Hi friends!
I have the Raspberry PI 3 B+.
I can't connect it whith TV via A/V output. There isn't a picture on TV.
I bought cable for MP3 player and little modified it like on schema on internet. Multimeter test is OK.
Maybe I should edit some setings on device?
Help me please.
- DougieLawson
- Contact: Website Twitter
Re: A/V connection problem
https://www.raspberrypi-spy.co.uk/2014/ ... ideo-jack/
What's your TV standard? The default if you add nothing to /boot/config.txt is that the AV video is NTSC 60Hz 480i.
I followed this instruction.DougieLawson wrote: ↑Fri Jun 29, 2018 11:06 amhttps://www.raspberrypi-spy.co.uk/2014/ ... ideo-jack/
And how can I find standard of my TV? It's model LG 21FS2CG-TS
- DougieLawson
What country are you in?
add
That sets it to PAL 50Hz 576i 4:3.
add
sdtv_mode=2
sdtv_aspect=1
serozhax wrote: ↑Fri Jun 29, 2018 11:36 amI followed this instruction.DougieLawson wrote: ↑Fri Jun 29, 2018 11:06 amhttps://www.raspberrypi-spy.co.uk/2014/ ... ideo-jack/
SDTV Modes
https://www.raspberrypi.org/documentati ... t/video.md
I'm from RussiaDougieLawson wrote: ↑Fri Jun 29, 2018 12:21 pmWhat country are you in?
addThat sets it to PAL 50Hz 576i 4:3.Code: Select all
sdtv_mode=2 sdtv_aspect=1
Russia choose to follow France and use SECAM. However most TVs that can decode SECAM also decode PAL.
In any case, it is extremely rare that the wrong* setting of sdtv_mode in config.txt will of itself be the reason for nothing appearing on a TV screen.
(* Even 525/625)
(* Even 525/625)
serozhax wrote: ↑Fri Jun 29, 2018 7:57 amHi friends!
Help me please.
Cable issue ???
Or need to force composite output disabling HDMI.
From wikipedia Russia use Secam as ATV color system. But, LG TV also is compatible with PAL.
hdmi_ignore_hotplug=1
1. Is the RPi actually booting?
2. Ensure nothing is plugged in to the RPi's HDMI socket when powering up.
3. What OS is on the card? Has NOOBS been used?
1. I have updated system today.
2. Nothing is plugged in to the RPi's HDMI socket.
3. OS Raspbian. Installed without NOOBS.
Maybe there is cable issue... But I checked it for many times...
1 - Video
2 - Ground
3 - Right Audio
4 - Left Audio
TVs can often automatically switch between PAL and SECAM.
But even if the PAL/SECAM setting is not correct you would get a black and white display.
You did not confirm that the RPi is booting.
IT WORKS!!!! Thank you!!!
P.S. If i want connect HDMI must I change this setting?
- Contact: Website
When using the default settings of Raspbian (Not NOOBS), the RPi will automatically use HDMI if connected at boot. If no HDMI is connected then the RPi will automatically switch to composite (AV) on boot.
You only need to change the setting for PAL:
sdtv_mode=2
