8fe8c ( 576 kB)
[ 0.000000] .bss : 0x80c96f10 - 0x80d478b0 ( 707 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 25276 entries in 75 pages
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000022] Switching to timer-based delay loop, resolution 52ns
[ 0.000270] Console: colour dummy device 80x30
[ 0.000830] console [tty1] enabled
[ 0.000872] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000912] pid_max: default: 32768 minimum: 301
[ 0.001239] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001273] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002143] CPU: Testing write buffer coherency: ok
[ 0.002572] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002993] Setting up static identity map for 0x100000 - 0x10003c
[ 0.003132] Hierarchical SRCU implementation.
[ 0.003830] smp: Bringing up secondary CPUs ...
[ 0.004633] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005479] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006304] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006411] smp: Brought up 1 node, 4 CPUs
[ 0.006482] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.006504] CPU: All CPU(s) started in HYP mode.
[ 0.006522] CPU: Virtualization extensions available.
[ 0.007422] devtmpfs: initialized
[ 0.017637] random: get_random_u32 called from bucket_table_alloc+0xfc/0x24c with crng_init=0
[ 0.018473] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.018718] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.018763] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.019341] pinctrl core: initialized pinctrl subsystem
[ 0.020132] NET: Registered protocol family 16
[ 0.022899] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.027755] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.027788] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.028002] Serial: AMBA PL011 UART driver
[ 0.029657] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.030172] uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.061754] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb813000, dmachans=0x1
[ 0.063186] SCSI subsystem initialized
[ 0.063426] usbcore: registered new interface driver usbfs
[ 0.063495] usbcore: registered new interface driver hub
[ 0.063597] usbcore: registered new device driver usb
[ 0.070084] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-09-10 17:26
[ 0.071552] clocksource: Switched to clocksource arch_sys_counter
[ 0.147758] VFS: Disk quotas dquot_6.6.0
[ 0.147868] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.148070] FS-Cache: Loaded
[ 0.148282] CacheFiles: Loaded
[ 0.157115] NET: Registered protocol family 2
[ 0.157853] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.157982] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.158184] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.158329] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.158391] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.158637] NET: Registered protocol family 1
[ 0.159112] RPC: Registered named UNIX socket transport module.
[ 0.159136] RPC: Registered udp transport module.
[ 0.159156] RPC: Registered tcp transport module.
[ 0.159175] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.159389] Trying to unpack rootfs image as initramfs...
[ 0.708711] Freeing initrd memory: 6924K
[ 0.714283] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.717052] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.724963] FS-Cache: Netfs 'nfs' registered for caching
[ 0.725638] NFS: Registering the id_resolver key type
[ 0.725699] Key type id_resolver registered
[ 0.725719] Key type id_legacy registered
[ 0.725748] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.727741] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.727897] io scheduler noop registered
[ 0.727919] io scheduler deadline registered (default)
[ 0.728207] io scheduler cfq registered
[ 0.728229] io scheduler mq-deadline registered
[ 0.728248] io scheduler kyber registered
[ 0.731116] BCM2708FB: allocated DMA memory fad10000
[ 0.731160] BCM2708FB: allocated DMA channel 0 @ bb813000
[ 0.788984] Console: switching to colour frame buffer device 240x67
[ 0.823269] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 0.824819] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.825100] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.825768] vc-sm: Videocore shared memory driver
[ 0.826185] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 0.836122] brd: module loaded
[ 0.845306] loop: module loaded
[ 0.845444] Loading iSCSI transport class v2.0-870.
[ 0.846288] libphy: Fixed MDIO Bus: probed
[ 0.846519] usbcore: registered new interface driver lan78xx
[ 0.846734] usbcore: registered new interface driver smsc95xx
[ 0.846913] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.875028] dwc_otg 3f980000.usb: base=0xf0980000
[ 1.075380] Core Release: 2.80a
[ 1.075488] Setting default values for core params
[ 1.075656] Finished setting default values for core params
[ 1.276070] Using Buffer DMA mode
[ 1.276178] Periodic Transfer Interrupt Enhancement - disabled
[ 1.276347] Multiprocessor Interrupt Enhancement - disabled
[ 1.276510] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.276645] Dedicated Tx FIFOs mode
[ 1.277145] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
[ 1.277445] FIQ FSM acceleration enabled for :
[ 1.277445] Non-periodic Split Transactions
[ 1.277445] Periodic Split Transactions
[ 1.277445] High-Speed Isochronous Endpoints
[ 1.277445] Interrupt/Control Split Transaction hack enabled
[ 1.278105] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x805e9588
[ 1.278289] WARN::hcd_init_fiq:460: FIQ ASM at 0x805e98f0 length 36
[ 1.278478] WARN::hcd_init_fiq:486: MPHI regs_base at 0xf0006000
[ 1.278700] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.278878] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.286642] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 1.294316] Init: Port Power? op_state=1
[ 1.301877] Init: Power Port (0)
[ 1.309558] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.317159] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.324755] usb usb1: Product: DWC OTG Controller
[ 1.332327] usb usb1: Manufacturer: Linux 4.14.69-v7+ dwc_otg_hcd
[ 1.339917] usb usb1: SerialNumber: 3f980000.usb
[ 1.348212] hub 1-0:1.0: USB hub found
[ 1.355878] hub 1-0:1.0: 1 port detected
[ 1.364249] usbcore: registered new interface driver usb-storage
[ 1.372052] mousedev: PS/2 mouse device common for all mice
[ 1.379701] IR NEC protocol handler initialized
[ 1.387197] IR RC5(x/sz) protocol handler initialized
[ 1.394659] IR RC6 protocol handler initialized
[ 1.402045] IR JVC protocol handler initialized
[ 1.409362] IR Sony protocol handler initialized
[ 1.416659] IR SANYO protocol handler initialized
[ 1.424018] IR Sharp protocol handler initialized
[ 1.431253] IR MCE Keyboard/mouse protocol handler initialized
[ 1.438480] IR XMP protocol handler initialized
[ 1.446375] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 1.453912] bcm2835-cpufreq: min=600000 max=1200000
[ 1.461583] sdhci: Secure Digital Host Controller Interface driver
[ 1.468920] sdhci: Copyright(c) Pierre Ossman
[ 1.476782] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[ 1.484624] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 1.492305] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.501341] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.509165] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.516915] usbcore: registered new interface driver usbhid
[ 1.524524] usbhid: USB HID core driver
[ 1.532678] vchiq: vchiq_init_state: slot_zero = bad80000, is_master = 0
[ 1.541780] [vc_sm_connected_init]: start
[ 1.552085] [vc_sm_connected_init]: end - returning 0
[ 1.560087] Initializing XFRM netlink socket
[ 1.567483] NET: Registered protocol family 17
[ 1.574960] Key type dns_resolver registered
[ 1.583022] Indeed it is in host mode hprt0 = 00021501
[ 1.591587] Registering SWP/SWPB emulation handler
[ 1.599605] registered taskstats version 1
[ 1.613046] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 1.620622] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 1.629853] console [ttyS0] disabled
[ 1.637514] 3f215040.serial: ttyS0 at MMIO 0x0 (irq = 166, base_baud = 31250000) is a 16550
[ 1.678410] random: fast init done
[ 1.791593] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.791737] Indeed it is in host mode hprt0 = 00001101
[ 2.021839] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.021848] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.022499] hub 1-1:1.0: USB hub found
[ 2.022587] hub 1-1:1.0: 5 ports detected
[ 2.341578] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.471813] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.471823] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.481230] smsc95xx v1.0.6
[ 2.543350] NOHZ: local_softirq_pending 01
[ 2.543369] NOHZ: local_softirq_pending 01
[ 2.543386] NOHZ: local_softirq_pending 01
[ 2.543413] NOHZ: local_softirq_pending 01
[ 2.574922] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet,aa:bb:cc:dd:ee:ff
[ 2.671582] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[ 2.814884] console [ttyS0] enabled
[ 2.816339] usb 1-1.2: New USB device found, idVendor=17ef, idProduct=6025
[ 2.816348] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.816355] usb 1-1.2: Product: ThinkPad USB Travel Mouse
[ 2.871106] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 2.884986] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 2.898853] input: ThinkPad USB Travel Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:17EF:6025.0001/input/input0
[ 2.919945] hid-generic 0003:17EF:6025.0001: input,hidraw0: USB HID v11.10 Mouse [ThinkPad USB Travel Mouse] on usb-3f980000.usb-1.2/input0
[ 2.952338] sdhost: log_buf @ bad08000 (fad08000)
[ 3.000689] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.016184] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.031557] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.031589] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
[ 3.060156] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.075016] of_cfs_init
[ 3.085726] of_cfs_init: OK
[ 3.096364] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.162013] NOHZ: local_softirq_pending 01
[ 3.174207] NOHZ: local_softirq_pending 01
[ 3.186372] NOHZ: local_softirq_pending 01
[ 3.198423] NOHZ: local_softirq_pending 41
[ 3.210347] NOHZ: local_softirq_pending 41
[ 3.222157] NOHZ: local_softirq_pending 41
[ 3.241857] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.264269] mmc0: new high speed SDHC card at address aaaa
[ 3.264896] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 3.293528] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[ 3.311471] mmcblk0: p1 p2
[ 3.329969] usb 1-1.3: New USB device found, idVendor=04d9, idProduct=1603
[ 3.335085] mmc1: new high speed SDIO card at address 0001
[ 3.358325] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.373753] usb 1-1.3: Product: USB Keyboard
[ 3.386149] usb 1-1.3: Manufacturer:
[ 3.446067] input: USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:04D9:1603.0002/input/input1
[ 3.532061] hid-generic 0003:04D9:1603.0002: input,hidraw1: USB HID v1.10 Keyboard [ USB Keyboard] on usb-3f980000.usb-1.3/input0
[ 3.621149] input: USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:04D9:1603.0003/input/input2
[ 3.711750] hid-generic 0003:04D9:1603.0003: input,hidraw2: USB HID v1.10 Device [ USB Keyboard] on usb-3f980000.usb-1.3/input1
[ 4.771766] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 4.821567] IP-Config: Complete:
[ 4.833728] device=eth0, hwaddr=aa:bb:cc:dd:ee:ff, ipaddr=192.168.0.xxx, mask=255.255.255.0, gw=192.168.0.1
[ 4.853205] host=yyyyyyy, domain=, nis-domain=(none)
[ 4.867990] bootserver=192.168.0.xxx, rootserver=192.168.0.xx, rootpath=
[ 4.887825] Freeing unused kernel memory: 1024K
[ 5.046699] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 5.054249] random: udevadm: uninitialized urandom read (16 bytes read)
[ 5.056264] random: udevadm: uninitialized urandom read (16 bytes read)
done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... IP-Config: eth0 hardware address aa:bb:cc:dd:ee:ff mtu 1500
IP-Config: eth0 guessed broadcast address 192.168.0.255
IP-Config: eth0 complete:
address: 192.168.0.xxx broadcast: 192.168.0.255 netmask: 255.255.255.0
gateway: 192.168.0.1 dns0 : 0.0.0.0 dns1 : 0.0.0.0
host : xxxxx
rootserver: 192.168.0.xxx rootpath:
filename :
iscsistart: Logging into iqn.blahblahblah 192.168.0.xxx:3260,1
iscsistart: version 2.0-874
iscsistart: initiator reported error (12 - iSCSI driver not found. Please make sure it is loaded, and retry the operation)
done.
Begin: Running /scripts/local-premount ... done.
Begin: Waiting for root file system ... Begin: Running /scripts/local-block ... done.
[ 15.060255] random: crng init done
[ 15.072603] random: 7 urandom warning(s) missed due to ratelimiting
done.
Gave up waiting for root file system device. Common problems:
- Boot args (cat /proc/cmdline)
- Check rootdelay= (did the system wait long enough?)
- Missing modules (cat /proc/modules; ls /dev)
ALERT! UUID=12345678-abcd-abcd-abcd-123412341234 does not exist. Dropping to a shell!
Rebooting automatically due to panic= boot argument
===CUT===
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 modules=iscsi_tcp ip=192.168.0.xxx:192.168.0.xxx:192.168.0.1:255.255.255.0:yyyyyyyyy:eth0:off rw rootfs=ext4 root=UUID=12345678-abcd-abcd-abcd-123412341234 fsck.repair=yes cgroup_enable=cpuset cgroup_enable=memory elevator=deadline rootwait panic=15
hdmi_group=2
hdmi_mode=82
enable_uart=1
initramfs initrd.img followkernel
TIA
chris
