[SOLVED] “mount error(112): Host is down” on stretch, but not jessie! Why?
First, some background: the CIFS drive I am trying to mount: `PASSPORT2TB` is connected via USB to a small wifi AP running [OpenWRT](https://openwrt.org/), and it is shared via the Samba server on that (OpenWRT) host. I want to connect to `PASSPORT2TB` from my two RPi boxes; one runs `jessie`, the other runs `stretch`. I do not have an entry in `/etc/fstab` for `PASSPORT2TB` on either of the RPis. `RPi:stretch` is a new install on a new 3B+; `RPi:jessie` was recently upgraded from wheezy, and has an operational mount point that has worked for... years.
Here's the exchange when I attempt to mount `PASSPORT2TB` from `RPi:stretch`:
sudo mount -t cifs //192.168.1.250/PASSPORT2TB ~/mntPassport
Password for root@//192.168.1.250/PASSPORT2TB: ********
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
This same command works perfectly on `RPi:jessie`. But not on `RPi:stretch`.
I've searched for an answer, and tried the `-o` option as follows with no success :
sudo mount -t cifs //192.168.1.250/PASSPORT2B mntPassport -o vers=1.0
Password for root@//192.168.1.250/PASSPORT2B: ********
Retrying with upper case share name
mount error(6): No such device or address
Here's what `journalctl -fb` tells me:
Apr 07 04:23:08 raspberrypi3b sudo[17967]: pam_unix(sudo:session): session closed for user root
Apr 07 04:23:08 raspberrypi3b kernel: CIFS VFS: cifs_mount failed w/return code = -6
Searching for meaning here leads to an [old Samba bug report] (https://bugzilla.samba.org/show_bug.cgi?id=8046) fixed years ago
Anyone know what is causing this - or how to correct it?
- DougieLawson
- Contact: Website Twitter
Re: “mount error(112): Host is down” on stretch, but not jessie! Why?
Are you sure that //192.168.1.250/PASSPORT2TB is shared?
Are you sure that a root userid exists on the CIFS/Samba server? Samba uses a seperate password file.
Since OpenWRT is a Linux system it supports NFS for shared filesystems. Since it does then mounting an NFS export is a) more secure, b) quicker and c) easy to set-up.
https://wiki.openwrt.org/doc/howto/nfs.server
Hello @Dougie - I really appreciate the helpDougieLawson wrote: ↑Sat Apr 07, 2018 7:13 am1.Are you sure that //192.168.1.250/PASSPORT2TB is shared?
2. Are you sure that a root userid exists on the CIFS/Samba server? Samba uses a seperate password file.
3. https://wiki.openwrt.org/doc/howto/nfs.server
1. Yes, I am quite sure (how else could my `RPi-jessie` mount the drive?
2. I cannot answer that question with 100% certainty because I did not (directly) populate `/etc/samba/smbpasswd` file. But with 99% certainty, the answer is "Yes". I say this because: a) I can mount the drive from my `RPi-jessie`, b) I can mount the drive from OS X as root, and as 'guest', c) it's "how things are done" in the GL-iNet (the mfr) installs of OpenWRT on their WiFi routers (mine is AR-150).
3. This may be OpenWRT's advice now, but it hasn't always been (much upset there now as you may know). Further, there is **NO OPTION** provided to switch over at this point (in the LUCI interface at any rate). I am running the latest firmware from GL-iNet.
To summarize, I really, truly appreciate your suggestions for making over my system, and I know you do so with the best of intentions. But without trying to sound ungrateful, I do not feel the need to invest that time now, and potentially wreck a configuration that has been serving its purpose well and securely for some time now on the theory that an NFS install will solve the problem.
That said, if you can answer the question I asked without requiring me to make over my system, I would really like to hear it. Something has changed in Raspbian between Jessie and Stretch that is causing this... do you know what it is? If it's an authentication issue, and you have any clue as to where I need to begin looking, I would appreciate that. Your NFS evangelism is duly noted.
- DougieLawson
Do you know the samba configuration on your OpenWRT device, are any shares public and don't need a userid/password?
Take a look with the following commands
nmblookup __SAMBA__
nmblookup -S __SAMBA__
nmblookup '*'
nmblookup -S '*'
nmblookup -S WORKGROUP
For that last command you can use your own workgroup name if it's not set to the Microsoft default of "WORKGROUP".
I suspect your problem will be that the credentials for your "root" user aren't recognised. I don't know OpenWRT (because I've never had a device that can run it) but it probably logs Samba/CIFS requests and failures.
nmblookup __SAMBA__
nmblookup '*'
nmblookup -S '*'
Thank you again. I take it then, that you're unaware of any diffs between raspbian Jessie and raspbian Stretch that could be responsible for this new behavior?DougieLawson wrote: ↑Sat Apr 07, 2018 5:37 pmDo you know the samba configuration on your OpenWRT device, are any shares public and don't need a userid/password?
nmblookup __SAMBA__
nmblookup '*'
nmblookup -S '*'
Yes - all files on the Passport (a 2TB USB drive used mostly to house my MP3 collection for Sonos) are designated as accessible from the 'guest' account. The entire drive is also marked as read-only. A screenshot follows that shows most of the config options (scratch that - I can't insert an image in posts here). Anyway, I am mounting PASSPORT2TB as the root user because occasionally I need to use it to back up files from my RPi. I've also tried to mount PASSPORT2TB as guest, and that fails also.
FWIW, this feels like a bug in raspbian stretch.
Thanks,
~S
- DougieLawson
Are you using
mount //192.168.1.250/PASSPORT2TB /home/pi/mntPassport -o guest,vers=1.0,...
or
mount //192.168.1.250/PASSPORT2TB /home/pi/mnt/Passport -o username=guest,password=,vers=1.0,...
or
Try changing vers=1.0 to vers=3.0 (or 2.0). Microsoft has deprecated 1.0, though I'm not sure why it would work on one system but not another.
samba security tightened up between jessie and stretch, and I've had the "Host is down" report for hosts that are so very up indeed.
Adding these options to the fstab line made a formerly disappeared host work for me:
I have no idea why these worked.
sec=ntlm,noserverino,vers=2.0
‘Remember the Golden Rule of Selling: “Do not resort to violence.”’ — McGlashan.
Pronouns: he/him
Pronouns: he/him
DougieLawson wrote: ↑Sat Apr 07, 2018 7:50 pmAre you using
or
mount //192.168.1.250/PASSPORT2TB /home/pi/mntPassport -o username=guest,password=,vers=1.0,...
I have tried:
sudo mount -t cifs //192.168.1.250/PASSPORT2B /home/pi/mntPassport
sudo mount -t cifs //192.168.1.250/PASSPORT2B /home/pi/mntPassport -o vers=1.0
sudo mount -t cifs //192.168.1.250/PASSPORT2B /home/pi/mntPassport -o vers=2.0
sudo mount.cifs //192.168.1.250 /home/pi/mntPassport -o guest,ro
sudo mount.cifs //192.168.1.250/pri_library /home/pi/mntPassport -o guest,ro
sudo mount.cifs //192.168.1.250/pri_library /home/pi/mntPassport -o user=root,password=********,nounix,sec=ntlmssp
sudo mount -t cifs -o username=root,password=********,nounix,sec=ntlmssp //192.168.1.250/PASSPORT2B /home/pi/mntPassport
sudo mount //192.168.1.250/PASSPORT2TB /home/pi/mntPassport -o username=guest,password=,vers=1.0
sudo mount //192.168.1.250/PASSPORT2TB /home/pi/mntPassport -o username=root,password=********,vers=1.0
sudo mount -t cifs //192.168.1.250/PASSPORT2TB /home/pi/mntPassport -o username=root,password=********,vers=1.0
FWIW, the key diffs are: `vers=1.0` AND `username` instead of `user`
For the record:
1.) using `vers=2.0` and `vers=3.0` both fail on Stretch
2.) using `-o user=*****` works fine on Jessie, but Stretch won't have it! Stretch **requires** `-o username=*****
3.) from `man mount.cifs`:
vers=
SMB protocol version. Allowed values are:
· 1.0 - The classic CIFS/SMBv1 protocol. This is the default.(*)
(*): Which we now know is INCORRECT.
But I was careless, and stupid - mea culpa; my apologies for that, and my thanks for your patience.
That said, I do find it odd that these changes were made **without** also making a change to the error codes that were returned.
Re: [SOLVED] “mount error(112): Host is down” on stretch, but not jessie! Why?
Welcome to Unix.isn't really very helpful.Code: Select all
"L'enfer, c'est les autres"
G fytc hsqr rum umpbq rm qyw rm rfc kmbq md rfgq dmpsk:
Epmu Sn!
J lnacjrw njbruh-carppnanm vxm rb mnuncrwp vh yxbcb!
Epmu Sn!
Yes, I read that the Samba vulnerability from last year had resulted in some changes. And I think that's fine, but it seems awkwardly implemented here.scruss wrote: ↑Sun Apr 08, 2018 2:16 amsamba security tightened up between jessie and stretch, and I've had the "Host is down" report for hosts that are so very up indeed.
Adding these options to the fstab line made a formerly disappeared host work for me:I have no idea why these worked.Code: Select all
It's interesting that `vers=2.0` worked in your fstab, but not on my command line... I hope that's not still more sloppiness (that's not the "Debian way").
Indeed! But I suppose as users of an open source system, that puts some of the responsibility for maintenance on us, eh?n67 wrote: ↑Sun Apr 08, 2018 4:16 pmWelcome to Unix.isn't really very helpful.Code: Select all
hi all, im trying to mount a share on startup (stretch) without anyluck. it works from the command line with
sudo mount -t cifs -o username=admin,password=password,vers=1.0 //192.168.1.100/movies /mnt/movies
but not in /etc/fstab
//192.168.1.100/movies /mnt/movies cifs defaults,vers=1.0,username=admin,password=password 0 0
sudo mount -a completes without any error but it does not mount
please help
please help
please don't add to a [SOLVED] post; everyone assumes it's resolved. Start a new thread
Pronouns: he/him
Pronouns: he/him
I confirm it works with option vers=1.0 !
system:
smb server: Zyxel NSA325-v2
/etc/fstab:
/home/openhabian/.smbcredentials:
.smbcredentials security:
without this option I get the classical error "host is down":
Many thanks for helping out with this issue!
system:
## Release = Raspbian GNU/Linux 9 (stretch)
## Kernel = Linux 4.14.34-v7+
## Platform = Raspberry Pi 3 Model B Rev 1.2
/etc/fstab:
//10.0.0.253/3tb_1 /mnt/3tb_1 cifs credentials=/home/openhabian/.smbcredentials,uid=openhabian,gid=openhabian,rw,vers=1.0 0 0
//10.0.0.253/3tb_2 /mnt/3tb_2 cifs credentials=/home/openhabian/.smbcredentials,uid=openhabian,gid=openhabian,rw,vers=1.0 0 0
username=userxxx
password=**************
openhabian@pi:~ $ ll /home/openhabian/.smbcredentials
-rw------- 1 openhabian openhabian 33 May 17 13:37 /home/openhabian/.smbcredentials
openhabian@pi:~ $ sudo mount -a
Many thanks for this post, I had exactly the same problem, I was using 'user' and 'passwd' now both require the full
'username' and 'password', also the vers=1.0 finally fixed it.
sudo mount -t cifs //192.168.0.111/Download /home/pi/wdshare -o username=pi,password=******,rw,file_mode=0777,dir_mode=0777,vers=1.0
Works fine on both 3B and 3B+
Interesting though, mounting to a windows share has not changed, this still works to my PC share.
sudo mount -t cifs -o username=XYZ,password=********,file_mode=0777,dir_mode=0777 //192.168.0.14/Pi /mnt
Thanks for this post, it fixed my problem as well.
just added vers-1.0 at the end of the mount and it worked.
same as the other user, my Windows mount didn't need the change.
- exartemarte
- Contact: Website
For the record, this worked for me too. I am accessing networked Pi's (with Samba and various old versions of Raspbian) on the network from a newly set up Pi with current Raspbian Stretch. Fstab entries which had previously worked in Jessie generated the 'Host is down' message in Stretch.
To mount a drive called 'disk1', on a remote Pi called 'hannah' (don't ask...), to the local directory /media/hannah, the relevant line in my /etc/fstab is now:
//hannah/disk1 /media/hannah cifs username=pi,password=MyPasswordForHannah,vers=1.0 0 0
This works, though I did have to check the 'Wait for Network' option in Raspi configuration for it to work on boot.
I am having the same problem but can't find any other thread that opened on this one. did you solve it?vectraboyv6 wrote: ↑Mon May 14, 2018 8:41 amhi all, im trying to mount a share on startup (stretch) without anyluck. it works from the command line with
please help
