MaryShah
Re: Kweb Suite (Minimal Kiosk Browser, omxplayerGUI)
Wed Jul 11, 2018 7:20 pm
omxplayerGUI seems to ignore the sound output settings on the pi...
I have set audio to be redirected to my attached speaker via 3.5mm jack but the sound still comes out of the TV..
is there a way for omxplayer to honour the sound out settings on the pi?
for omxplayer I can use the below:
omxplayer -o alsa <stream>
Is there a way I can do the same with omxplayergui? In the below string format perhaps
http://localhost:9192/play?url=http://m ... mxoptions=
thanks!
gkreidl
Wed Jul 11, 2018 9:11 pm
thanks!
Yes, you can add the same options. You can also set them as default options on the settings page (in different places).
Minimal Kiosk Browser (kweb)
sgehdn
Wed Aug 01, 2018 5:45 pm
Hi, I Tried to install the kweb suite using the commands on page 1.
Trying ./debinstall I get the messagre "gdebi-core not found".
Trying to use "sudo apt-get install gdebi-core" gives me a "package gdebi-core cannot be found"
How do I get this gdebi-core to my raspi? (Raspbian)
gkreidl
Wed Aug 01, 2018 6:06 pm
It's in the repository both for Jessie and Stretch. I just checked it.
Perhaps you have a problem with a mirror.
sgehdn
Wed Aug 01, 2018 6:15 pm
How can I check if it is in my repository? Hpw can add it manually?
Best regards
gkreidl
Wed Aug 01, 2018 6:24 pm
Best regards
For Stretch:
http://archive.raspbian.net/raspbian/po ... u2_all.deb
You can download it and install it with
dpkg -i gdebi-core_0.9.5.7+nmu2_all.deb
sgehdn
Wed Aug 01, 2018 6:41 pm
Best regards
For Stretch:
Thanks.
Now I get the message that python3-debian is not installed. If I try sudo apt-get install python3-debian, I get the messager that the package is not available but is referenced by another package. .... any way to "restore" al my packages? I mean if you say that gdebi-core is in the repository. something is probaby mixed up in my system?
Regards
sgehdn
Wed Aug 01, 2018 9:20 pm
alright, I switched my system to english, and now I can copy my erro messages.
after trying to use the install command:
sudo dpkg -i gdebi-core_0.9.5.7+nmu2_all.deb
(Reading database ... 156798 files and directories currently installed.)
Preparing to unpack gdebi-core_0.9.5.7+nmu2_all.deb ...
Unpacking gdebi-core (0.9.5.7+nmu2) over (0.9.5.7+nmu2) ...
dpkg: dependency problems prevent configuration of gdebi-core:
gdebi-core depends on python3-debian; however:
Package python3-debian is not installed.
dpkg: error processing package gdebi-core (--install):
dependency problems - leaving unconfigured
Processing triggers for man-db (2.7.6.1-2) ...
Errors were encountered while processing:
and after trying to install python3_debian:
Reading package lists... Done
Building dependency tree
Package python3-debian is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'python3-debian' has no installation candidate
can anybody help how to fix this?
thanks
gkreidl
Thu Aug 02, 2018 3:49 am
thanks
Obviously your complete package management system is broken. Try the following first:
sudo apt-get update
sudo apt-get upgrade
As this is not related to kweb at all, it might be better to open a new thread for your problem.
sgehdn
Thu Aug 02, 2018 9:20 am
Update/Upgrad helped, thanks. Kweb is running now.
One quewstion: I was wondering if kweb suite could also play the videos from www.be-at.tv?
Is there any chance to make kweb play these videos?
regards
gkreidl
Thu Aug 02, 2018 9:29 am
regards
Currently not. There's no youtube-dl module which supports it.
bazzacad
Thu Aug 02, 2018 5:17 pm
I've installed Kweb 1.7.9.8 onto my Pi 3 B+. I launch it with "kweb -J" and then I go to my url. I have my page setup to auto refresh every min. It refreshes a few times & then kweb crashes/shuts down. This is all I see at the terminal. To be far, Chromium also crashes, so maybe I'm doing something wrong in my Javascript refresh code. Any suggestions...?
gkreidl
Fri Aug 03, 2018 2:45 am
The cairo (graphics) backend is crashing, which is used by both webkit (kweb) and chromium.
I have no idea about the cause.
funstuff
Thu Aug 16, 2018 8:33 pm
I get 404 error after typin: "wget http://steinerdatenbank.de/software/kweb-1.7.9.7.tar.gz"
Do I instal the jessi or stretch ?..I used noob's to install.
Thu Aug 16, 2018 8:39 pm
You should be using Raspbian Stretch as the Operating System, it has been current for 12 months now, whilst Jessie is end of life:
Update September, 22, 2017: Version 1.7.9.8 for Stretch is now available
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
gkreidl
Thu Aug 16, 2018 8:57 pm
It depends on which OS you did install using noobs. Running
cat /etc/os-release
will tell you which OS version you did install.
cyberiano
Thu Aug 23, 2018 7:53 pm
Hi
I'm having a problem with the last version of kweb for raspbian stretch.
On previous versions, launching Kweb with kweb3 command, HTML5 videos (without OMXPlayer) used to work without major issues, now in the last version HTML5 videos are not longer working.
Is there any configuration to solve this issue?
Greetings!
gkreidl
Fri Aug 24, 2018 3:25 am
Hi
Greetings!
Development of the HW accelerated GTK+3-webkit engine (used by epiphany and kweb3) has been discontinued by the Foundation and it is not available on Stretch any more. That's also the reason that there is no kweb3 any more.
Software video decoding should work though, as long as the screen area of the video is not too large (up to 480p perhaps).
MaryShah
Fri Aug 24, 2018 5:06 pm
reading back it was mentioned that if omxplayer plays the link the omxplayergui will play it
I have a link to my stream that omxplayer plays fine but omxplayergui thinks about playing it then just doesn't
How can I begin troubleshooting this?
gkreidl
Fri Aug 24, 2018 6:11 pm
Can you give a few more details?
MaryShah
Fri Aug 24, 2018 6:36 pm
I'm using
omxplayer -o local "http://dew34453x.stackpathcdn.com/<name ... ylist.m3u8"
from the terminal and it plays great I see a full screen and everything
but trying the same link using omxplayergui it doesnt play anything I see the controls appearing at the bottom then disappearing
using the below from the chromium browser
http://localhost:9192/play?url=http://d ... ylist.m3u8
bgstart server has been started as well
not sure how else to describe this really except the exact same link doesnt work in omxplayergui
I think it could be something to do with port 8080 ? I have tried playing on urls with port 8080 and they also don't play
gkreidl
Fri Aug 24, 2018 9:05 pm
I'm using
Try
http://localhost:9192/dplay?url=http:// ... ylist.m3u8
or
omxplayergui http://dew34453x.stackpathcdn.com/<name ... ylist.m3u8
play uses youtube-dl to extract the video url from a web page
dplay (direct play) uses the given URL directly.
MaryShah
Sat Aug 25, 2018 2:29 pm
No difference I'm afraid its still doesnt play
gkreidl
Sat Aug 25, 2018 6:59 pm
Without having access to the stream it's difficult for me to check what's happening.
Did you try
omxplayergui http://...
MaryShah
Mon Aug 27, 2018 1:02 pm
Yes that didnt work as well
If okay can I PM you a stream link that doesnt seem to play?
Return to “Raspberry Pi OS”
