As most of us know that the audio output on the pi is only about 775 millivolts which is right for using headphones but what if you needed a higher voltage output possibly around 1.5 volts or higher which is the spec of most CD players etc use
So on that note is there a recommended usb soundcard for output not input for the raspberry pi
