#!/usr/bin/python
import spidev
import RPi.GPIO as GPIO
import time
import os
# GPIO setup
GPIO.setmode (GPIO.BCM)
GPIO.setwarnings(False)
switch = 18
GPIO.setup(switch, GPIO.IN)
#Define Variables
delay = 0.5
#Create SPI
spi = spidev.SpiDev()
spi.open(0, 0)
spi.max_speed_hz=1000000
def readadc(adcnum):
# read SPI data from the MCP3008, 8 channels in total
if adcnum > 7 or adcnum < 0:
return -1
r = spi.xfer2([1, 8 + adcnum << 4, 0])
data = ((r[1] & 3) << 8) + r[2]
return data
print('Reading MCP3008 values, press Ctrl-C to quit...')
# Print nice channel column headers.
print('| {0:>4} | {1:>4} | {2:>4} | {3:>4} | {4:>4} | {5:>4} | {6:>4} | {7:>4} |'.format(*range(8)))
print('-' * 57)
# Main program loop.
while True:
# Read all the ADC channel values in a list.
values = [0]*8
for i in range(8):
# The read_adc function will get the value of the specified channel (0-7).
values[i] = readadc(i) + "n"
# Print the ADC values.
print('| {0:>4} | {1:>4} | {2:>4} | {3:>4} | {4:>4} | {5:>4} | {6:>4} | {7:>4} |'.format(*values))
# Pause for one second.
time.sleep(1)
while GPIO.input(switch) == 0:
time.sleep (0.5)
# write results data to file
with open("/home/pi/data_log.csv", "a") as file:
if os.stat("/home/pi/data_log.csv").st_size == 0:
file.write("readadc(i)\"n")
file.write(results)
# if sensors write to file to often increase this time
time.sleep (2)
#KeyboardInterrupt:
print("keyboard interrupt detected, File closed")
file.close()
eError: unsupported operand type(s) for +: 'int' and 'str'
