bradwiggo
Pi Zero W media centre
Mon Aug 06, 2018 12:27 pm
Hello all,
I just ordered a Pi Zero W, and I am trying to decide which of my many project ideas to do first. One of my ideas was to set up a portable media centre by setting up the Pi as a media centre and as an access point. Is the Pi Zero Powerful enough to be used as a media centre?
The files I have are quite large. I interpolate movies before watching them so I have a few movies that run at 1080p 60fps and are about 10GB in size (for about 1 and a half hours of video). Does the pi actually do the decoding, as my phone is running VLC and is cable of decoding the videos itself.
Will5455
Re: Pi Zero W media centre
Mon Aug 06, 2018 2:17 pm
No a pi 3b (not plus) can barely run YouTube.
I do strange things and am sometimes the techhead stereotype.
deal with it!
Mon Aug 06, 2018 2:45 pm
YouTube != Media centre
All the Pi range can decode 1080p30 H264 as standard with no problem with the HW decoder, and can go up to 1080p60 on certain streams, where it will bump the clock to increase performance.
Many many people use Pi's as media centres, although they tend to use the latest model which gives a faster GUI (HW decode is the same)
bradwiggo
Mon Aug 06, 2018 2:55 pm
I just tried it on my Pi 2, and it seems to be streaming it fine. I assume if it was set up as an access point that would reduce performance, woudl it reduce it significantly?
Mon Aug 06, 2018 3:34 pm
I used to use a Pi1 (slower than a Zero) as a streaming media server using Kodi and a wifi dongle with attached USB HD. Worked fine serving up video to the children in the motorhome.
bradwiggo
Mon Aug 06, 2018 4:13 pm
Did you use the hardware decoding feature? Also was the video 60fps, as I have tried with my Pi 1 B and it is really laggy and freezes constantly.
As a side question, did you have the Pi set up as an access point, as I have been trying to do that for ages but it doesn't seem to be working.
Imperf3kt
Mon Aug 06, 2018 10:42 pm
I would have agreed with this back in 2017, but today, this is just nonsense. A Pi3b effortlessly streams Youtube.
I also watch youtube from my Pi0W just fine. It does almost max out the poor thing, but it does work.
55:55:44:44:4C
52:4C:52:42:41
Rose coloured glasses are difficult to see through.
HiassofT
Tue Aug 07, 2018 5:50 am
Have a look at LibreELEC https://libreelec.tv/
I regularly test this on a RPi (1) model B and kodi works fine.
Keep in mind though that streaming high bitrate files over Wifi can be problematic. Media on a local USB drive or using the wired ethernet connection on a RPi 1/2/3 is more stable.
so long,
Hias
Tue Aug 07, 2018 8:54 am
I was using it as a media source, so streaming to other devices, although could also be used as a player. All worked fine. Kodi uses the HW decoding, plus some software on formats that the HW doesn;t support. However, you need a beefier Pi for those ones than the Zero. Stick to H264 and you will be fine on all models.
steelo
Mon Nov 19, 2018 7:25 pm
A while back, I installed plex on my Pi3 to stream tv shows/movies/audio to Roku connected TV's. As long as it didn't have to transcode, it worked okay but the processor hovered at 50-60% the entire time. IMO, a pi zero with 1 core, opposed to 4 cores really would not be ideal. It just doesn't have the processing power and would be a frustrating experience with the user interface/GUI menus. I would imagine it would be maxed out the entire time and you'd constantly be buffering.
dom
Mon Nov 19, 2018 9:34 pm
Kodi is usable on a Pi0w: https://www.youtube.com/watch?v=Q8GZr2fyUY0
A Pi3 is a better choice and will give a smoother gui and play some more demanding video formats.
geoffpalmeruk
Wed Nov 21, 2018 10:54 am
I have used the Pi Zero (not w) as a media player for about a year now, It is a little slow through the interface (but still useable) No complaints here
Bruce Crowthorne
Sat Dec 22, 2018 7:16 pm
Sounds like the RPiZero W with VLC falls short in either network or processing power.
I have tried Stretch and VLC on a Pi3B+ (wireless) and it works fine. It is streaming video from my new Humax 5000T Freeview box which has a DLNA server capability.
When I tried a RPiZeroW also running Stretch and VLC it would run at 720p but was a bit pixellated. But at 1080P it would barely run.
Also tried a RPi3 running OSMC. It runs OK and plays fine
However, I find OSMC much less stable than Raspbian. OSMC "falls over" every few days, maybe about weekly (can be 1 day or 10 days!). Doesn't appear to be a memory leak or a storage problem, but if the system is doing much other than playing a video then it gets upset and hangs.
So I guess my lesson is that I should run at least a RPi3 with VLC and preferable a wired LAN
Anyone else have different experiences?
Bruce
gkreidl
Sat Dec 22, 2018 7:55 pm
omxplayer(GUI) runs fine on RPiZeroW (and older boards like B+).
Minimal Kiosk Browser (kweb)
Return to “Media centres”
