MrBool
scriptexecutor problem
Thu Apr 05, 2018 9:17 am
I'm trying to use scriptexecutor to flash CM3. I have a problem with buildroot push over USB.
I followed by build instructions:
https://github.com/raspberrypi/scriptex ... ustomizing
and build was done fine.
When I run command
sudo ./rpiboot -d /home/dawid/scriptexecutor/output
I always get:
Waiting for BCM2835/6/7
Sending bootcode.bin
Successful read 4 bytes
Second stage boot server
File read: config.txt
File read: start.elf
File read: fixup.dat
and it stops.
rpiboot works fine with standard files, so it is not a hardware problem.
PhilE
Re: scriptexecutor problem
Thu Apr 05, 2018 9:23 am
This is a duplicate of an issue created on the usbboot GitHub repo: https://github.com/raspberrypi/usbboot/issues/30
gsh
Thu Apr 05, 2018 9:42 am
Yeah, I'm just looking into some CM3 booting problems now...
Might be worth reverting the firmware back to when maxnet originally wrote the scriptexecutor to see if that helps?
Gordon
Gordon Hollingworth PhD
Raspberry Pi - Director of Software Engineering
MrBool
Sat Sep 08, 2018 12:50 pm
Any update about that issue?
I tried lastest usbboot and the result is the same.
Scriptexecutor is completely useless.
gsh
Sun Sep 09, 2018 6:20 pm
You could try enabling the UART output on bootcode.bin using
strings bootcode.bin | grep BOOT_UART=0
Should give you BOOT_UART=0 by default on a clean recent bootcode.bin (if I've got this wrong it may be UART_BOOT instead), then do:
sed -i -e "s/BOOT_UART=0/BOOT_UART=1/" bootcode.bin
This should enable the UART output on the GPIO14,15 which you can capture and check...
MrBool
Mon Sep 10, 2018 8:38 am
Commands:
strings bootcode.bin | grep UART_BOOT=0
do not return anything.
PhilE
Mon Sep 10, 2018 8:50 am
The result you should get is:
[email protected]raspberrypi:~$ strings /boot/bootcode.bin | grep BOOT_UART
BOOT_UART=0
(you may need to change the path to bootcode.bin depending on where your shell is hosted, file system mount points etc.)
If you don't then it is because your firmware is too old to support the feature. You can grab the current build from our firmware repo.
MrBool
Mon Sep 10, 2018 10:03 am
This works on /boot/bootcode.bin on the eMMC but we are talking about scriptexecutor. It has their own bootcode.bin file (on the output directory) and this file loaded by USB. It looks like scriptexecutor uses old firmware during the build.
gsh
Mon Sep 10, 2018 1:53 pm
Just rebuild it and use the latest firmware
MrBool
Mon Sep 10, 2018 4:38 pm
OK. I use the latest firmware. Here is the console log:
Raspberry Pi Bootcode
USB device booting
Read File: config.txt, 28 (bytes)
Read File: start.elf, 2846756 (bytes)
Read File: fixup.dat, 6659 (bytes)
MESS:00:00:15.758794:0: brfs: File read: /mfs/sd/config.txt
MESS:00:00:15.762915:0: brfs: File read: 28 bytes
MESS:00:00:16.137702:0: HDMI:EDID error reading EDID block 0 attempt 0
MESS:00:00:16.504491:0: HDMI:EDID error reading EDID block 0 attempt 1
MESS:00:00:16.871278:0: HDMI:EDID error reading EDID block 0 attempt 2
MESS:00:00:17.238064:0: HDMI:EDID error reading EDID block 0 attempt 3
MESS:00:00:17.604852:0: HDMI:EDID error reading EDID block 0 attempt 4
MESS:00:00:17.971637:0: HDMI:EDID error reading EDID block 0 attempt 5
MESS:00:00:18.338424:0: HDMI:EDID error reading EDID block 0 attempt 6
MESS:00:00:18.705211:0: HDMI:EDID error reading EDID block 0 attempt 7
MESS:00:00:19.071997:0: HDMI:EDID error reading EDID block 0 attempt 8
MESS:00:00:19.438783:0: HDMI:EDID error reading EDID block 0 attempt 9
MESS:00:00:19.444613:0: HDMI:EDID giving up on reading EDID block 0
and freeze here.
gsh
Tue Sep 11, 2018 9:06 am
Do you have a pullup to 1v8 on HDMI_HPD_N_1V8
MrBool
Tue Sep 11, 2018 10:28 am
Yes, I have the pullup 100k to 1v8 on HDMI_HPD_N_1V8.
gsh
Tue Sep 11, 2018 10:32 am
Do you have the same response on a CMIO3 board?
MrBool
Tue Sep 11, 2018 10:34 am
I don't have a CMIO3 board.
gsh
Tue Sep 11, 2018 3:22 pm
If you had a 1V8 pullup then it wouldn't be detecting any HDMI, and therefore, it wouldn't try reading EDID...
Try adding hdmi_ignore_edid=1 to config.txt that should stop it from reading the EDID
Gordon
MrBool
Wed Sep 12, 2018 6:31 am
My mistake. I have pullup on schematic but I use version without HDMI and this pullup is not assembled.
After adding hdmi_ignore_edid=1 to config.txt console log looks like below
USB device booting
Read File: config.txt, 48 (bytes)
MESS:00:00:15.794203:0: brfs: File read: /mfs/sd/config.txt
MESS:00:00:15.798342:0: brfs: File read: 48 bytes
MESS:00:00:15.812307:0: HDMI:EDID version 1.3, 1 extensions, screen size 16x9 cm
MESS:00:00:15.818047:0: HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
MESS:00:00:15.835923:0: HDMI:EDID found preferred CEA detail timing format: 1920x1080p @ 60 Hz (16)
MESS:00:00:15.844678:0: HDMI:EDID found CEA detail timing format: 1280x720p @ 50 Hz (19)
MESS:00:00:15.852485:0: HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
MESS:00:00:15.861596:0: HDMI:EDID found DMT format: code 5, 640x480p @ 72 Hz in established timing I/II
MESS:00:00:15.870711:0: HDMI:EDID found DMT format: code 6, 640x480p @ 75 Hz in established timing I/II
MESS:00:00:15.879825:0: HDMI:EDID found DMT format: code 8, 800x600p @ 56 Hz in established timing I/II
MESS:00:00:15.888940:0: HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
MESS:00:00:15.898055:0: HDMI:EDID found DMT format: code 10, 800x600p @ 72 Hz in established timing I/II
MESS:00:00:15.907256:0: HDMI:EDID found DMT format: code 11, 800x600p @ 75 Hz in established timing I/II
MESS:00:00:15.916459:0: HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
MESS:00:00:15.925746:0: HDMI:EDID found DMT format: code 17, 1024x768p @ 70 Hz in established timing I/II
MESS:00:00:15.935035:0: HDMI:EDID found DMT format: code 18, 1024x768p @ 75 Hz in established timing I/II
MESS:00:00:15.944326:0: HDMI:EDID found DMT format: code 36, 1280x1024p @ 75 Hz in established timing I/II
MESS:00:00:15.953743:0: HDMI:EDID standard timings block x 8: 0x714F 8100 8140 8180 9500 950F A940 B300
MESS:00:00:15.962912:0: HDMI:EDID found DMT format: code 21, 1152x864p @ 75 Hz (4:3) in standard timing 0
MESS:00:00:15.972200:0: HDMI:EDID found DMT format: code 28, 1280x800p @ 60 Hz (16:10) in standard timing 1
MESS:00:00:15.981661:0: HDMI:EDID found DMT format: code 32, 1280x960p @ 60 Hz (4:3) in standard timing 2
MESS:00:00:15.990950:0: HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 3
MESS:00:00:16.000326:0: HDMI:EDID found DMT format: code 47, 1440x900p @ 60 Hz (16:10) in standard timing 4
MESS:00:00:16.009787:0: HDMI:EDID found DMT format: code 48, 1440x900p @ 75 Hz (16:10) in standard timing 5
MESS:00:00:16.019248:0: HDMI:EDID found DMT format: code 51, 1600x1200p @ 60 Hz (4:3) in standard timing 6
MESS:00:00:16.028625:0: HDMI:EDID found DMT format: code 58, 1680x1050p @ 60 Hz (16:10) in standard timing 7
MESS:00:00:16.039156:0: HDMI:EDID parsing v3 CEA extension 0
MESS:00:00:16.043542:0: HDMI:EDID monitor support - underscan IT formats:yes, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:1
MESS:00:00:16.055182:0: HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
MESS:00:00:16.063078:0: HDMI:EDID found CEA detail timing format: 1920x1080i @ 60 Hz (5)
MESS:00:00:16.070891:0: HDMI:EDID found CEA detail timing format: 1280x720p @ 60 Hz (4)
MESS:00:00:16.078618:0: HDMI:EDID found CEA detail timing format: 720x576p @ 50 Hz (17)
MESS:00:00:16.086341:0: HDMI:EDID found CEA detail timing format: 720x480p @ 60 Hz (2)
MESS:00:00:16.093974:0: HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz (native)
MESS:00:00:16.101609:0: HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz
MESS:00:00:16.108467:0: HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
MESS:00:00:16.115413:0: HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
MESS:00:00:16.122442:0: HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
MESS:00:00:16.129213:0: HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz
MESS:00:00:16.136072:0: HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz
MESS:00:00:16.143103:0: HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz
MESS:00:00:16.150135:0: HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
MESS:00:00:16.157166:0: HDMI:EDID found CEA format: code 33, 1920x1080p @ 25Hz
MESS:00:00:16.164197:0: HDMI:EDID found CEA format: code 34, 1920x1080p @ 30Hz
MESS:00:00:16.171248:0: HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16|20|24 bits
MESS:00:00:16.181977:0: HDMI:EDID found Video Capability DB length 2
MESS:00:00:16.188062:0: HDMI:EDID video capability: CE:3 IT:3 PT:0 QS:0
MESS:00:00:16.194390:0: HDMI:EDID found HDMI VSDB length 7
MESS:00:00:16.199606:0: HDMI:EDID HDMI VSDB has physical address 1.0.0.0
MESS:00:00:16.206025:0: HDMI:EDID HDMI VSDB supports AI:yes, dual link DVI:no
MESS:00:00:16.212892:0: HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:yes 30-bit:yes DC_yuv444:yes
MESS:00:00:16.222690:0: HDMI:EDID HDMI VSDB max TMDS clock 225 MHz
MESS:00:00:16.228590:0: HDMI:EDID HDMI VSDB has no latency information
MESS:00:00:16.234865:0: HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
MESS:00:00:16.243925:0: HDMI:EDID preferred mode remained as CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz
MESS:00:00:16.266832:0: brfs: File read: /mfs/sd/config.txt
MESS:00:00:16.270840:0: HDMI:Setting property pixel encoding to Default
MESS:00:00:16.277045:0: HDMI:Setting property pixel clock type to PAL
MESS:00:00:16.283209:0: HDMI:Setting property content type flag to No data
MESS:00:00:16.289806:0: HDMI:Setting property fuzzy format match to enabled
MESS:00:00:16.296566:0: gpioman: gpioman_get_pin_num: pin DISPLAY_SDA not defined
MESS:00:00:16.303703:0: gpioman: gpioman_get_pin_num: pin LEDS_PWR_OK not defined
MESS:00:00:16.320128:0: gpioman: gpioman_get_pin_num: pin BT_ON not defined
MESS:00:00:16.325395:0: gpioman: gpioman_get_pin_num: pin WL_ON not defined
MESS:00:00:16.364823:0: gpioman: gpioman_get_pin_num: pin LEDS_PWR_OK not defined
MESS:00:00:16.372599:0: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
MESS:00:00:16.379950:0: hdmi: HDMI:>>>>>>>>>>>>>Rx sensed, reading EDID<<<<<<<<<<<<<
MESS:00:00:16.387478:0: hdmi: HDMI:EDID version 1.3, 1 extensions, screen size 16x9 cm
MESS:00:00:16.395098:0: hdmi: HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
MESS:00:00:16.413492:0: hdmi: HDMI:EDID found preferred CEA detail timing format: 1920x1080p @ 60 Hz (16)
MESS:00:00:16.422768:0: hdmi: HDMI:EDID found CEA detail timing format: 1280x720p @ 50 Hz (19)
MESS:00:00:16.431097:0: hdmi: HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
MESS:00:00:16.440729:0: hdmi: HDMI:EDID found DMT format: code 5, 640x480p @ 72 Hz in established timing I/II
MESS:00:00:16.450365:0: hdmi: HDMI:EDID found DMT format: code 6, 640x480p @ 75 Hz in established timing I/II
MESS:00:00:16.460000:0: hdmi: HDMI:EDID found DMT format: code 8, 800x600p @ 56 Hz in established timing I/II
MESS:00:00:16.469635:0: hdmi: HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
MESS:00:00:16.479271:0: hdmi: HDMI:EDID found DMT format: code 10, 800x600p @ 72 Hz in established timing I/II
MESS:00:00:16.488993:0: hdmi: HDMI:EDID found DMT format: code 11, 800x600p @ 75 Hz in established timing I/II
MESS:00:00:16.498717:0: hdmi: HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
MESS:00:00:16.508525:0: hdmi: HDMI:EDID found DMT format: code 17, 1024x768p @ 70 Hz in established timing I/II
MESS:00:00:16.518334:0: hdmi: HDMI:EDID found DMT format: code 18, 1024x768p @ 75 Hz in established timing I/II
MESS:00:00:16.528146:0: hdmi: HDMI:EDID found DMT format: code 36, 1280x1024p @ 75 Hz in established timing I/II
MESS:00:00:16.538085:0: hdmi: HDMI:EDID standard timings block x 8: 0x714F 8100 8140 8180 9500 950F A940 B300
MESS:00:00:16.547773:0: hdmi: HDMI:EDID found DMT format: code 21, 1152x864p @ 75 Hz (4:3) in standard timing 0
MESS:00:00:16.557583:0: hdmi: HDMI:EDID found DMT format: code 28, 1280x800p @ 60 Hz (16:10) in standard timing 1
MESS:00:00:16.567565:0: hdmi: HDMI:EDID found DMT format: code 32, 1280x960p @ 60 Hz (4:3) in standard timing 2
MESS:00:00:16.577374:0: hdmi: HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 3
MESS:00:00:16.587272:0: hdmi: HDMI:EDID found DMT format: code 47, 1440x900p @ 60 Hz (16:10) in standard timing 4
MESS:00:00:16.597254:0: hdmi: HDMI:EDID found DMT format: code 48, 1440x900p @ 75 Hz (16:10) in standard timing 5
MESS:00:00:16.607236:0: hdmi: HDMI:EDID found DMT format: code 51, 1600x1200p @ 60 Hz (4:3) in standard timing 6
MESS:00:00:16.617134:0: hdmi: HDMI:EDID found DMT format: code 58, 1680x1050p @ 60 Hz (16:10) in standard timing 7
MESS:00:00:16.628185:0: hdmi: HDMI:EDID parsing v3 CEA extension 0
MESS:00:00:16.633092:0: hdmi: HDMI:EDID monitor support - underscan IT formats:yes, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:1
MESS:00:00:16.645251:0: hdmi: HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
MESS:00:00:16.653668:0: hdmi: HDMI:EDID found CEA detail timing format: 1920x1080i @ 60 Hz (5)
MESS:00:00:16.662001:0: hdmi: HDMI:EDID found CEA detail timing format: 1280x720p @ 60 Hz (4)
MESS:00:00:16.670250:0: hdmi: HDMI:EDID found CEA detail timing format: 720x576p @ 50 Hz (17)
MESS:00:00:16.678494:0: hdmi: HDMI:EDID found CEA detail timing format: 720x480p @ 60 Hz (2)
MESS:00:00:16.686648:0: hdmi: HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz (native)
MESS:00:00:16.694805:0: hdmi: HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz
MESS:00:00:16.702183:0: hdmi: HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
MESS:00:00:16.709649:0: hdmi: HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
MESS:00:00:16.717200:0: hdmi: HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
MESS:00:00:16.724492:0: hdmi: HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz
MESS:00:00:16.731872:0: hdmi: HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz
MESS:00:00:16.739423:0: hdmi: HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz
MESS:00:00:16.746975:0: hdmi: HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
MESS:00:00:16.754528:0: hdmi: HDMI:EDID found CEA format: code 33, 1920x1080p @ 25Hz
MESS:00:00:16.762079:0: hdmi: HDMI:EDID found CEA format: code 34, 1920x1080p @ 30Hz
MESS:00:00:16.769651:0: hdmi: HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16|20|24 bits
MESS:00:00:16.780902:0: hdmi: HDMI:EDID found Video Capability DB length 2
MESS:00:00:16.787507:0: hdmi: HDMI:EDID video capability: CE:3 IT:3 PT:0 QS:0
MESS:00:00:16.794355:0: hdmi: HDMI:EDID found HDMI VSDB length 7
MESS:00:00:16.800093:0: hdmi: HDMI:EDID HDMI VSDB has physical address 1.0.0.0
MESS:00:00:16.807032:0: hdmi: HDMI:EDID HDMI VSDB supports AI:yes, dual link DVI:no
MESS:00:00:16.814421:0: hdmi: HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:yes 30-bit:yes DC_yuv444:yes
MESS:00:00:16.824739:0: hdmi: HDMI:EDID HDMI VSDB max TMDS clock 225 MHz
MESS:00:00:16.831160:0: hdmi: HDMI:EDID HDMI VSDB has no latency information
MESS:00:00:16.837957:0: hdmi: HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
MESS:00:00:16.847534:0: hdmi: HDMI:EDID preferred mode remained as CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz
MESS:00:00:16.857812:0: hdmi: HDMI: hotplug attached with HDMI support
MESS:00:00:16.864075:0: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
MESS:00:00:16.875234:0: hdmi: HDMI: power_on to CEA mode 1080p60
MESS:00:00:16.882708:0: hdmi: HDMI: Action callback added to queue to happen at frame 2
MESS:00:00:16.889020:0: hdmi: HDMI: Action stop_3d_mode added to queue to happen at frame 2
MESS:00:00:16.897093:0: hdmi: HDMI: Action unmute added to queue to happen at frame 3
MESS:00:00:16.904649:0: hdmi: HDMI: Action cec_init added to queue to happen at frame 3
MESS:00:00:16.932925:0: *** Restart logging
MESS:00:00:16.935414:0: brfs: File read: 48 bytes
MESS:00:00:16.942416:0: brfs: File read: /mfs/sd/cmdline.txt
MESS:00:00:16.946404:0: Read command line from file 'cmdline.txt':
MESS:00:00:16.952280:0: 'dwc_otg.host_rx_fifo_size=256 dyndbg="module dwc_otg +p" script=http://f.maxnet.eu/scriptexecute/helloworld.sh'
MESS:00:00:16.964487:0: brfs: File read: 111 bytes
MESS:00:00:21.583108:0: brfs: File read: /mfs/sd/kernel7.img
MESS:00:00:21.587073:0: Loading 'kernel7.img' to 0x8000 size 0x4b46b0
MESS:00:00:21.593247:0: brfs: File read: 4933296 bytes
MESS:00:00:22.224336:0: brfs: File read: /mfs/sd/scriptexecute.img
MESS:00:00:22.228819:0: Loading 'scriptexecute.img' to 0x4bc6b0 size 0xa3283
MESS:00:00:22.359513:0: gpioman: gpioman_get_pin_num: pin CAMERA_0_SDA_PIN not defined
MESS:00:00:22.365730:0: gpioman: gpioman_get_pin_num: pin CAMERA_0_SCL_PIN not defined
MESS:00:00:22.373371:0: gpioman: gpioman_get_pin_num: pin CAMERA_0_I2C_PORT not defined
MESS:00:00:22.381092:0: No kernel trailer - assuming DT-capable
MESS:00:00:22.386760:0: brfs: File read: 668291 bytes
MESS:00:00:22.416007:0: brfs: File read: /mfs/sd/bcm2710-rpi-cm3.dtb
MESS:00:00:22.420667:0: Loading 'bcm2710-rpi-cm3.dtb' to 0x4bc6b0 size 0x5db7
MESS:00:00:22.560021:0: brfs: File read: 23991 bytes
MESS:00:00:22.564945:0: brfs: File read: /mfs/sd/config.txt
MESS:00:00:23.668611:0: Device tree loaded to 0x2ef55e00 (size 0x61f4)
MESS:00:00:23.674390:0: uart: Set PL011 baud rate to 103448.300000 Hz
MESS:00:00:23.681152:0: uart: Baud rate change done...
MESS:00:00:23.684585:0: uart: Baud rate change done...
MESS:00:00:25.197652:0: vchiq_core: vchiq_init_state: slot_zero = 0xfad80000, is_master = 1
MESS:00:00:25.209766:0: hdmi: HDMI:hdmi_get_state is deprecated, use hdmi_get_display_state instead
MESS:00:00:25.222846:0: TV service:host side not connected, dropping notification 0x00000002, 0x00000001, 0x00000010
and stop here.
Return to “Compute Module”
