After a few reboots, with WIFI seemingly randomly ending up working or not working, I compared the output of 'service --status-all' in both cases: They are exactly the same
I also dumped the output of 'dmesg' in both cases: output is below for both cases:
NOT WORKING:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.59+ (
[email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1047 Sun Oct 29 11:47:10 GMT 2017
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] OF: fdt:Machine model: Raspberry Pi Model B Plus Rev 1.2
[ 0.000000] cma: Reserved 8 MiB at 0x1b400000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 114688
[ 0.000000] free_area_init_node: node 0, pgdat c0914e10, node_mem_map db010000
[ 0.000000] Normal zone: 1008 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 114688 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 113680
[ 0.000000] Kernel command line: bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=PARTUUID=f3a2a455-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 435944K/458752K available (5950K kernel code, 491K rwdata, 1948K rodata, 396K init, 725K bss, 14616K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xdc800000 - 0xff800000 ( 560 MB)
lowmem : 0xc0000000 - 0xdc000000 ( 448 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc05d7a48 (5951 kB)
.init : 0xc0841000 - 0xc08a4000 ( 396 kB)
.data : 0xc08a4000 - 0xc091ef48 ( 492 kB)
.bss : 0xc091ef48 - 0xc09d4648 ( 726 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000031] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000075] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000176] bcm2835: system timer (irq = 27)
[ 0.000646] Console: colour dummy device 80x30
[ 0.001386] console [tty1] enabled
[ 0.001441] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[ 0.060364] pid_max: default: 32768 minimum: 301
[ 0.060828] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.060899] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.062192] Disabling memory control group subsystem
[ 0.062400] CPU: Testing write buffer coherency: ok
[ 0.062504] ftrace: allocating 21715 entries in 64 pages
[ 0.180776] Setting up static identity map for 0x8200 - 0x8238
[ 0.182852] devtmpfs: initialized
[ 0.192339] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.192865] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.192965] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.194291] pinctrl core: initialized pinctrl subsystem
[ 0.195794] NET: Registered protocol family 16
[ 0.198244] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.207851] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.207943] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.208083] Serial: AMBA PL011 UART driver
[ 0.211037] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[ 0.261413] bcm2835-dma 20007000.dma: DMA legacy API manager at dc80d000, dmachans=0x1
[ 0.264175] SCSI subsystem initialized
[ 0.264506] usbcore: registered new interface driver usbfs
[ 0.264678] usbcore: registered new interface driver hub
[ 0.264917] usbcore: registered new device driver usb
[ 0.270865] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-10-24 17:09
[ 0.272812] clocksource: Switched to clocksource timer
[ 0.327007] VFS: Disk quotas dquot_6.6.0
[ 0.327209] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.327580] FS-Cache: Loaded
[ 0.327975] CacheFiles: Loaded
[ 0.347399] NET: Registered protocol family 2
[ 0.348829] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.348987] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.349120] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.349256] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.349323] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.349681] NET: Registered protocol family 1
[ 0.350490] RPC: Registered named UNIX socket transport module.
[ 0.350565] RPC: Registered udp transport module.
[ 0.350605] RPC: Registered tcp transport module.
[ 0.350640] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.351769] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[ 0.354405] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.375161] FS-Cache: Netfs 'nfs' registered for caching
[ 0.377009] NFS: Registering the id_resolver key type
[ 0.377121] Key type id_resolver registered
[ 0.377166] Key type id_legacy registered
[ 0.381652] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.382124] io scheduler noop registered
[ 0.382189] io scheduler deadline registered (default)
[ 0.382695] io scheduler cfq registered
[ 0.388724] BCM2708FB: allocated DMA memory 5b500000
[ 0.388857] BCM2708FB: allocated DMA channel 0 @ dc80d000
[ 0.397166] Console: switching to colour frame buffer device 82x26
[ 0.407553] bcm2835-rng 20104000.rng: hwrng registered
[ 0.410345] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 0.416766] vc-sm: Videocore shared memory driver
[ 0.444352] brd: module loaded
[ 0.459730] loop: module loaded
[ 0.462503] Loading iSCSI transport class v2.0-870.
[ 0.466180] usbcore: registered new interface driver smsc95xx
[ 0.468928] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.699833] Core Release: 2.80a
[ 0.702508] Setting default values for core params
[ 0.705225] Finished setting default values for core params
[ 0.908344] Using Buffer DMA mode
[ 0.910954] Periodic Transfer Interrupt Enhancement - disabled
[ 0.913605] Multiprocessor Interrupt Enhancement - disabled
[ 0.916253] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.918936] Dedicated Tx FIFOs mode
[ 0.922210] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xdb514000 dma = 0x5b514000 len=9024
[ 0.927838] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.941012] dwc_otg: Microframe scheduler enabled
[ 0.941150] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc0451694
[ 0.943768] WARN::hcd_init_fiq:460: FIQ ASM at 0xc0451970 length 36
[ 0.946399] WARN::hcd_init_fiq:486: MPHI regs_base at 0xdc8a5000
[ 0.949180] dwc_otg 20980000.usb: DWC OTG Controller
[ 0.951881] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[ 0.954737] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[ 0.957427] Init: Port Power? op_state=1
[ 0.959959] Init: Power Port (0)
[ 0.962879] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.965552] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.968166] usb usb1: Product: DWC OTG Controller
[ 0.970724] usb usb1: Manufacturer: Linux 4.9.59+ dwc_otg_hcd
[ 0.973357] usb usb1: SerialNumber: 20980000.usb
[ 0.977081] hub 1-0:1.0: USB hub found
[ 0.979693] hub 1-0:1.0: 1 port detected
[ 0.983123] dwc_otg: FIQ enabled
[ 0.983136] dwc_otg: NAK holdoff enabled
[ 0.983142] dwc_otg: FIQ split-transaction FSM enabled
[ 0.983162] Module dwc_common_port init
[ 0.983670] usbcore: registered new interface driver usb-storage
[ 0.986669] mousedev: PS/2 mouse device common for all mice
[ 0.990838] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
[ 0.994080] bcm2835-cpufreq: min=700000 max=700000
[ 0.997332] sdhci: Secure Digital Host Controller Interface driver
[ 1.000016] sdhci: Copyright(c) Pierre Ossman
[ 1.003162] sdhost-bcm2835 20202000.sdhost: could not get clk, deferring probe
[ 1.006274] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.009759] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.012731] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.016010] usbcore: registered new interface driver usbhid
[ 1.018805] usbhid: USB HID core driver
[ 1.022758] vchiq: vchiq_init_state: slot_zero = 0xdb580000, is_master = 0
[ 1.027654] [vc_sm_connected_init]: start
[ 1.038049] [vc_sm_connected_init]: end - returning 0
[ 1.041500] Initializing XFRM netlink socket
[ 1.044359] NET: Registered protocol family 17
[ 1.047246] Key type dns_resolver registered
[ 1.051664] registered taskstats version 1
[ 1.061732] uart-pl011 20201000.serial: cts_event_workaround enabled
[ 1.065006] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 1.890340] console [ttyAMA0] enabled
[ 1.899379] sdhost: log_buf @ db513000 (5b513000)
[ 1.982895] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.991411] of_cfs_init
[ 2.016909] of_cfs_init: OK
[ 2.023377] Waiting for root device PARTUUID=f3a2a455-02...
[ 2.033203] Indeed it is in host mode hprt0 = 00021501
[ 2.102049] random: fast init done
[ 2.150750] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.166495] mmc0: new high speed SDHC card at address 59b4
[ 2.176390] mmcblk0: mmc0:59b4 USD 3.75 GiB
[ 2.185900] mmcblk0: p1 p2
[ 2.242901] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.252410] Indeed it is in host mode hprt0 = 00001101
[ 2.334558] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.348746] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.369624] devtmpfs: mounted
[ 2.377029] Freeing unused kernel memory: 396K
[ 2.384471] This architecture does not have kernel memory protection.
[ 2.493404] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.503570] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.515632] hub 1-1:1.0: USB hub found
[ 2.522951] hub 1-1:1.0: 5 ports detected
[ 2.852929] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.966229] systemd[1]: System time before build time, advancing clock.
[ 2.993417] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.003927] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.020376] smsc95xx v1.0.5
[ 3.127582] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-20980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:48:41:45
[ 3.151798] NET: Registered protocol family 10
[ 3.183904] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.236163] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 3.263843] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[ 3.274997] systemd[1]: Detected architecture arm.
[ 3.305014] systemd[1]: Set hostname to <CM0019>.
[ 3.431580] usb 1-1.4: New USB device found, idVendor=148f, idProduct=5370
[ 3.441829] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.452418] usb 1-1.4: Product: 802.11 n WLAN
[ 3.459981] usb 1-1.4: Manufacturer: Ralink
[ 3.467244] usb 1-1.4: SerialNumber: 1.0
[ 3.652499] uart-pl011 20201000.serial: no DMA platform data
[ 4.410050] systemd[1]:
[email protected]: Cannot add dependency job, ignoring: Unit
[email protected] is masked.
[ 4.440782] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 4.456688] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 4.471425] systemd[1]: Listening on udev Kernel Socket.
[ 4.484810] systemd[1]: Listening on udev Control Socket.
[ 4.498871] systemd[1]: Created slice User and Session Slice.
[ 4.512708] systemd[1]: Listening on Journal Socket.
[ 6.868030] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 8.992716] systemd-journald[114]: Received request to flush runtime journal from PID 1
[ 9.892576] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[ 15.537951] usb 1-1.4: reset high-speed USB device number 4 using dwc_otg
[ 15.738025] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5390, rev 0502 detected
[ 16.358952] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
[ 16.523697] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5370 detected
[ 16.663359] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 16.693343] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 16.696453] usbcore: registered new interface driver rt2800usb
[ 18.251728] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x43E1
[ 18.907607] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
[ 18.919621] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.36
[ 19.395664] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 26.245393] nf_conntrack version 0.5.0 (7168 buckets, 28672 max)
[ 28.607416] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 29.245471] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 57.062339] random: crng init done
WORKING:
[ 0.000032] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000077] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000179] bcm2835: system timer (irq = 27)
[ 0.001390] console [tty1] enabled
[ 0.001446] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[ 0.060367] pid_max: default: 32768 minimum: 301
[ 0.060832] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.060906] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.062205] Disabling memory control group subsystem
[ 0.062414] CPU: Testing write buffer coherency: ok
[ 0.062517] ftrace: allocating 21715 entries in 64 pages
[ 0.180790] Setting up static identity map for 0x8200 - 0x8238
[ 0.182864] devtmpfs: initialized
[ 0.192366] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.192891] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.192992] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.194308] pinctrl core: initialized pinctrl subsystem
[ 0.195815] NET: Registered protocol family 16
[ 0.198271] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.207836] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.207931] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.208070] Serial: AMBA PL011 UART driver
[ 0.211015] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[ 0.261407] bcm2835-dma 20007000.dma: DMA legacy API manager at dc80d000, dmachans=0x1
[ 0.264160] SCSI subsystem initialized
[ 0.264488] usbcore: registered new interface driver usbfs
[ 0.264661] usbcore: registered new interface driver hub
[ 0.264900] usbcore: registered new device driver usb
[ 0.270870] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-10-24 17:09
[ 0.272819] clocksource: Switched to clocksource timer
[ 0.327014] VFS: Disk quotas dquot_6.6.0
[ 0.327216] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.327587] FS-Cache: Loaded
[ 0.327977] CacheFiles: Loaded
[ 0.347367] NET: Registered protocol family 2
[ 0.348784] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.348942] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.349075] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.349212] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.349280] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.349634] NET: Registered protocol family 1
[ 0.350444] RPC: Registered named UNIX socket transport module.
[ 0.350520] RPC: Registered udp transport module.
[ 0.350558] RPC: Registered tcp transport module.
[ 0.350595] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.351726] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[ 0.354373] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.375129] FS-Cache: Netfs 'nfs' registered for caching
[ 0.376966] NFS: Registering the id_resolver key type
[ 0.377077] Key type id_resolver registered
[ 0.377120] Key type id_legacy registered
[ 0.381609] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.382077] io scheduler noop registered
[ 0.382143] io scheduler deadline registered (default)
[ 0.382651] io scheduler cfq registered
[ 0.388695] BCM2708FB: allocated DMA memory 5b500000
[ 0.388830] BCM2708FB: allocated DMA channel 0 @ dc80d000
[ 0.397140] Console: switching to colour frame buffer device 82x26
[ 0.407532] bcm2835-rng 20104000.rng: hwrng registered
[ 0.410323] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 0.416762] vc-sm: Videocore shared memory driver
[ 0.444354] brd: module loaded
[ 0.459723] loop: module loaded
[ 0.462514] Loading iSCSI transport class v2.0-870.
[ 0.466200] usbcore: registered new interface driver smsc95xx
[ 0.468948] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.699842] Core Release: 2.80a
[ 0.702517] Setting default values for core params
[ 0.705234] Finished setting default values for core params
[ 0.908343] Using Buffer DMA mode
[ 0.910948] Periodic Transfer Interrupt Enhancement - disabled
[ 0.913608] Multiprocessor Interrupt Enhancement - disabled
[ 0.916255] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.918942] Dedicated Tx FIFOs mode
[ 0.922222] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xdb514000 dma = 0x5b514000 len=9024
[ 0.927829] FIQ FSM acceleration enabled for :
[ 0.940986] dwc_otg: Microframe scheduler enabled
[ 0.941124] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc0451694
[ 0.943732] WARN::hcd_init_fiq:460: FIQ ASM at 0xc0451970 length 36
[ 0.946365] WARN::hcd_init_fiq:486: MPHI regs_base at 0xdc8a5000
[ 0.949143] dwc_otg 20980000.usb: DWC OTG Controller
[ 0.951850] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[ 0.954701] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[ 0.957380] Init: Port Power? op_state=1
[ 0.959910] Init: Power Port (0)
[ 0.962758] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.965502] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.968140] usb usb1: Product: DWC OTG Controller
[ 0.970703] usb usb1: Manufacturer: Linux 4.9.59+ dwc_otg_hcd
[ 0.973331] usb usb1: SerialNumber: 20980000.usb
[ 0.977044] hub 1-0:1.0: USB hub found
[ 0.979667] hub 1-0:1.0: 1 port detected
[ 0.983088] dwc_otg: FIQ enabled
[ 0.983100] dwc_otg: NAK holdoff enabled
[ 0.983106] dwc_otg: FIQ split-transaction FSM enabled
[ 0.983126] Module dwc_common_port init
[ 0.983628] usbcore: registered new interface driver usb-storage
[ 0.986634] mousedev: PS/2 mouse device common for all mice
[ 0.990849] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
[ 0.994079] bcm2835-cpufreq: min=700000 max=700000
[ 0.997344] sdhci: Secure Digital Host Controller Interface driver
[ 1.000026] sdhci: Copyright(c) Pierre Ossman
[ 1.003175] sdhost-bcm2835 20202000.sdhost: could not get clk, deferring probe
[ 1.006286] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.009773] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.012745] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.016022] usbcore: registered new interface driver usbhid
[ 1.018821] usbhid: USB HID core driver
[ 1.022769] vchiq: vchiq_init_state: slot_zero = 0xdb580000, is_master = 0
[ 1.027647] [vc_sm_connected_init]: start
[ 1.038064] [vc_sm_connected_init]: end - returning 0
[ 1.041514] Initializing XFRM netlink socket
[ 1.044372] NET: Registered protocol family 17
[ 1.047261] Key type dns_resolver registered
[ 1.051690] registered taskstats version 1
[ 1.061741] uart-pl011 20201000.serial: cts_event_workaround enabled
[ 1.065013] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 1.890330] console [ttyAMA0] enabled
[ 1.899352] sdhost: log_buf @ db513000 (5b513000)
[ 1.982906] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.991408] of_cfs_init
[ 2.016888] of_cfs_init: OK
[ 2.023349] Waiting for root device PARTUUID=f3a2a455-02...
[ 2.033227] Indeed it is in host mode hprt0 = 00021501
[ 2.101813] random: fast init done
[ 2.150766] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.166502] mmc0: new high speed SDHC card at address 59b4
[ 2.176368] mmcblk0: mmc0:59b4 USD 3.75 GiB
[ 2.185850] mmcblk0: p1 p2
[ 2.242916] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.252417] Indeed it is in host mode hprt0 = 00001101
[ 2.334704] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.348894] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.369669] devtmpfs: mounted
[ 2.377066] Freeing unused kernel memory: 396K
[ 2.384512] This architecture does not have kernel memory protection.
[ 2.503584] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.515639] hub 1-1:1.0: USB hub found
[ 2.522993] hub 1-1:1.0: 5 ports detected
[ 2.852945] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.968191] systemd[1]: System time before build time, advancing clock.
[ 2.993454] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.003760] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.017877] smsc95xx v1.0.5
[ 3.128985] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-20980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:48:41:45
[ 3.153420] NET: Registered protocol family 10
[ 3.186123] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.238403] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 3.266092] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[ 3.277347] systemd[1]: Detected architecture arm.
[ 3.306711] systemd[1]: Set hostname to <CM0019>.
[ 3.431513] usb 1-1.4: New USB device found, idVendor=148f, idProduct=5370
[ 3.441764] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.452349] usb 1-1.4: Product: 802.11 n WLAN
[ 3.459925] usb 1-1.4: Manufacturer: Ralink
[ 3.467168] usb 1-1.4: SerialNumber: 1.0
[ 3.651571] uart-pl011 20201000.serial: no DMA platform data
[ 4.409206] systemd[1]:
[ 4.440781] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.455463] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 4.470090] systemd[1]: Listening on Syslog Socket.
[ 4.483792] systemd[1]: Created slice System Slice.
[ 4.497171] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 4.516214] systemd[1]: Mounting RPC Pipe File System...
[ 6.822997] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 9.210135] systemd-journald[95]: Received request to flush runtime journal from PID 1
[ 9.943067] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[ 15.256308] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 16.163063] usb 1-1.4: reset high-speed USB device number 4 using dwc_otg
[ 16.354042] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5390, rev 0502 detected
[ 16.808354] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
[ 16.820688] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x43E1
[ 17.003090] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5370 detected
[ 17.069652] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 17.076353] usbcore: registered new interface driver rt2800usb
[ 19.115910] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
[ 19.127818] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.36
[ 19.625598] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 20.585688] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 25.663559] nf_conntrack version 0.5.0 (7168 buckets, 28672 max)
[ 27.526434] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 28.568739] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 179.018477] random: crng init done
