funstuff
how to run and install TeamVewer on old Pi Zero ?
Mon May 21, 2018 8:16 pm
Hi all
Can old pi zero rune TeamVewer ? And If any know how to install it plz let me know.
drgeoff
Re: how to run and install TeamVewer on old Pi Zero ?
Mon May 21, 2018 8:27 pm
Yes, but to connect a network interface (ethernet or Wi-Fi), a keyboard and possibly a mouse you will need a USB hub. From there on it isn't really any different from installing and using TeamViewer on any variety of B model RPi.
funstuff
Wed May 23, 2018 4:12 am
ya I have a hube/motorola phone doce..
Wed May 23, 2018 5:35 am
Hi all
https://community.teamviewer.com/t5/Kno ... /ta-p/6318
ARMv7 Architecture supported, the Zero is ARMv6..
Retired disgracefully.....
funstuff
Wed May 23, 2018 8:30 pm
Hi all
so no the zero cant run temvewer ?
drgeoff
Wed May 23, 2018 10:34 pm
Hi all
From the already linked page https://community.teamviewer.com/t5/Kno ... /ta-p/6318
Machine requirements
x86 64 bit: amd64 (Intel 64/EM64T)
x86 32 bit: SSE2
armv7 32 bit: armv7 hardfloat (Raspberry Pi 2+)
HawaiianPi
Thu May 24, 2018 10:46 am
The Pi Zero can run a VNC server (which is included with Desktop versions of Raspbian), and you can use the free RealVNC viewer to get remote desktop control of Raspbian. https://www.realvnc.com/en/connect/download/viewer/
You can run the Pi0 headless with USB Gadget mode, or cut the cord with a Raspbian compatible USB WiFi dongle. I have done both.
For wireless access I use a pcDuino USB WiFi dongle I got from Amazon for $4 with a tiny OGT adapter that fits inside the plug.
By placing a file named "ssh" (or ssh.txt) and a properly configured wpa_supplicant.conf file on the small FAT32 "boot" partition of a Raspbian imaged SD card, the Pi0 will boot up with SSH enabled and connect to my wireless network. I can then login with SSH and use the configuration utility to enable the VNC server.
If there is some specific reason you need Team Viewer then it seems like you are out of luck. However, if all you really want is remote desktop control of your Raspberry Pi Zero computer, RealVNC will do that. If you think RealVNC will work for you, then check out this other post of mine for more detailed instructions. viewtopic.php?p=1318257#p1318257
Return to “Beginners”
