dcaccount
Log file monitoring
Sat May 05, 2018 8:18 pm
Is there a way to continuously monitor a log file and to trigger an action, for instance send an email, upon detecting any change?
Thnaks,
Dan
droleary
Contact: Website Skype
Re: Log file monitoring
Sun May 06, 2018 2:54 am
There are many ways to do that. If you want some pre-packaged software to do something specific, please say exactly what it is you wish to accomplish. For example, you might use fail2ban if you want to keep out attackers.
maurice1
Sun May 06, 2018 1:19 pm
Hi Dan,
Script below checks if a file time stamp has updated in the last 10 minutes and sends an email if it hasn't
Script is called by cron
Is that the sort of thing you are looking for?
#!/usr/bin/python
import os
from datetime import datetime, timedelta
file_name = "/var/1w_files/test"
file_mod_time = datetime.fromtimestamp(os.stat(file_name).st_mtime)  # This is a datetime.datetime object!
print"file_mod_time", file_mod_time
now = datetime.today()
print"now", now
max_delay = timedelta(minutes=10)
print"max_delay", max_delay
if now-file_mod_time > max_delay:
    print "CRITICAL: {} last modified on {}. Threshold set to {} minutes.".format(file_name, file_mod_time, max_delay.seconds/60)
    os.system ( "echo 1w_Update Problem | mail -s CS450 [email protected]" )
else:
    print "OK. Command completed successfully {} minutes ago.".format((now-file_mod_time).seconds/60)
print "########DONE   ##############-"
dcaccount
Mon May 07, 2018 11:06 am
Hi Dan,
#!/usr/bin/python
import os
print"now", now
else:
YES!
Thanks a lot,
dan
Return to “Raspbian”
