VincentGR
WiFi and Updates problem
Mon Feb 19, 2018 12:39 am
Hello everybody.
Well I have a ZeroW where my BBS is running with some scripts for noip refresh and re-enabling mystic if something goes wrong.
All worked fine till some days ago, when my router reboots or just internet connection drops and returns my Pi is unresponsive through local telnet etc.
This is not happening on my Pi3.
Another issue is that I use the latest raspbian on my Pi3 and I saw this when I run the update:
[email protected]:~ $ sudo apt-get update
Hit:1 http://mirrordirector.raspbian.org/raspbian stretch InRelease
Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
Reading package lists... Done
and on my Zero:
[email protected]:~$ sudo apt-get update
Hit http://mirrordirector.raspbian.org jessie InRelease
Hit http://archive.raspberrypi.org jessie InRelease
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
Pi0 firmware:
Linux raspberrypi 4.14.18+ #1093 Fri Feb 9 15:07:36 GMT 2018 armv6l GNU/Linux
Feb 9 2018 14:22:56
Copyright (c) 2012 Broadcom
version b54484abff4ad7d7bdda6e6387737e29b33f18ee (clean) (release)
Pi3 firmware:
Linux raspberrypi 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l GNU/Linux
Oct 24 2017 17:09:22
version a3d7660e6749e75e2c4ce4d377846abd3b3be283 (clean) (release)
Is this normal?
Thank you for your time.
wh7qq
Re: WiFi and Updates problem
Mon Feb 19, 2018 8:21 pm
It looks like the Pi3 has much more recent software on it with the most recent version (stretch) while the zero still has the last version (jessie) and will need more updating because of its age. Wifi tends to drop with router outages on the RPis and you need to set up software to reboot or restart the wifi automatically when it drops.
VincentGR
Mon Feb 19, 2018 10:26 pm
Thanks for your answer.
I had tested some scripts in bashrc - rc.local that worked but not anymore.
Even the one in crontab stopped too.
Really don't know why it changes behavior.
wh7qq
Tue Feb 20, 2018 6:01 am
It changes because the Debian devs change things...arbitrary but of course, for good reason. Your Jessie installation is overdue to be replaced by the current Stretch. Get it here on the "Downloads" page above.
VincentGR
Tue Feb 20, 2018 7:41 am
I'll let zero as is, don't want to mess more the BBS.
As for 3 I will keep updating, maybe bluetooth will be fixed too.
VincentGR
Wed Apr 04, 2018 2:32 pm
Everything is OK now after the new updates.
VincentGR
Thu Apr 05, 2018 9:04 pm
Well...
After another update everything is back to "normal"
No bluetooth again.
:evil:
Return to “Raspberry Pi OS”
