cubii
cloning Kernel - Fatal error
Thu Jul 19, 2012 9:56 am
i am trying to get usbip working and if i use the howto from secretagent http://www.raspberrypi.org/phpBB3/viewt ... 91#p121691 i have to use git to clone the kernel
sudo apt-get install git
git clone git://github.com/raspberrypi/linux.git kernel
but i get all the time this error
]Recieving Objects: 100% ("some numbers") , 465,76Mb
Error: index-pack died of Signal  901563)     901563)
Fatal: index-pack failed
The number after signal changes with every try.
I used the wheezy beta image with updates (apt-get update, apt-get upgrade, aptitude update, aptitude upgrade and 2 times i also use the hexxa updater for the kernel update.
I tried different sd cards - but all the time i used the raspi-config script to use all available space on the sdcard (perhaps this is wrong?)
Anybody nows whats wrong here? My pi or git or something else?
RaTTuS
Re: cloning Kernel - Fatal error
Thu Jul 19, 2012 10:02 am
possibly you are running out of memory,
if this is on a RPi then
configure a swapfile or enable a swap partition.
the RPi is set to low swapiness so will only use it if needed.
Covfefe
cubii
Fri Jul 20, 2012 6:53 am
Thanks, it seems that this was the problem.
I found an how to on this page http://elsmorian.com/post/23366148056/b ... y-pi-setup
To create the swapfile;
sudo dd if=/dev/zero of=/var/swapfile bs=1M count=128
This creates a 128MB file filled with zeros called /var/swapfile, and might take a little while depending on the speed of your card.
sudo mkswap /var/swapfile (to setup the file as swap space)
sudo swapon /var/swapfile (to enable the swap space, this also might take a little while.)
sudo reboot
All thats left now is to edit /etc/fstab and tell the system to mount the file as swap every time it starts up;
sudo nano /etc/fstab
Whilst in nano, delete the line starting with a hash (#), and paste or type in:
/dev/mmcblk0p2 / ext4 defaults,noatime,nodiratime 0 0
/var/swapfile none swap sw 0 0
This tells the system to mount the 2nd partition at / in the filesystem, and to mount it with “noatime,nodiratime”, meaning the system will not write when files and directories were last accessed, speed things up a bit. The next line also tells the system to mount the swapfile we made. This file is read at boot time, and tells the system to mount the stated devices automatically each time the system is booted.
“CTRL+W” then “Y” to exit nano and save changes, and then a final reboot is all that’s needed.
and after that it worked!
Thanks for the tip!
