ksharindam
Use opencv mat data to create dispmanx resource
Sun Sep 09, 2018 7:22 am
I am a newbie in dispmanx.
I want to load an image with opencv using
cv::Mat img = cv::imread("test.jpg");
now i want to use write/use img.data to create dispmanx resource.
how i can utilize img.data in this case.
void *image;
vc_dispmanx_resource_write_data(resource,
                                type,
                                pitch,
                                image,
                                &dst_rect );
please explain clearly.
ksharindam
Re: Use opencv mat data to create dispmanx resource
Tue Sep 11, 2018 3:46 pm
Finally found it by myself.
Each rows of cv mat data is aligned to 4. But the pitch of image buffer for dispmanx is needed to be multiple of 16. Thats why we can not directly use mat.data for the resource buffer.
We have to allocate a data of pitch*height. and copy each row of cv::mat to that allocated memory.
uchar* cvimg2VCbuffer(int width, int height, int bytesPerLine, uchar* data)
    int pitch = ALIGN_UP(width, 16)*3;
    void* buffer = calloc(1, pitch*height);
    uint8_t *line = (uint8_t*)buffer;
    for (int i = 0;i < height; ++i) {
        memcpy(line, data, bytesPerLine);
        line += pitch;
        data += bytesPerLine;
    return (uchar*)buffer;
Return to “Graphics programming”
