BRUH
Re: How to setup Minecraft 1.12.1 on Raspberry Pi 3
Thu Jun 07, 2018 3:47 am
PLZ HELP WHERE DO YOU FIND /boot/config.txt :?: :?: :?:
rpiMike
Thu Jun 07, 2018 8:47 am
Under the root folder (/) there is a boot folder (/boot) which contains the file config.txt (/boot/config.txt).
From a command line window you can start Raspbians text editor (leafpad):
sudo leafpad /boot/config.txt
or use nano within the command line window:
sudo nano /boot/config.txt
BRUH
Thu Jun 07, 2018 1:31 pm
Thank you so much! :D
edit: it did not work on my Kano :(
edit 2: does not even work for the earliest version called Cave Game!
This is what it said:
Java HotSpot(TM) Client VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
Jun 07, 2018 7:46:26 AM net.minecraft.launchwrapper.LogWrapper log
INFO: Using tweak class name net.minecraft.launchwrapper.VanillaTweaker
Jun 07, 2018 7:46:29 AM net.minecraft.launchwrapper.LogWrapper log
INFO: Launching wrapped minecraft
28
Turning of ImageIO disk-caching
Loading current icons for window from: /home/Smithies/.minecraft/assets/virtual/legacy/icons/icon_16x16.png and /home/Smithies/.minecraft/assets/virtual/legacy/icons/icon_32x32.png
Java HotSpot(TM) Client VM warning: You have loaded library /home/Smithies/.minecraft/versions/b1.0/b1.0-natives-1829277381228/liblwjgl64.so which might have disabled stack guard. The VM will try to fix the stack guard now.
It's highly recommended that you fix the library with 'execstack -c <libfile>', or link it with '-z noexecstack'.
Exception in thread "Minecraft main thread" java.lang.UnsatisfiedLinkError: /home/Smithies/.minecraft/versions/b1.0/b1.0-natives-1829277381228/liblwjgl.so: /home/Smithies/.minecraft/versions/b1.0/b1.0-natives-1829277381228/liblwjgl.so: cannot open shared object file: No such file or directory (Possible cause: can't load IA 32-bit .so on a ARM-bit platform)
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1938)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1854)
at java.lang.Runtime.loadLibrary0(Runtime.java:870)
at java.lang.System.loadLibrary(System.java:1122)
at org.lwjgl.Sys$1.run(Sys.java:73)
at java.security.AccessController.doPrivileged(Native Method)
at org.lwjgl.Sys.doLoadLibrary(Sys.java:66)
at org.lwjgl.Sys.loadLibrary(Sys.java:95)
at org.lwjgl.Sys.<clinit>(Sys.java:112)
at org.lwjgl.opengl.Display.<clinit>(Display.java:135)
at net.minecraft.client.Minecraft.a(SourceFile:231)
at net.minecraft.client.Minecraft.run(SourceFile:641)
at java.lang.Thread.run(Thread.java:745)
Jun 07, 2018 7:46:31 AM net.minecraft.launchwrapper.LogWrapper log
SEVERE: Unable to launch
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at net.minecraft.launchwrapper.Launch.launch(Launch.java:57)
at net.minecraft.launchwrapper.Launch.main(Launch.java:18)
Caused by: java.lang.NoClassDefFoundError: Could not initialize class org.lwjgl.opengl.Display
at net.minecraft.launchwrapper.injector.VanillaTweakInjector.loadIconsOnFrames(VanillaTweakInjector.java:107)
at net.minecraft.launchwrapper.injector.VanillaTweakInjector.inject(VanillaTweakInjector.java:94)
at net.minecraft.client.Minecraft.main(SourceFile:1565)
... 6 more
DarkPlatinum
Contact: Website YouTube
Tue Jun 26, 2018 1:19 pm
Hi, ive had minecraft 1.12.2 optifine working. Im trying to get forge working, but getting this error
[email protected]:~/Minecraft $ ./runForge1.12.sh
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0curl: (6) Could not resolve host: authserver.mojang.com
todays access token =
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0curl: (6) Could not resolve host: api.mojang.com
MINECRAFT_UUID=
Exception in thread "main" joptsimple.OptionMissingRequiredArgumentException: Option tweakClass requires an argument
	at joptsimple.RequiredArgumentOptionSpec.detectOptionArgument(RequiredArgumentOptionSpec.java:48)
	at joptsimple.ArgumentAcceptingOptionSpec.handleOption(ArgumentAcceptingOptionSpec.java:257)
	at joptsimple.OptionParser.handleLongOptionToken(OptionParser.java:513)
	at joptsimple.OptionParserState$2.handleArgument(OptionParserState.java:56)
	at joptsimple.OptionParser.parse(OptionParser.java:396)
	at net.minecraft.launchwrapper.Launch.launch(Launch.java:50)
	at net.minecraft.launchwrapper.Launch.main(Launch.java:28)
how do i fix this?
1 * Raspberry Pi Zero W, 1 * Raspberry Pi 2, 1 * Raspberry Pi 3 1 * Raspberry Pi 3B + :mrgreen:
Check Out My Raspberry Site (Run on a Raspberry Pi 3B :) ): https://html.dynu.net
DarkPlatinum
Tue Jun 26, 2018 6:00 pm
MINECRAFT_UUID=
how do i fix this?
Very happy to say i got forge working. Had to add
TWEAK_CLASS=net.minecraftforge.fml.common.launcher.FMLTweaker
thanks for making this happen!
emiru
Wed Jun 27, 2018 6:37 pm
HELP!!!Please i have raspberry pi 3 model b ITS TYPES:
[15:36:16] [main/INFO]: Loading tweak class name optifine.OptiFineTweaker
[15:36:16] [main/INFO]: Using primary tweak class name optifine.OptiFineTweaker
[15:36:16] [main/INFO]: Calling tweak class optifine.OptiFineTweaker
OptiFineTweaker: acceptOptions
OptiFineTweaker: injectIntoClassLoader
OptiFine ClassTransformer
OptiFine ZIP file: /home/pi/.minecraft/libraries/optifine/OptiFine/1.12.1_HD_U_C7/OptiFine-1.12.1_HD_U_C7.jar
OptiFineTweaker: getLaunchArguments
OptiFineTweaker: getLaunchTarget
[15:36:17] [main/INFO]: Launching wrapped minecraft {net.minecraft.client.main.Main}
Java HotSpot(TM) Client VM warning: You have loaded library /home/pi/.minecraft/versions/1.12.1-OptiFine_HD_U_C7/1.12.1-OptiFine_HD_U_C7-natives-1868943847705/liblwjgl64.so which might have disabled stack guard. The VM will try to fix the stack guard now.
[15:36:18] [main/ERROR]: Unable to launch
java.lang.reflect.InvocationTargetException: null
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_65]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_65]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_65]
at java.lang.reflect.Method.invoke(Method.java:497) ~[?:1.8.0_65]
at net.minecraft.launchwrapper.Launch.launch(Launch.java:135) [launchwrapper-1.12.jar:?]
at net.minecraft.launchwrapper.Launch.main(Launch.java:28) [launchwrapper-1.12.jar:?]
Caused by: java.lang.UnsatisfiedLinkError: /home/pi/.minecraft/versions/1.12.1-OptiFine_HD_U_C7/1.12.1-OptiFine_HD_U_C7-natives-1868943847705/liblwjgl.so: /home/pi/.minecraft/versions/1.12.1-OptiFine_HD_U_C7/1.12.1-OptiFine_HD_U_C7-natives-1868943847705/liblwjgl.so: невозможно открыть разделяемый объектный файл: Нет такого файла или каталога (Possible cause: can't load IA 32-bit .so on a ARM-bit platform)
at java.lang.ClassLoader$NativeLibrary.load(Native Method) ~[?:1.8.0_65]
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1938) ~[?:1.8.0_65]
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1854) ~[?:1.8.0_65]
at java.lang.Runtime.loadLibrary0(Runtime.java:870) ~[?:1.8.0_65]
at java.lang.System.loadLibrary(System.java:1122) ~[?:1.8.0_65]
at org.lwjgl.Sys$1.run(Sys.java:72) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:1.8.0_65]
at org.lwjgl.Sys.doLoadLibrary(Sys.java:66) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at org.lwjgl.Sys.loadLibrary(Sys.java:96) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at org.lwjgl.Sys.<clinit>(Sys.java:117) ~[lwjgl-2.9.4-nightly-20150209.jar:?]
at bib.I(SourceFile:2825) ~[bib.class:?]
at net.minecraft.client.main.Main.main(SourceFile:38) ~[Main.class:?]
... 6 more
DarkPlatinum
Wed Jun 27, 2018 7:05 pm
So as I said I got forge working. It is working with mods n such but it is not outputting sound. In terminal it is saying missing sound for the audio.soundmanager
Sumie
Fri Jun 29, 2018 4:16 pm
Anyone else seeing lots of flickering while playing now (in the ESC menu, or inventory)? It's been happening for a few months with newer images/updates. It happens more severely at higher resolutions or with higher view distance so I imagine it has to do with the Ram utilization, but I have the GPU ram upto 256mb. It was working great with 192mb at the start of the year.
Happens on both my Pi3 and Pi3Bplus.
I'm downloading the new June image right now to apply it to see if the same thing is going on, but I imagine it is.
mrtumnus
Fri Jun 29, 2018 4:18 pm
Tested this tutorial successfully with the latest release, Minecraft/OptiFine 1.12.2. Thanks!!
EDIT: To connect to my server, I had to explicitly specify the port #. I'm using the default minecraft server port, but I guess it's required. Probably not a rpi-specific thing.
DarkPlatinum
Fri Jun 29, 2018 10:37 pm
Yes, using f11 makes it flicker for some reason. To prevent this I just use full screen from the minecraft application bar.
Sumie
Wed Jul 11, 2018 9:50 pm
It's freakin' irritating. I'm using the script to start Minecraft outside of the GUI to squeeze a bit more performance out of it, so non-full-screen is not really an option in my mind. ;)
("startx ./Minecraft/runOptifine1_12_1.sh" from the command line for those interested. I use a composite cable to use the lowest possible resolution too, looks and works great on tube TVs... besides the flickering)
GarretteO
Mon Jul 16, 2018 9:17 pm
I did everything correctly for version 1.12.1, but when I put in ./runOptifine1_12_1.sh, the game just crashes. Please help!
rpiMike
Tue Jul 17, 2018 8:59 am
What error do you get ?
BilyBob333
Tue Jul 17, 2018 6:49 pm
On steps 8 and 9, the guide says to download files from <URL url="https://www.dropbox.com">https://www.dropbox.com</URL>. Why is this necessary? can't lwjgl be download from the official source? Is the version that the guide says to download modified to work on a Raspberry pi? Also, what about the launcher? The download link on Minecraft.net does not redirect to s3.amazonaws.com anymore? Isn't this a security issue?
rpiMike
Tue Jul 17, 2018 7:23 pm
I've rebuilt lwjgl for the arm processor - thats why its downloaded from my dropbox. You can try and re-build it yourself.
Minecraft is now owned by Microsoft, I would imagine thats why its not on an amazon server!
Sumie
Thu Jul 19, 2018 4:42 pm
Small update, I changed from using FakeKMS to FullKMS and the flickering is gone. I had always used FakeKMS because it just seemed to work better for me for most things, but now I'm really liking how FullKMS is working for me. It had been a while since I tried it so updates and fixes may have been applied since I last tried it so moving forward, FullKMS seems like the better option.
Anyone else want to help me confirm this?
EDIT: Another small update, I tried my composite cable with FullKMS and it just displays a blank screen. I remember it working with either mode a while back so again, not sure what changed. I have tried forcing NTSC on my sdtv output but no luck. I just want my FullKMS to work with Composite :(
Sumie
Thu Jul 19, 2018 4:44 pm
You say that, but the process still works for me (just did it again on another PI about a week ago). Show us the error you're seeing after the crash and we'll be able to help you better.
Logan M
Mon Jul 23, 2018 9:13 pm
Hey I don't know what I did wrong but when I try to use step 14 to open runoptifine (which I edited) it says permission denied any help would be nice.
rpiMike
Tue Jul 24, 2018 12:22 am
Maybe the last part of step 12 didn’t complete:
sudo chmod +x runOptifine1_12_1.sh
leafs444
Sun Jul 29, 2018 8:47 pm
I made a installer script for the whole process. rpiMike you can update the forum with it if you want. :D
do this in terminal: git clone https://github.com/Minecraft1-12-2Pi/Mi ... 1.12.2.git
leafs444
Mon Jul 30, 2018 8:48 pm
I am working on a installer for forge1.12.2 as well, will be out later today.
leafs444
Tue Jul 31, 2018 7:08 pm
UPDATE: The forge installer failed, will try again maybe?? I will need to rebuild it for ARM.
I also made a new post for my new installer. View it here: viewtopic.php?f=78&t=219438
DarkPlatinum
Fri Aug 17, 2018 7:46 pm
As i stated sometime ago, I got the forge installer working. In the minecraft launcher just look for the cp thingy and paste like what @rpiMike said in the tutorial. The only draw back i had is that i cant get sound.
unclebod
Sat Aug 18, 2018 12:04 pm
That script takes some time to run for me.... (OK, it starts with a system upgrade, so that could explain the time it takes)
Also, it is hardcoded about where in the directory tree the Minecraft1.12.2 folder is. Not the best to do...
After placing it in the correct place, I've found at least two bugs in the script:
The optifine it downloads is not correctly moved do Downloads
It installs 1.12.1 version of optifine
I'm going to do the 1.12.2 install manual, I think...
Could you please update the readme with eaxtly what it installs?
leafs444
Sat Sep 08, 2018 3:27 am
It's still in beta testing. What do you mean by "Could you please update the readme with exactly what it installs?"? Also, if you'd like to work with me on this, I'm open.
[email protected]
Return to “Gaming”
