BenMcLean
Re: Quake and Quake III, but not Quake II?
Sun Dec 17, 2017 8:33 pm
VincentGR wrote:
Sun Dec 17, 2017 8:29 pm
BenMcLean wrote:
Sun Dec 17, 2017 7:57 pm
Can we get binaries distributed?
If it is legal and the site permits it, there is no reason I wouldn't upload them.
It's perfectly legal to redistribute binaries because the Quake II source code is GPLv2. It would even be legal to redistribute the shareware PAK files. (but don't bother) It just wouldn't be legal to redistribute the commercial PAK files.
I'd appreciate your sharing, but ultimately, I'd like to get Quake II added to the RetroPie setup script. That would make it easy for people running RetroPie to set up and start playing Quake II.
VincentGR
Sun Dec 17, 2017 8:36 pm
Yes that would be great, I have 1 and 3 on my RetroPie.
jdonald
Tue Dec 19, 2017 3:43 am
Isn't RetroPie largely limited to the legacy Broadcom driver at this time? Given the OpenGL requirement I think this could work on RetroPie for ODROID, but for Pi we'd need better support for rpi3-mesa.
https://github.com/RetroPie/RetroPie-Setup/issues/2093
386dx40
Tue Feb 06, 2018 5:39 pm
I'm trying the tutorial to run the game demo with the last source but when I run the executable I get this errors:
----- refresher initialization -----
LoadLibrary("ref_gl.so") failed: No such file or directory
CDAudio_Init: Unable to open default CD-ROM drive: Invalid CD-ROM drive index
-------- game initialization -------
LoadLibrary("game.so")
ERROR: failed to load game DLL
Shutting down OpenAL.
Error: Error during initialization
I remember having some warning during the compilation but I didn't save the output. I've enabled the gl driver thinking could be related to that but no way. Any help? :)
I also tried to recompile the source and now I get this (???):
src/refresh/files/jpeg.c:55:1: error: conflicting types for ‘jpeg_mem_src’
jpeg_mem_src(j_decompress_ptr cinfo, unsigned char *mem, unsigned long len)
In file included from src/refresh/files/jpeg.c:30:0:
/usr/include/jpeglib.h:923:14: note: previous declaration of ‘jpeg_mem_src’ was here
EXTERN(void) jpeg_mem_src (j_decompress_ptr cinfo,
Before even with some warning it didn't stop this way! :shock:
jdonald
Tue Feb 06, 2018 6:52 pm
Hey 386dx40,
I explain how to avoid the libjpeg header issue at the end of my Sat Dec 16, 2017 7:05 pm post earlier in this thread. Basically you should use the master branch rather than the opengl_es branch, then it's a non-issue.
Not sure if your earlier problem was tied to using the wrong branch as well?
386dx40
Tue Feb 06, 2018 8:15 pm
Hey 386dx40,
Thank you! I'm now using that source to compile the game and it's compiling without errors and it runs! :)
It runs quiet well with texture filtering and all, but need to test it better cause the mouse sometimes seems not to fire during gameplay and sometimes it freeze firing. Anyway impressive porting of the game.
JohnnyDub
Wed Feb 07, 2018 1:33 am
Hi Guys,
i followed spidey57 description and got Quake II running with OpenGL_es. It was running ok... if any lighting was on the screen it started dropping the framerate to much to be playable. The i discovered jdonalds thread about the newest branch in normal gl. I downloaded the github repo. Followed exactly the descirption in the readme text with this result: ....everything fine....then this:
Yamagi Quake II v7.11pre
Client build options:
 + SDL2
 - CD audio
 + OGG/Vorbis
 + OpenAL audio
 + Zip file support
Platform: Linux
Architecture: arm
Byte ordering: little endian
Added packfile './baseq2/pak0.pak' (3307 files).
Added packfile './baseq2/pak1.pak' (279 files).
Added packfile './baseq2/pak2.pak' (2 files).
Added packfile '/home/pi/RetroPie/roms/ports/quake2//baseq2/pak0.pak' (3307 files).
Added packfile '/home/pi/RetroPie/roms/ports/quake2//baseq2/pak1.pak' (279 files).
Added packfile '/home/pi/RetroPie/roms/ports/quake2//baseq2/pak2.pak' (2 files).
Using '/home/pi/.yq2//baseq2' for writing.
execing default.cfg
execing yq2.cfg
execing config.cfg
You can't bind the special key "ESCAPE"!
couldn't exec autoexec.cfg
Console initialized.
------- sound initialization -------
LoadLibrary(libopenal.so.1)
AL lib: (WW) alc_initconfig: Failed to initialize backend "pulse"
...opening OpenAL device:ok
...creating OpenAL context: ok
...making context current: ok
OpenAL settings:
AL_VENDOR: OpenAL Community
AL_RENDERER: OpenAL Soft
AL_VERSION: 1.1 ALSOFT 1.15.1
AL_EXTENSIONS: AL_EXT_ALAW AL_EXT_DOUBLE AL_EXT_EXPONENT_DISTANCE AL_EXT_FLOAT32 AL_EXT_IMA4 AL_EXT_LINEAR_DISTANCE AL_EXT_MCFORMATS AL_EXT_MULAW AL_EXT_MULAW_MCFORMATS AL_EXT_OFFSET AL_EXT_source_distance_model AL_LOKI_quadriphonic AL_SOFT_buffer_samples AL_SOFT_buffer_sub_data AL_SOFTX_deferred_updates AL_SOFT_direct_channels AL_SOFT_loop_points AL_SOFT_source_latency
Available OpenAL devices:
- ALSA Default
- bcm2835 ALSA, bcm2835 ALSA (CARD=ALSA,DEV=0)
- bcm2835 ALSA, bcm2835 IEC958/HDMI (CARD=ALSA,DEV=1)
Current OpenAL device:
- OpenAL Soft
Number of OpenAL sources: 31
Starting Ogg Vorbis.
Ogg Vorbis not initializing.
Sound sampling rate: 0
LoadLibrary(ref_gl1.so)
Refresh: Yamagi Quake II OpenGL Refresher
Client: 7.11pre
Refresher build options:
 + Retexturing support
 - Gamma via X11
SDL version is: 2.0.7
SDL video driver is "x11".
setting mode 4: 640 480
MESA-LOADER: failed to retrieve device information
R_InitContext(): Got an OpenGL version 0.0 context - need (at least) 1.4!
ref_gl::R_SetMode() - invalid mode
ref_gl::R_Init() - could not R_SetMode()
ERROR: Loading ref_gl1.so as rendering backend failed!
Cmd_RemoveCommand: force_centerview not added
Cmd_RemoveCommand: +mlook not added
Cmd_RemoveCommand: -mlook not added
Shutting down input.
recursive shutdown
Error: Couldn't load a rendering backend!
Does anyone know whats wrong. I tried everything..rebuilding a secound time..no errors. Now I'm considerably pissed. :oops: :?
spidey57
Sun Feb 11, 2018 2:51 pm
If you are struggling with yamagi quake2 try q2pro:-
http://skuller.net/q2pro/
https://github.com/AndreyNazarov/q2pro
Latest commit 924ff39 on 3 Dec 2014
Tested on a RaspberryPi3
using
RASPBIAN STRETCH WITH DESKTOP
Image with desktop based on Debian Stretch
Version:November 2017
Release date:2017-11-29
Kernel version:4.9
unzip
q2pro-master.zip
sudo apt-get install libsdl1.2-dev
make
when compiled you need to read the INSTALL file to cp the pak files as usual and
cp src/client/ui/q2pro.menu ~/.q2pro/baseq2/
so that the menu works correctly then change to windowed mode
turn on opengl in raspi-config & reboot
You can play online if you paste a server IP address from
http://q2servers.com
then open console and type
connect ipaddress
If too dark
Check your ‘intensity’ and ‘gl_modulate’ settings.
set both to 2.
Happy fragging!
spidey57
Sat Mar 17, 2018 4:14 pm
Quake2 server running on RaspberryPiZero-W RaspberryPi2 or RaspberryPi3.
Do you have a spare RpiZeroW gathering dust? Use it as a Quake2 server.
This assumes you have successfully compiled and configured YamagiQ2, Rogue and Xatrix
as detailed earlier in this thread.
It is quicker to configure the server(s) on a RaspberryPi3 and then move the SD card to the Rpi0w/2.
Once configured reboot the Rpi0/2/3 into CLI mode for better performance.
No need to configure all the servers just pick the one you need.
No additional software required for 1.1, 1.2, 1.3
1.1 standard dm
1.2 xatrix dm
1.3 rogue dm
1.1 create server.cfg in quake2\baseq2 with these params
set hostname "rpi standard dm"
set deathmatch 1
set maxclients 8
set fraglimit 50
set timelimit 20
set sv_maplist "q2dm1 q2dm2 q2dm3 q2dm4 q2dm5 q2dm6 q2dm7 q2dm8"
map q2dm1
to start the server ./q2ded +set game baseq2 +exec server.cfg
1.2 create server.cfg in quake2\rogue with these params
set hostname "rpi rogue dm"
set deathmatch 1
set maxclients 8
set fraglimit 50
set timelimit 20
set sv_maplist "rdm1 rdm2 rdm3 rdm4 rdm5 rdm6 rdm7 rdm8 rdm9 rdm10 rdm11 rdm12 rdm13 rdm14"
map rdm1
to start the server ./q2ded +set game rogue +exec server.cfg
1.3 create server.cfg in quake2\xatrix with these params
set hostname "rpi xatrix dm"
set deathmatch 1
set maxclients 8
set fraglimit 50
set timelimit 20
set sv_maplist "xdm1 xdm2 xdm3 xdm4 xdm5 xdm6 xdm7"
map xdm1
to start the server ./q2ded +set game xatrix +exec server.cfg
Happy fragging!
spidey57
Wed Mar 21, 2018 5:32 pm
2 more Quake2 server mods that run fine on any rpi0w, rpi0, rpi2, rpi3.
This assumes you have successfully compiled and configured YamagiQ2 as detailed earlier in this thread.
1.4 Capture The Flag (CTF) and
1.5 Lithium (LITH)
Files required:-
https://www.yamagi.org/quake2/
Three Wave Capture The Flag: Three Wave CTF Version 1.05 (06/08/2017)
https://deponie.yamagi.org/quake2/quake ... .05.tar.xz
https://deponie.yamagi.org/quake2/idstu ... ll-ctf.exe
https://github.com/mattayres/li2mod
Latest commit 6415a7e on Sep 23, 2010
https://github.com/mattayres/li2mod/archive/master.zip
1.4 create a ctf folder alongside baseq2
unzip quake2-ctf-1.05.tar.xz
make
cp game.so into the ctf folder
copy pak0.pak from q2-3.20-x86-full-ctf.exe into ctf folder
create server.cfg in quake2/ctf with these params
set hostname "rpi ctf"
set deathmatch 1
set maxclients 8
set fraglimit 50
set timelimit 20
set sv_maplist "q2ctf1 q2ctf2 q2ctf3 q2ctf4 q2ctf5"
map q2ctf1
to start the server ./q2ded +set game ctf +exec server.cfg
1.5 create a lithium folder alongside baseq2
unzip li2mod-master.zip
make
copy the contents of the li2mod-master/lithium folder to the lithium folder created earlier
cp gamei386.so to game.so
cp lithium.cfg to server.cfg
edit server.cfg
set hostname "rpi lithium"
to start the server
./q2ded +set dedicated 1 +set game lithium +exec server.cfg
Happy fragging!
jdonald
Fri Nov 23, 2018 4:09 am
Hey JohnnyDub, sorry you never got an answer to this in the past 9 months. For you or anyone else who comes across the same problem I have the following thoughts on troubleshooting:
• Did you remember to run sudo raspi-config and enable the full OpenGL driver with KMS? (Included in spidey57's original instructions, but could have been missed in all the followup.)
• Confirm that the kernel module loads on boot. Run lsmod | grep vc4
• Check if it user software can see it by running sudo apt install mesa-utils, check glxinfo for version 1.4 or higher, and confirm you're getting 60 fps if you run glxgears. Unfortunately there's a lot that can still go wrong with the graphics driver ranging from a patched kernel to the wrong hardware.
• Among the latter requirements, can you confirm you're testing on a Pi 2 or newer? Full OpenGL is not supported on the Pi 1 or Zero.
• Don't use BerryBoot, which mandates the legacy driver.
• When all else fails there's rpi-update which updates the kernel, firmware, and VideoCore blobs.
MattPurland
Wed Jul 01, 2020 10:00 am
Hi Guys,
 + SDL2
 - CD audio
 + OGG/Vorbis
 + OpenAL audio
 + Zip file support
Platform: Linux
Architecture: arm
execing default.cfg
execing yq2.cfg
execing config.cfg
OpenAL settings:
- ALSA Default
- OpenAL Soft
Client: 7.11pre
 - Gamma via X11
recursive shutdown
Apologies for resurrecting an old thread, but I'm getting the same issue. Though with the latest commit, instead of failing completely, it's falling back to the software renderer - which does run at full speed on the RPi4. So it's at least playable.
I may contact the developer and get their input - as the RPi4 does support OpenGL 2.1, so the OpenGL 1.4 renderer should work (I pressume, I've no idea on OpenGL backwards compatibility)
Gavinmc42
Wed Jul 01, 2020 10:04 am
Vulkan based vkQuake?
viewtopic.php?f=63&t=277779
I'm dancing on Rainbows.
MattPurland
Wed Jul 01, 2020 11:23 am
I literally just found Yamagi Quake 2 has a Vulkan branch:
https://github.com/yquake2/yquake2/tree/ref_vk
I don't have a RPi3 free to test this with the new Vulkan driver, and there's not a Vulkan driver for RPi4 (yet)
Gavinmc42
Wed Jul 01, 2020 1:11 pm
Pi4 Vulkan
viewtopic.php?f=63&t=277125&p=1678832&h ... n#p1678832
I did get it working and then broke it ;)
A path issue or missed step?
I got a bunch of Vulkan examples and demos and they all compiled in 32 and 64bit but popped an error when trying to run.
I probably should go back and try again.
It is probably not far away now for some beta guys, at least for 32bit.
MattPurland
Wed Jul 01, 2020 2:28 pm
Pi4 Vulkan
I'm aware of the new Vulkan driver, but wasn't sure what state it's in as there's no official release
MattPurland
Wed Jul 01, 2020 3:20 pm
Just tried the Vulkan version of yQuake2 on a RPi4 and got the following error:
...found 1 Vulkan-capable device(s)
Could not find a suitable physical device!
R_InitContext() - could not initialize Vulkan!
Shutting down Vulkan
Real display mode: 800x480@60 (vid_fullscreen: 0)
Enabled extensions: VK_KHR_surface VK_KHR_xlib_surface
...created Vulkan instance
...created Vulkan surface
vk: error: v3dv_GetPhysicalDeviceProperties2: ignored VkStructureType 1000212000:VK_STRUCTURE_TYPE_PHYSICAL_DEVICE_PCI_BUS_INFO_PROPERTIES_EXT
WARNING: v3dv is neither a complete nor a conformant Vulkan implementation. Testing use only.
Looks like we'll have to wait for the driver to be more complete
spidey57
Fri Jul 03, 2020 9:41 pm
Hi Matt
Just ran through compiling this on Rpi4 4gb (its been a while)...
get source code
https://deponie.yamagi.org/quake2/quake2-7.43.tar.xz
extract from archive
sudo apt-get update
sudo apt-get install build-essential libgl1-mesa-dev libsdl2-dev libopenal-dev libcurl4-openssl-dev
make
compile ok
copy
pak0.pak 175.5mb
into /release/baseq2
cd /quake2-7.43/release
./quake2
defaults to opengl 1.4
running ok here
My version of Raspbian:-
cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
cat /etc/rpi-issue
Raspberry Pi reference 2020-02-13
Generated using pi-gen, https://github.com/RPi-Distro/pi-gen, 5f884374b6ac6e155330c58caa1fb7249b8badf1, stage4
Hope this helps
Gavinmc42
Mon Jul 27, 2020 9:54 am
Have not been on my Pi's for a few days, just noticed this.
vkquake is working.
http://planet.igalia.com/
Return to “Gaming”
