Martin Frezman
RISCOS and wireless?
Fri Jan 13, 2017 5:03 pm
Does RISCOS support WiFi at all?
On boot, I get a message about it trying to connect via Ethernet, but nothing about WiFi? Is the problem that it doesn't support my Wifi dongle or is it that it doesn't support WiFi at all?
If this post appears in the wrong forums category, my apologies.
dfeugey
Re: RISCOS and wireless?
Sat Jan 14, 2017 10:35 am
No, there is no WiFi support... for now. It's possible, as WiFi support was once available on RISC OS computers. But not today.
RISC OS FR - All RISC OS, in french (but not only)
http://www.riscos.fr/
Martin Frezman
Sat Jan 14, 2017 12:49 pm
OK. Thanks.
Micha1982
Sun Mar 04, 2018 1:05 pm
Does this change at any time maybe, is anyone working on it? Without internet/wifi it makes no sense to try it out at all to me.
Alles, was schiefgehen kann, wird auch schiefgehen.
Sun Mar 04, 2018 1:11 pm
The Developers do not hang out here:
https://www.riscosopen.org/content/down ... spberry-pi
RPi 4B 4GB (SSD Boot)..
dfeugey
Mon Mar 05, 2018 12:25 pm
Internet works... with an Ethernet cable. For WiFi, you'll have to wait, but it's high on the RISC OS' todo list.
DavidS
Tue Apr 10, 2018 4:51 am
For a desktop computer (such as a RPi with RISC OS) WiFi does not make any since. Use Ethernet instead, like you would with any desktop computer, it works quite well.
You can get on the internet using Ethernet. And there is a LOT MORE to computing than just accessing the internet.
RPi = The best ARM based RISC OS computer around
More than 95% of posts made from RISC OS on RPi 1B/1B+ computers. Most of the rest from RISC OS on RPi 2B/3B/3B+ computers
handsomegenius
Wed Jun 27, 2018 3:52 am
It's totally the other way around IMO.
The files you need for your Risc OS projects are so small, that there's no real need to worry about plugging straight into the router if it's not conveniently placed.
Here's how I'm dealing with it: http://oi67.tinypic.com/2lm2yrs.jpg
The Pi on the left is running Raspbian - it's mostly a home theatre and retro gaming rig, but I configured dnsmasq for it to serve double duty as a wireless bridge as well.
It works pretty well - I can download files to Risc OS without interrupting my album streaming on youtube. It isn't the fastest way to connect to the internet, but Risc OS doesn't really need it.
rbreslin
Tue Feb 26, 2019 1:54 pm
It's not very good not to support wifi.
I am a home/bobbyist and my method of working is the VNC or SSH into my pi from a convenient laptop. I don't have a monitor set up on a table. My pi's are not near to a nework hub (so I'd have to trail cables all through the house). How very inconvenient. Sadly, I will abandon use of Risc OS until it gets its wifi sorted out.
DavidS
Tue Feb 26, 2019 3:06 pm
How does any of that prevent you from using an Ethernet connection, plug in the network cable to the RPi's?
You still need to hook up a monitor long enough to set up VNC on the RPi to begin with.
code_exec
Tue Feb 26, 2019 7:25 pm
RISC simply doesn't have the drivers for the Pi 3's built-in WiFi. The devs also can't make drivers because the Raspberry Pi hardware, including the WiFi chip, is proprietary.
Ubuntu 18.04 LTS desktop images for the Raspberry Pi 3.
https://github.com/CodeExecution/Ubuntu-ARM64-RPi
code_exec
Tue Feb 26, 2019 7:28 pm
Not everyone uses Ethernet cables to connect to the internet. I use wireless on my laptop, Raspberry Pi 3 (running Ubuntu 18.04), tablets, and phone. Someone's router may be in the living room, while their computer room is upstairs. But they also have a laptop downstairs in the living room using the Ethernet connection! Ethernet is fast but not always convenient.
DavidS
Sat Mar 02, 2019 4:07 pm
Sounds like good reasons to avoid WiFi in my personal book. If there is both vertical gaps and horizontal gaps in space from the WiFi point then signal quickly becomes an issue, and Ethernet becomes more desirable.
I actually purchased USB Ethernet adapters for use with my Tablet PC, Phone, and other devices that did not come with an Ethernet adapter builtin. I only have WiFi for my phone when I am not sitting at one of my computer desks.
Of course the WiFi for my phone is a bit backwards to most, as my internet connection comes through my cell phone. It is the only internet available to me.
bnedwek
Sun May 12, 2019 5:10 pm
A small wireless bridge (this looks good but haven't used it yet: https://www.netgear.com/home/products/n ... R2000.aspx) would solve this problem nicely.
Return to “RISCOS”
