However, with current Rasbian (4.14.50) if I connect an official screen, it works fine - but i cannot see any entries in the Device Tree to make it work. There is also no module listed by lsmod - so I am more than a little puzzled. I think somehow it must all now be buried somewhere in the firmware. [An explanation of why this is and how the official screen DT/driver works would be helpful - I think it has changed from earlier releases].
I have been trying to follow Eric Anholt's helpful page at https://github.com/anholt/linux/wiki/Ra ... lay-panels.
So I have made a modified version of panel-raspberrypi-toucscreen.c which complies and loads OK.
It has the element { .compatible = "creative,lvds-bridge-i2c" }, in the of_device_id struct.
This matches the compatible= element in the flattened device tree:
i2cdsi {
gpios = <0x10 0x2c 0x0 0x10 0x2d 0x0>;
compatible = "i2c-gpio";
status = "okay";
#address-cells = <0x1>;
#size-cells = <0x0>;
phandle = <0x73>;
[email protected] {
compatible = "creative,lvds-bridge-i2c";
phandle = <0x78>;
reg = <0x2c>;
port {
endpoint {
remote-endpoint = <0x7a>;
phandle = <0x79>;
There is also the following element under dsi1:
port {
endpoint {
remote-endpoint = <0x79>;
phandle = <0x7a>;
The problem I have is that - so far as I can tell - whilst the module is loading on boot-up (being shown in lsmod), and sitting above drm as expected -the module's 'probe' callback does not appear to be being called.
I say this because:
a) dmesg shows "[ 14.145100] bus: 'mipi-dsi': add driver panel-texas-sn65dsi83,
but then nothing else
b) printk's in the probe function are not firing
c) whilst the i2cbus is being 'poked' by the kernel module for the Goodix touch overlay driver chip, there is no activity on the 2C address configured for the DSI bridge chip (so I know I'm driving the right i2c bus) [Determined using an I2C bus analyser]
d) the DSI clock a data lane outputs are not firing up [determined with a 'scope].
If I remove the module then re-insert it using modprobe I see:
[email protected]:/home/kdev# lsmod
Module Size Used by
fuse 106496 3
cmac 16384 1
rfcomm 77824 6
bnep 24576 2
hci_uart 45056 1
btbcm 16384 1 hci_uart
serdev 20480 1 hci_uart
bluetooth 536576 29 hci_uart,bnep,btbcm,rfcomm
ecdh_generic 28672 1 bluetooth
panel_texas_sn65dsi83 16384 0
vc4 151552 0
drm_kms_helper 184320 1 vc4
drm 385024 3 panel_texas_sn65dsi83,vc4,drm_kms_helper
i2c_gpio 16384 0
i2c_algo_bit 16384 1 i2c_gpio
snd_soc_core 204800 1 vc4
snd_compress 24576 1 snd_soc_core
snd_pcm_dmaengine 16384 1 snd_soc_core
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
fb_sys_fops 16384 1 drm_kms_helper
brcmfmac 307200 0
brcmutil 20480 1 brcmfmac
cfg80211 581632 1 brcmfmac
snd_bcm2835 32768 1
rfkill 28672 6 bluetooth,cfg80211
snd_pcm 98304 4 vc4,snd_pcm_dmaengine,snd_bcm2835,snd_soc_core
snd_timer 32768 1 snd_pcm
snd 69632 7 snd_compress,snd_timer,snd_bcm2835,snd_soc_core,snd_pcm
fixed 16384 0
uio_pdrv_genirq 16384 0
uio 20480 1 uio_pdrv_genirq
i2c_dev 20480 0
ip_tables 24576 0
x_tables 36864 1 ip_tables
ipv6 446464 26
[email protected]:/home/kdev# rmmod panel_texas_sn65dsi83
[email protected]:/home/kdev# modprobe -vvv panel_texas_sn65dsi83
modprobe: INFO: ../libkmod/libkmod.c:364 kmod_set_log_fn() custom logging function 0x19778 registered
modprobe: DEBUG: ../libkmod/libkmod-index.c:755 index_mm_open() file=/lib/modules/4.14.50-v7-CM+/modules.dep.bin
modprobe: DEBUG: ../libkmod/libkmod-index.c:755 index_mm_open() file=/lib/modules/4.14.50-v7-CM+/modules.alias.bin
modprobe: DEBUG: ../libkmod/libkmod-index.c:755 index_mm_open() file=/lib/modules/4.14.50-v7-CM+/modules.symbols.bin
modprobe: DEBUG: ../libkmod/libkmod-index.c:755 index_mm_open() file=/lib/modules/4.14.50-v7-CM+/modules.builtin.bin
modprobe: DEBUG: ../libkmod/libkmod-module.c:556 kmod_module_new_from_lookup() input alias=panel_texas_sn65dsi83, normalized=panel_texas_sn65dsi83
modprobe: DEBUG: ../libkmod/libkmod-module.c:562 kmod_module_new_from_lookup() lookup modules.dep panel_texas_sn65dsi83
modprobe: DEBUG: ../libkmod/libkmod.c:574 kmod_search_moddep() use mmaped index 'modules.dep' modname=panel_texas_sn65dsi83
modprobe: DEBUG: ../libkmod/libkmod.c:402 kmod_pool_get_module() get module name='panel_texas_sn65dsi83' found=(nil)
modprobe: DEBUG: ../libkmod/libkmod.c:410 kmod_pool_add_module() add 0xd9b080 key='panel_texas_sn65dsi83'
modprobe: DEBUG: ../libkmod/libkmod.c:402 kmod_pool_get_module() get module name='drm' found=(nil)
modprobe: DEBUG: ../libkmod/libkmod.c:410 kmod_pool_add_module() add 0xd9b3a0 key='drm'
modprobe: DEBUG: ../libkmod/libkmod-module.c:196 kmod_module_parse_depline() add dep: /lib/modules/4.14.50-v7-CM+/kernel/drivers/gpu/drm/drm.ko
modprobe: DEBUG: ../libkmod/libkmod-module.c:202 kmod_module_parse_depline() 1 dependencies for panel_texas_sn65dsi83
modprobe: DEBUG: ../libkmod/libkmod-module.c:583 kmod_module_new_from_lookup() lookup panel_texas_sn65dsi83=0, list=0xd9b258
modprobe: DEBUG: ../libkmod/libkmod.c:501 lookup_builtin_file() use mmaped index 'modules.builtin' modname=panel_texas_sn65dsi83
modprobe: DEBUG: ../libkmod/libkmod-module.c:1748 kmod_module_get_initstate() could not open '/sys/module/panel_texas_sn65dsi83/initstate': No such file or directory
modprobe: DEBUG: ../libkmod/libkmod-module.c:1758 kmod_module_get_initstate() could not open '/sys/module/panel_texas_sn65dsi83': No such file or directory
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=snd_pcsp mod->name=drm mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=snd_usb_audio mod->name=drm mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=cx88_alsa mod->name=drm mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=snd_atiixp_modem mod->name=drm mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=snd_intel8x0m mod->name=drm mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=snd_via82xx_modem mod->name=drm mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=8250 mod->name=drm mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=bcm2708_fb mod->name=drm mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=vc_mem mod->name=drm mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=dwc_otg mod->name=drm mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=fsck mod->name=drm mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod.c:501 lookup_builtin_file() use mmaped index 'modules.builtin' modname=drm
modprobe: DEBUG: ../libkmod/libkmod-module.c:1304 kmod_module_probe_insert_module() Ignoring module 'drm': already loaded
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=snd_pcsp mod->name=panel_texas_sn65dsi83 mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=snd_usb_audio mod->name=panel_texas_sn65dsi83 mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=cx88_alsa mod->name=panel_texas_sn65dsi83 mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=snd_atiixp_modem mod->name=panel_texas_sn65dsi83 mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=snd_intel8x0m mod->name=panel_texas_sn65dsi83 mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=snd_via82xx_modem mod->name=panel_texas_sn65dsi83 mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=8250 mod->name=panel_texas_sn65dsi83 mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=bcm2708_fb mod->name=panel_texas_sn65dsi83 mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=vc_mem mod->name=panel_texas_sn65dsi83 mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=dwc_otg mod->name=panel_texas_sn65dsi83 mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod-module.c:1391 kmod_module_get_options() modname=fsck mod->name=panel_texas_sn65dsi83 mod->alias=(null)
modprobe: DEBUG: ../libkmod/libkmod-module.c:744 kmod_module_get_path() name='panel_texas_sn65dsi83' path='/lib/modules/4.14.50-v7-CM+/kernel/drivers/gpu/drm/panel/panel-texas-sn65dsi83.ko'
insmod /lib/modules/4.14.50-v7-CM+/kernel/drivers/gpu/drm/panel/panel-texas-sn65dsi83.ko
modprobe: DEBUG: ../libkmod/libkmod-module.c:468 kmod_module_unref() kmod_module 0xd9b080 released
modprobe: DEBUG: ../libkmod/libkmod.c:418 kmod_pool_del_module() del 0xd9b080 key='panel_texas_sn65dsi83'
modprobe: DEBUG: ../libkmod/libkmod-module.c:468 kmod_module_unref() kmod_module 0xd9b3a0 released
modprobe: DEBUG: ../libkmod/libkmod.c:418 kmod_pool_del_module() del 0xd9b3a0 key='drm'
modprobe: INFO: ../libkmod/libkmod.c:331 kmod_unref() context 0xd9a178 released
I should add that my config.text includes "ignore_lcd=1" and "disable_touchscreen=1", as I assume these are necessary to 'release' the i2c bus on the DSI connector from being controlled by the firmware.
Also, is there a way of getting the kernel to report details of probing activity (I am using a kernel configured for "maximum smoke" on the debug front - still nothing - really struggling to get printk() to work)
Is there a helpful soul who can help me identify what I've missed?
I'd be most grateful for some guidance!
Chris
