MatsK007
Headless system - Post install script
Tue Aug 15, 2017 10:43 pm
Now when we have /boot/ssh and /boot/wpa_supplicant.conf it's possible to get a Raspberry Pi up and running and reachable via WiFi and SSH.
I would like to promote the idea that a "Post install script" that is executed at first boot would be a nice idea and save a lot of manual work for headless deployment.
But perhaps I am proposing a idea that is there already?
Re: Headless system - Post install script
Wed Aug 16, 2017 9:17 am
SSH was specifically disabled for security reasons: https://www.raspberrypi.org/blog/a-secu ... ian-pixel/
How can one read the "post install script" if the RPi is headless ??
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
B.Goode
Wed Aug 16, 2017 9:41 am
It isn't clear to me what you are proposing, but maybe PINN viewtopic.php?f=63&t=142574 or PiBakery http://www.pibakery.org would meet your needs?
chrisoh
Wed Aug 16, 2017 10:27 am
Seems MatsK007 is wanting something similar to the ssh and wpa_supplicant.conf files, in that you drop a file named post-install.sh into the /boot dir and Raspbian will automatically copy it over and exec the script on first boot. A simple use case being that you would be able to pre designate a hostname in post-install.sh and it'll be auto configured.
I can see why it'd be useful, as /boot is the only commonly accessible dir yet you can only auto configure ssh and network currently.
Some previous discussion: viewtopic.php?p=297884
Another request: viewtopic.php?t=167544&p=1077846
Similar request: viewtopic.php?t=189676&p=1192668
Coffee's ready...
Raspberry Pi 3 model B Idle @ 250mA
  • HDMI +200mA
  • Minecraft 1.9 Server +100mA
  • 2.4Ghz dongle +20mA
procount
Wed Aug 16, 2017 2:23 pm
To run a post-install script, there must be some standard way of calling this script on first boot.
Most standard OSes, including Raspbian, do not have this "hook" function, probably for security reasons.
(By 'Standard' I mean an official unaltered distro that you can just download and install)
The problem boils down to how to install such a hook function into an OS that is in a compressed image file of an ext type filesystem, preferably by someone who has a Windows PC or maybe a Mac.
So here is a list of what I know exists (there may be more):
1) Raspbian - No hook. You would have to create one yourself, making it a non-standard distro.
2) PiBakery - This takes the standard Raspbian image, adds a hook function (making it non-standard) and downloads it to your SD card. It has a nice graphical interface to program what the hook function does on first boot.
3) NOOBS - More of an OS installer, but after installation of each OS it uses a hook function to tidy things up due to the changing partitions.
4) NOOBSCONFIG - a little post-install script that takes advantage of NOOBS hook function to drive some initial customisations or additional installs using a simple text file for any standard OS distribution. Not as pretty or comprehensive as PiBakery.
5) PINN- An enhanced version of NOOBS that has noobsconfig built into it, so there is no need to add the noobsconfig post-install script, just add the text file to drive the customisation of any OS.
6) PiKitchen - A whole load of recipe files built on top of noobsconfig that work with NOOBS or PINN.
One difference between noobsconfig and pibakery is that noobsconfig runs a script within NOOBS/PINN before the OS is first booted (post-install), whereas pibakery's script runs within the installed OS when it first boots (post-boot). However, noobsconfig can be used to "post-install" a "post-boot" script such as pibakery's hook function into any OS.
I know Meltwater has developed a proof of concept that merges PiBakery with PINN's noobsconfig feature. If this can be developed it would allow PiBakery to create post-install functions for any standard OS that is installable by PINN.
chrisoh
Wed Aug 16, 2017 2:51 pm
I'm assuming security reasons of sorts also, seeing as a post-install script would essentially render the current Raspbian ssh and wpa_supplicant 'hooks' moot as they could be encompassed within a post-install instead.
It'd be nice to hear the official take on this concept really, as a post-install hook feature would be rather quite useful.
As a fix doesn't look likely to be released, it would provision a viable workaround for the Broadcom WiFi QoS issue present on the Pi 3 and Pi Zero W, as scripted edits could be applied to the ssh and ntp confs automatically. As it stands at the moment, headless setup over WiFi requires an extra WiFi adapter be used to bypass the onboard chip, which is tedious to say the least.
It'd also make cloning installations and applying custom configurations for deployment so much easier in the long run e.g. security camera installations.
  • HDMI +200mA
ShiftPlusOne
Wed Aug 16, 2017 3:02 pm
It's coming. Not in the next image, but eventually.
Martin Frezman
Wed Aug 16, 2017 3:09 pm
That's very good news!
Thanks!
MatsK007
Wed Aug 16, 2017 9:45 pm
Thank you all!
The idea is to drop in a script, aka post-install.sh, ssh and wpa_supp into /boot and then will a set of Pi's for a classroom be ready to use with the software needed ready to use.
And I like that it's coming in a future image and I have got a few ideas to use in the meantime.
/Mats
meltwater
Fri Aug 18, 2017 3:45 pm
Glad to hear there is still interest in a configurable and repeatable turnkey solution.
Looking forward to a system which allows quick and easy configuration, even if it just leverages a hook within the standard installer. Allowing complete setups right out the box.
Hopefully can tie these solutions together and provide benefit for the whole RPi community.
Shall put a pull request to the PiBakery to enable support for PINN/NOOBS SDCard structure, and create the config for injecting the PiBakery files into the clean image.
______________
http://www.themagpi.com/
A Magazine for Raspberry Pi Users
Read Online or Download for Free.
My new book: goo.gl/dmVtsc
Meltwater's Pi Hardware - pihardware.com
Like the MagPi? @TheMagP1 @TheMagPiTeam
MatsK007
Sat Jan 13, 2018 7:25 am
And a half year later ish, is there any news on when?
Or what could I do to help?
/Mats
mfa298
Sun Jan 14, 2018 12:02 am
This sort of functionality already exists if you use the likes of ansible, chef, puppet or salt to manage systems.
Ansible seems to be particularly popular and uses play books to configure a variety of things. I use chef (which uses cookbooks and recipes) on most of my systems to manage them. One of the benefits these can also provide is on going updates to configuration (one of my pis runs a dhcp server with the configuration updates managed via chef).
MatsK007
Sun Jan 14, 2018 12:03 pm
Noop, chef, puppet, ansibel doesn't exist without a manual interaction, first login, some commands to install, configure and deploy !
What Im aiming at is to get something that other auto deployment tools like RHEL's Kickstarts and Debians preseed's "Post script". A script that run at first boot after the installation is completed.
I have discovered that on Github there is https://github.com/RPi-Distro and that has two repos, raspberrypi-sys-mods that handles the SSH enabling part and raspberrypi-net-mods that move wpa_supplicant.conf to /etc/wpa_supplicant/wpa_supplicant.conf.
And raspberrypi-net-mods and raspberrypi-sys-mods are used with Pi-gen to create new images.
To incorporate a "Post script" is not an overly complex task, and as soon as I have got my build environment up and running I will start experimenting with it.
An first draft could be something like this:
[Unit]
Description=Copy first boot script to ....
ConditionPathExists=/boot/firstrun.sh
[Service]
Type=oneshot
ExecStart=.....
ExecStartPost=.....
[Install]
WantedBy=multi-user.target
mfa298
Sun Jan 14, 2018 4:11 pm
I can't comment on the others but with chef you bootstrap from a management node (has keys to create the required stuff on the chef server and is able to login to the client being configured). That bootstrap process should install the required binaries (you might need to find/build an armhf chef package) and do the required configuration. What I've heard of ansible it's probably even easier to work with. So as long as the pi is on the network and has ssh enabled then you should be able to use those tools to configure the pi without any manual logging in and installing stuff.
dazz100
Wed Apr 18, 2018 10:44 am
Hi
I ended up here because I really want a post script. At present it takes me about a day to manually install Raspian, configure the OS, install, configure and test the applications I run.
I want to be able to put an SD card into my PC (Linux or Windows) and write an image that includes the post script. I want to be able to then insert that SD card into a Pi and boot up. After a cup of coffee, I want to have a fully configured system running.
toussa
Fri Jun 22, 2018 11:37 am
Yes, same things here... a post install script that will be executed at the very first boot would be awesome (without installing Ansible or use SSH). Any news ?
ShiftPlusOne
Fri Jun 22, 2018 12:22 pm
...he said almost a year ago. :oops:
Sorry, no news right now. I had a bit of a template for a config file then when implementing it found a few issues which were taking some time to fix. Other higher priority tasks caught up with me and this has been sitting at the bottom of the todo list for a while.
R-A
Mon Jun 25, 2018 12:11 pm
Just to add my vote quickly.
I just setup a Raspberry Pi using the 2018-04-28-Stretch image. Generally I add the sssh and wpa_supplicant files, but in this case there is no DHCP running, and I had no spare HDMI monitor (only have my laptop with me). So it would be very helpful if there is such a post install /boot/first_run.sh script where I could add something as simple as
"ifconfig eth0 192.168.10.20 && route add default gw 192.168.10.254", and possibly even download some script from a remote server and deploy to the pie.
I'm using a Raspberry Pi 3 Model B with 7" LCD Touch screen and Mini USB Wireless Keyboard
kevin.shumaker
Mon Sep 17, 2018 1:31 am
I've been using the pi-gen to modify the installs, remove pre-installed apps, install my apps, set up wifi, activate ssh, add scripts called by crontab, just about everything the post-install script would do. Just a few other niceties to correct, and I like the idea of handling it the same way ssh.txt and wpa_supp... are handled. A one-time triggered file would be awesome.
PhatFil
Mon Sep 17, 2018 3:31 am
Hi
for a fully featured system you could check out 'Pete Scargills Christmas script' https://tech.scargill.net/the-script/
however since you seem to have been through the wheel a few times why not make your own next time you need to perform the duty,
Just open a text file (i configure my pis via ssh so have a gui to access behind the ssh window), and copy all your cli commands to the text file with copy n paste and take note if any commands that require any confirmation input.
that way when done you will have a template for a script or set of scripts.
2 things may hamper just running the commands as is, in a script, after you have removed or commented out any comments or anotations you have made.
1) any commands requiering input will be fed the next command in the list resulting in an exception, and
2) any file edits you have made are beyond the scope of the solution so far.
generally adding a flag '-y' for yes -'n' for no to commands that prompt for such input will satisfy them correctly ie 'sudo apt-get upgrade'
If that will not satisfy the cli commands that require input break/cut your script in 2 at that point and run the first script and respond to the input request and run the second etc if necessary..
for file edits when making additions to the end of a file for example /etc/dhcpcp.conf to set a static ip you can use cli commands and redirection from stdout to append to the file . so to add the line "this is a test" to the above mentioned file the cli command would be
 sudo echo this is a test >> /etc/dhcpcd.conf
sudo may not be necessary depending on your user rights..
so you can script additions to the end of files very easily,
making replacements is a bit more involved but do-able google 'grep replace' for solutions
but you may elect just to make the edits and copy the files and save along side the script/s and simply copy them back when needed?
to make your script runnable again google.. (hint add a shebang first line and execute chmod to change the files executable status.)
you will have one last painstaking install but will have a useful set up script or 2 whan done
mfa298
Mon Sep 17, 2018 10:00 am
Doesn't have to be a text file, I've also used Private Wikis, Google docs, Word, and OneNote for the same purpose. Wiki is probably my preferred as you can easy distinguish comments and descriptions from commands using some suitable formatting (I've done the same in Google Docs and Word but that usually takes a bit more configuration and copy/paste doesn't always work as well)
Don't trust in that, apt/apt-get might take -y to answer yes by default but plenty of other tools won't (or worse is might do something else). In other tools I've seen -s do a similar thing (-s for scripted) or -n do totally different things (either go through the motions but don't make changes or be silent about what's happening).
In the case of needing to edit text files sed can be a useful tool to learn.
For tools that require input sometimes you can pass them a set of commands to run, in extreme cases you could look at using expect (you'll probably need to install it first) to automate the installation.
The sudo there won't do what you expect. It'll run 'echi this is a test' as root but the redirect will be run as the logged in user (usually pi). There are a few ways around that my preferred method is to use tee.
To overwrite a file:
echo 'pi3' | sudo tee /etc/hostname
To Append to the end of a file
echo 'this is a test' | sudo tee -a /etc/dhcpcd.conf
Or for longer sets of changes use a HEREDOC
sudo tee -a /boot/config.txt << EOF
# Enable The Serial Gadget
[pi0]
dtoverlay=dwc2
[all]
EOF
PhatFil
Mon Sep 17, 2018 11:02 am
[pi0]
dtoverlay=dwc2
[all]
EOF
Thanks for the expansion and clarification, and crucially the corrections of course i would expect every command to be 'dry ran' in advance to confirm any options added..
And i have some 'echi' homework reading..
iandk
Fri Jan 24, 2020 9:35 pm
Any updates?
I'd love to see such a implementation, this would simplify the deployment enormously
Even a simple one, like this:
https://github.com/nmcclain/raspberian-firstboot
Thanks!
Fri Jan 24, 2020 9:53 pm
Any updates?
Thanks!
It hasn't happened in the last three years. Do you really think bumping an ancient historic thread is going to make any difference. I think the developer of PINN (Mr Procount) has given you the answer in this thread.
Beating your head against a wall may be less painful.
ShiftPlusOne
Sat Jan 25, 2020 12:16 am
Right sorry, I know it would be a great feature, but it's on the shelf for now.
Return to “Advanced users”
