peggyopal
Pi3B+ crontab not running raspistill
Fri May 11, 2018 8:40 pm
I have a script that is run as a cron job
(crontab -l 2>/dev/null; echo "@reboot /home/pi/PicsOnSticks/picScript.sh") | crontab -
The script runs perfectly, with one exception, it doesn't take a picture (which is its one goal in "life".)
This script has been successfully taking photos on RPi0s and RPi3Bs but it's not working on RPi3B+s, did something change that I'm missing?
Edit: The script takes a photo and stores it in a directory so it can be analyzed at a later time. Also, I'm using Stretch.
peggyopal
Re: Pi3B+ crontab not running raspistill
Wed May 16, 2018 3:05 pm
Figured it out.
The script is running from
crontab -e
and
sudo crontab -e
This is causing the script to be called twice and the photo is failing because the camera is trying to take two photos at the same time.
n67
Wed May 16, 2018 3:14 pm
Two commands you should never, ever, ever, ever execute:
1) sudo rm -rf /
2) sudo crontab -e
"L'enfer, c'est les autres"
G fytc hsqr rum umpbq rm qyw rm rfc kmbq md rfgq dmpsk:
Epmu Sn!
J lnacjrw njbruh-carppnanm vxm rb mnuncrwp vh yxbcb!
peggyopal
Wed May 16, 2018 3:20 pm
2) sudo crontab -e
I didn't execute that ¯\_(ツ)_/¯ but good to know, thank you! I'll make sure that
crontab -e
is the one running the script. Is there a reason that's preferred over sudo?
RaTTuS
Wed May 16, 2018 3:33 pm
sudo crontab -e
edits the cron for the root user
crontab -e
edits the cron for the current user
Covfefe
peggyopal
Wed May 16, 2018 3:40 pm
Okay, but is there a reason that editing the current user is preferred over editing the root user?
Wed May 16, 2018 10:04 pm
If the script you're running from cron doesn't need elevated privileges then don't run it from the root crontab. Don't use sudo when you don't need it. Don't run as root when you don't need it. That's part of Linux Security 101.
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
n67
Wed May 16, 2018 10:42 pm
That's half of the answer - and the most important half. Since nothing in this current thread requires root privs to run, there is, of course, no reason to run it as root.
The other half is that if you do need root privs in a cron job, then there are two ways to do it:
1) Put it in root's crontab - now you have two things to keep track of - which leads to confusion as we see this thread. Don't do this!
2) Put it in pi's crontab - and use 'sudo' like you normally do when you need to run stuff as root when running on the Pi.
Note: Yes. I am assuming the default configuration with "passwordless" sudo. If, as many of the big time forum posters do, you remove "passwordless" sudo, then this changes (and in that case, you ought to know what you are doing). But in the default config, it is better to keep everything in a single file. As already mentioned, this keeps things simple and trackable - and avoids the confusion that caused the problem in this thread.
Epmu Sn!
