rishitghosh
7 segment 4 digit display - python code
Fri May 25, 2018 2:58 pm
Can you point me to a link which has a 7 segment 4 digit python code with the appropriate connections in Raspberry pi 3?
I found a link on the internet which has the code and the connections, but the connections is for pi 2 (which has 26 pins) . So , can you provide me the pin mapping for pi 2 to pi 3?
Re: 7 segment 4 digit display - python code
Fri May 25, 2018 3:01 pm
rishitghosh
Fri May 25, 2018 4:09 pm
The link which you gave has a raspberry pi which has 26 pins, but my raspberry pi 3 has 40 pins . So , can you provide me with the pin mapping for pi 2(26 pins ) to pi 3 ?
DirkS
Fri May 25, 2018 6:13 pm
First 26 pins are the same, so you can use the same pins as in that topic.
Fri May 25, 2018 8:18 pm
To add to Dirk's answer.
https://pinout.xyz
rishitghosh
Sat May 26, 2018 4:05 am
Thanks a lot "Dirks" , I will try this out.
rishitghosh
Sat May 26, 2018 4:10 am
https://pinout.xyz
This is extremely helpful , Thank you .
Return to “Python”
