6by9
Re: Hardware camera sync pulses
Thu Aug 02, 2018 10:02 am
gordon77 wrote:
Thu Aug 02, 2018 8:08 am
6by9 wrote:
Mon Aug 07, 2017 4:00 pm
There have been various requests over the years for external triggers for frame synchronisation. Generally it's been stated that doing such things isn't trivial, and it wasn't. However, as of the 22nd July firmware, there is support for repurposing the camera LED GPIO to change state on frame start and frame end interrupts.....
I don't quite see how this externally triggers cameras, it appears it just shows you when a picture is being taken. Anyone got any details how it can be used to trigger cameras?
It can't be, and I don't think I've ever said it could be.
You can use it alongside the frame rate control to produce effectively a phase lock loop that will pull things in to sync over a few seconds and keep them there.
gordon77
Thu Aug 02, 2018 12:24 pm
Thanks. It looks like I misunderstood "There have been various requests over the years for external triggers for frame synchronisation."
6by9
Sun Aug 05, 2018 1:05 pm
True, I could have possibly phrased that better - now edited.
This is purely an output which synchronised with frame start/end events as received by the SoC.
Kozuch
Sat Sep 15, 2018 6:27 pm
Do the camera sync pulses also work with the very high FPS mode that user HermannSW showed in the Raw sensor access / CSI-2 receiver peripheral thread? And also here. He claims some 900-1000 FPS.
6by9
Sat Sep 15, 2018 6:53 pm
IIRC then no. They only work with the full camera stack, not rawcam/raspiraw.
Kozuch
Sat Sep 15, 2018 10:50 pm
That really is a pity. Do you think there could be a way to get the closest possible to the moment when a frame is taken in raw camera mode?
6by9
Sun Sep 16, 2018 9:25 am
I can do the same thing as for the main stack (it's less plumbing there too), although it still makes little real world sense with a rolling shutter camera where there isn't a single instant of capture.
Kozuch
Sun Sep 16, 2018 1:01 pm
Sync does make a big reason for rolling shutter, especially when combined with a special camera mode (raw in this case) which further shortens the image readout etc. (in low resolution, but that is OK for many computer vision applications). There are also moments when the shutter speed is very short and the rolling shutter is negligible (I can think of a sunny outdoor scene etc.).
ds72
Tue Oct 30, 2018 8:37 pm
fishbeetle wrote:
Tue May 15, 2018 1:23 pm
Hi There,
I'm trying to use the LED flash sync feature in continuous grab mode on a Pi3B with a v2 camera. I followed the instructions from above and was able to get the flash pulse(s) for single grabs but in continuous grab mode (with exposure_mode off) I get no pulses. Should this possible?
EDIT
Subsequently, I re-tried disable_camera_led=2 in config.txt & re-compiling an edited dt-blob file to map IO17 to camera-0-LED and it works
perfectly.
Thanks again.
Steve.
I'm a little confused here, maybe someone can clear up for me. I also have a V2 camera but there's no LED on V2. How is the signal for the LED captured if it's not on the board?
ethanol100
Wed Oct 31, 2018 1:15 pm
ds72 wrote: I'm a little confused here, maybe someone can clear up for me. I also have a V2 camera but there's no LED on V2. How is the signal for the LED captured if it's not on the board?
The LED is not captured, the camera module and the Raspberry Pi's Image Signal Processor(ISP) are communicating. The ISP now uses these information to toggle the previously defined GPIO for the camera LED. Basically when it starts receiving some data, it will say "Yes I'm getting some data lets turn on the GPIO" and when the last piece of data is received it says "This is finished now, I will turn off the GPIO again".
It was just convenient to already have defined one GPIO which is used for the LED on the camera module, which is just re-purposed for the trigger pulses. Just lighting up a LED is not very useful and you need to assign the "camera LED" pin to another GPIO, this is done using the dt-blob. Now an external thing can be connected to this newly configured GPIO and gets informed when the image is captured. This could be for example a motor which will need to move to the next frame of a film roll to digitalize the film frame by frame.
(This is simplified, as we can configure if the ISP turns the led on or off during capture...)
jyviko
Wed Nov 14, 2018 12:01 am
Hi All,
First of all, thank you for the effort making this happen!
I might have read this thread 100 times and I am still not able to get pulses from the camera. I have an RPI3+ and RPI3v1.2. I have added the following under pins_3bplus and pins_3b2, respectively, under pin_config:
[email protected] { function = "output"; termination = "no_pulling"; }; // GPU WILL USE THIS PIN FOR CAMERA 0 LED
and under pin_defines:
[email protected]_0_LED {
type = "internal";
number = <0x15>;
Should type be "external"? Moreover, should disable_camera_led in config.txt be 2 or 3? I would like to get a trigger using both the still and the video port mode.
Currently, I am planning to connect GPIO21 to GPIO20 and trigger an event once the state has changed. Is there a way to get the state of GPIO21 internally and attach a callback without connecting it to another pin?
Thank for your help and feedback
Jyviko
gordon77
Wed Nov 14, 2018 11:14 am
To use pin 18 I changed...
Lines 1226 to 1228 to
               type = "internal";
               number = <18>;
and LIne 1193 to
[email protected] { function = "output"; termination = "no_pulling"; }; // Camera LED
whether you use 2 or 3 depends which way you want the pulse to go
If 2, the camera LED GPIO will go low on a frame start, and high on frame end.
If 3, the camera LED GPIO will go high on a frame start, and low on frame end.
6by9
Wed Nov 14, 2018 12:25 pm
Don't forget to compile the dt-blob.dts file into a dt-blob.bin.
sudo dtc -I dts -O dtb -o /boot/dt-blob.bin dt-blob.dts
HermannSW
Sat Mar 09, 2019 1:12 pm
First I started with GPIO21:
[email protected]:~ $ diff dt-blob.dts dt-blob.21.dts
1362a1363
1395,1396c1396,1397
<                type = "external";
<                number = <6>;
>                type = "internal";
>                number = "<21>";
Compiling into "/boot/dt-blob.bin" resulted in many warnings, and after reboot v1 camera was not detected (vcgencmd get_camera).
Then I tried with GPIO18:
1362a1363
1395,1396c1396,1397
<                number = <6>;
>                type = "internal";
>                number = <18>;
Again many warnings during compilation, this time camera was detected after reboot, but no changes on GPIO18 can be captured with logic analyzer, although I added this to config.txt as described:
[email protected]:~ $ tail -1 /boot/config.txt
disable_camera_led property=3
There are 760 warnings during compile, so I show the 66 warnings related to 3bplus only to fit into this posting -- what do I do wrong?
[email protected]:~ $ sudo dtc -I dts -O dtb -o /boot/dt-blob.bin dt-blob.18.dts 2>&1 | grep 3bplus
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_config/[email protected] has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_config/p[email protected] has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_CONTROL_ATTACHED has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_CAMERAS has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_0_I2C_PORT has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_0_SDA_PIN has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_0_SCL_PIN has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_0_SHUTDOWN has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_0_UNICAM_PORT has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_0_LED has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_0_ENABLE has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_0_INDICATOR has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_1_ENABLE has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_1_INDICATOR has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_LOW has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_PWR_OK has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_DISK_ACTIVITY has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_RUN has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_RUN_BOOT has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_ON has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_SDA has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_SCL has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_CLK has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_LPO_CLK has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_LIMIT_1A2 has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_1V8_SEL has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected] has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_MODE has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_CARD_DETECT has a unit name, but no reg property
/boot/dt-blob.bin: Warning (unit_address_vs_reg): Node /videocore/pins_3bplus/pin_defines/[email protected]_I2C_PORT has a unit name, but no reg property
bookmark list: https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://github.com/Hermann-SW/fork-raspiraw
https://github.com/Hermann-SW/userland
https://twitter.com/HermannSW
HermannSW
Wed Mar 13, 2019 10:29 am
Can anybody please help to get this working?
The description sofar seems to be incomplete, I followed the steps and ended with errors and non-function.
gordon77
Wed Mar 13, 2019 11:18 am
Have you modified the correct lines? As far as l can see your line numbers don't agree with the ones l have shown above.
6by9
Wed Mar 13, 2019 11:30 am
The instructions were written against dtc version 1.4.0. Later versions add more error checking which is redundant in this case as we're not fully complying with DT as used by Linux.
Add -q to the dtc command line to shut up warnings.
The cleanup in https://github.com/Hexxeh/rpi-firmware/ ... 0ac3eaf2dc broke the hardware sync pulses - this is where I wish I hadn't taken the easy option out of reusing disable_camera_led.
Revert to an earlier firmware, and I'm sorting out a patch.
HermannSW
Wed Mar 13, 2019 4:30 pm
Because I had to do your edits for 3bplus section, you did for 3b section.
Now command runs without warnings.
But the change (Bump to 4.19.25) you suspect to have broken camera sync pulses is past my running version:
[email protected]:/etc $ uname -a
Linux raspberrypi3BplusX 4.14.79-v7+ #1159 SMP Sun Nov 4 17:50:20 GMT 2018 armv7l GNU/Linux
6by9
Wed Mar 13, 2019 4:58 pm
a) I'm not a mind reader and you hadn't provided that previously.
b) You want "vcgencmd version" to report the firmware version as it is a firmware change.
c) Regardless, if you haven't added disable_camera_led then it is correctly defined anyway and should turn your GPIO on/off on camera access.
HermannSW
Wed Mar 13, 2019 10:25 pm
a) sorry
b)
[email protected]:~ $ vcgencmd version
Nov  4 2018 16:35:17
Copyright (c) 2012 Broadcom
version ed5baf9520a3c4ca82ba38594b898f0c0446da66 (clean) (release)
c) I will try again, since the LED before the changes was on, I know that I had not configured disable_camera_led before the changes.
After the changes I have this per the instructions:
HermannSW
Wed Mar 13, 2019 11:15 pm
Thanks, my fault, I had to correct last line to:
disable_camera_led=3
There is a bug left, doing as shown before with GPIO21 leads again to camera not detected after reboot.
With GPIO18 all is fine and I could see camera sync signals on logic analyzer after executing this command:
$ raspivid -md 7 -w 640 -h 480 -fps 200 -o tst.h264 -pts tst.pts
The first 7 frames get captured at 40fps (preview?), then framerate is 1000/4.984=200.64fps.
I don't know whether it is a bug or feature, but without "-o" option capturing is done at 40fps the whole time.
One question to @6by9:
Length from frame start to frame end is 4.699ms, nearly the whole 4.984ms for 200fps.
Can it be that GPU has 202fps max issue because the 4.699ms do not fit into the whole frame length then anymore?
If I would provide register set for [email protected] mode for v2 camera, could you test whether GPU would work with 360fps as well?
P.S:
Maybe it is easier to use a mode similar to raspiraw 640x240 or 640x480_s tools for GPU test?
Capturing only 240 lines should tale half the 4.699ms time and easily allow for 360fps.
6by9
Thu Mar 14, 2019 11:22 am
Yes, it's a quirkiness I know of (one of the many) in raspivid that preview isn't at the specified frame rate.
The diff
diff --git a/host_applications/linux/apps/raspicam/RaspiVid.c b/host_applications/linux/apps/raspicam/RaspiVid.c
index f80ba85..5760c18 100644
--- a/host_applications/linux/apps/raspicam/RaspiVid.c
+++ b/host_applications/linux/apps/raspicam/RaspiVid.c
@@ -1631,8 +1631,8 @@ static MMAL_STATUS_T create_camera_component(RASPIVID_STATE *state)
    format->es->video.crop.y = 0;
    format->es->video.crop.width = state->common_settings.width;
    format->es->video.crop.height = state->common_settings.height;
-   format->es->video.frame_rate.num = PREVIEW_FRAME_RATE_NUM;
-   format->es->video.frame_rate.den = PREVIEW_FRAME_RATE_DEN;
+   format->es->video.frame_rate.num = state->framerate;
+   format->es->video.frame_rate.den = VIDEO_FRAME_RATE_DEN;
    status = mmal_port_format_commit(preview_port);
diff --git a/host_applications/linux/apps/raspicam/RaspiVidYUV.c b/host_applications/linux/apps/raspicam/RaspiVidYUV.c
index 93ea8fc..22ceed4 100644
--- a/host_applications/linux/apps/raspicam/RaspiVidYUV.c
+++ b/host_applications/linux/apps/raspicam/RaspiVidYUV.c
@@ -941,8 +941,8 @@ static MMAL_STATUS_T create_camera_component(RASPIVIDYUV_STATE *state)
should fix it. I'll check it and create a PR at some point.
40fps is the minimum frame rate that mode 7 is configured to run at.
HermannSW wrote:One question to @6by9:
I haven't measured with a scope as to exactly why we can't exceed 202fps in the firmware. The sensor will obviously have constraints of its own, and IIRC it just stopped sending data when I tried it.
HermannSW wrote:If I would provide register set for [email protected] mode for v2 camera, could you test whether GPU would work with 360fps as well?
P.S:
I could try a reduced resolution, higher frame rate mode in the firmware. It's not a priority though, although interesting things often get slotted into time when rebuilding kernels etc...
Kozuch
Sat Apr 06, 2019 12:11 pm
Is the current firmware already patched now or do I still need to use 1.4.0 to get the camera sync pulses?
6by9
Sat Apr 06, 2019 6:35 pm
The only issue of using a more recent version of dtc is that it reports a load of warnings. Add -q to silence those on any version of dtc.
Sync pulses should work with the current firmware.
PCHSwS
Sun Apr 28, 2019 2:58 pm
The one major proviso is that the GPIO selected MUST be one of the directly connected GPIOs on the SoC, and that is not the default situation on a Pi3 (it connects to an I2C GPIO expander).
All is not lost though, as on any Pi you can reconfigure the GPIO used for the camera LED via the dt-blob.bin file as detailed in https://www.raspberrypi.org/documentati ... uration.md and https://www.raspberrypi.org/documentati ... -camera.md.
Hi there, first of all thank you very much for the implementation of this feature! This was a thing I whished for some months ago, and now I need it again, so that comes in very handy :)
One question though. I'm working with raspi Zero W atm. dt-blob source tells me camera LED is GPIO40, and internal, so no need for reconfiguring it, if I got this right.
However, I cant find GPIO40 anywhere in the schematics, neither on the camera connector, not the Pi Board itself. Can you tell me a point where to tap into it?
Best regards
PCHSwS
Return to “Camera board”
