andalus
Ethernet on RISCOS not detectable
Fri Sep 14, 2018 11:28 pm
I am running RISCOS for my first time. I tempered a bit with the OS and its windows, but it doesn't detect my Ethernet adapter. It has only a USB-to-Ethernet adapter mentioned in its networking.
Anybody knows how may I let the RISC OS detect the ethernet adapter?
I am using Raspberry Pi 3.
Best,
Amjad
andalus
Re: Ethernet on RISCOS not detectable
Wed Sep 26, 2018 6:24 pm
would anybody jump to help? :(
Wed Sep 26, 2018 8:59 pm
Best,
Amjad
Maybe ask the developers ??
https://www.riscosopen.org/forum/
adieu
My other Computer is an Asus CS10 ChromeBit running Chrome Operating System.
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
bulldozer
Thu Sep 27, 2018 1:50 pm
Hi what RISCOS are you using and which Pi you are using. I have an out of the box Pi 3B and a SD card from ROOL and it works quite nicely.
andalus
Sun Sep 30, 2018 7:41 pm
I am using RPi 3B. I installed the OS from the website and put it on the SD card. The OS opens with no problem. but it seems it can't detect or see the ethernet nor the wifi adapters.
andalus
Sun Sep 30, 2018 8:56 pm
bulldozer wrote:
Thu Sep 27, 2018 2:10 pm
Also an interresting piece at http://www.riscos.org/networking/riscos.html
Also perhaps of interrest : https://www.riscosopen.org/wiki/documen ... Networking
Thanks. I've looked into those posts but they assume I have the ethernet card icon. I don't.
andalus
Best,
Amjad
Thanks. This is what I eventually did.
bulldozer
Mon Oct 01, 2018 9:40 am
If you downloaded it strait it shouldn't be a problem but I see that you also submitted the question on the ROOL forum. WiFi is not supported by RISCOS at this moment.
andalus
Wed Oct 03, 2018 6:28 pm
It is working now.
on RISCOS forums they said that USB-to-Ethernet adapter that i see on my settings is the Ethernet. but because they Ethernet on the RPi 3 is USB based then that's why it appears this way.
Another point of confusion that happened with me is, after the RISCOS fails to get an IP address from DHCP, it falls back to manual IP address. Even If I try to reboot again, the IP assignment settings is set permanently to manual assignment!!! I assumed it should try DHCP every time it boots but it seems it is not. I had to go to the IP assignment settings and change it to DHCP to get it to work with DHCP server.
Now things are fine. thank you all for your valuable assistance.
Amjad
bulldozer
Thu Oct 04, 2018 10:05 pm
Your welcome no problem. If you have more questions please don't hesitate to ask...
Return to “RISCOS”
