pi_amateur
Easy Way to code Raspberry with blocks
Sat Jan 20, 2018 11:19 pm
Hello Everyone; in this topic i will talk about http://www.raspblocks.com/
Raspblocks is a code generator for Raspberry boards. You don’t need any coding skills to program it and make your projects.
Here is a Youtube tuorial Blink Led : https://www.youtube.com/edit?o=U&video_id=nNh3GG2TlEU
Link to Start Coding http://generator.raspblocks.com
Have Fun ;)
Re: Easy Way to code Raspberry with blocks
Sun Jan 21, 2018 5:33 pm
What does this give me that I don't already get with Scratch or Scratch2 (which are built-in to Raspbian)?
mattmiller
Sun Jan 21, 2018 6:01 pm
If you try it out in the last link - it seems to generate runnable Python code
Very nice work :)
Sun Jan 21, 2018 6:05 pm
As I said what does it give me that isn't in Scratch or Scratch2?
mahjongg
Sun Jan 21, 2018 6:39 pm
the answer is "runnable python code".
but even when it wouldn't, it gives us choices.
great work pi_amateur, and don't mind dougie, he can be a bit negative sometimes... :roll:
B.Goode
Sun Jan 21, 2018 6:51 pm
No harm in having other options.
Long standing forum member @AllAboutCode has a similar offering at http://edublocks.org/
The website for edublocks looks more polished to me, and it is capable of generating code for a micro:bit as well as for an RPi.
Sun Jan 21, 2018 7:56 pm
With so much pre-existing choice why do we need a new website to do the same stuff we can already do?
The proliferation of programming languages is one of the great problems with the software industry. We've got a wheel that's already had the corners knocked off, why do we need snow tyres when it's not snowing? Do we really need a re-spin of an existing thing every week?
scruss
Sun Jan 21, 2018 9:52 pm
Yes, yes we do. Because some tools work better for some people. I've been having quite a bit of fun using Blocks with a micro:bit, so I really want to give this a shot. But I've also seriously tried shell scripting in PostScript¹, something I don't think anyone else would even want to try or use even if they had to.
I mean, I check the Days Since Last JavaScript Framework site frequently. I know it's absurd. But there are sometimes some neat ideas that come out.
¹: PostScript: a page-description language notable for using stack-based notation and mixing code and data all in the one stream, but it can be coerced into doing file operations. You've probably got the GhostScript (gs) PostScript interpreter installed on your Raspberry Pi already. The tiny PS program ‘1 1 10 { == } for’ will print the numbers 1…10. Adobe's PostScript Language Tutorial & Cookbook (search for "adobe blue book") is freely available if anyone feels like trying this somewhat niche language.
Update: seems I accidentally linked to a js bitcoin mining site. Sorry about that; link removed. Was hoping to find the cartoon of the same name.
Pronouns: he/him
Sun Jan 21, 2018 10:24 pm
scruss,
Please don't link us to pages that run coin mining javascript in our browsers. Especially when they are otherwise useless.
...PostScript¹, something I don't think anyone else would even want to try or use even if they had to.
Ha! I did. First time I ever had access to a laser printer. A great big office printer back in 1980 something. Actual work stopped for a few days as I had to check out this weird PostScript thing. Managed to make some quite funky graphics with it.
Never again....
scruss
Mon Jan 22, 2018 12:02 am
Nice work! It even ran on my Pi Zero over VNC.
In the Blink example — http://www.raspblocks.com/blink.html — you might want to change the 500 second blink delay down to 1. I don't really want to wait 8' 20" between blinks.
Pronouns: he/him
procount
Mon Jan 22, 2018 9:50 am
The Ultrasonic distance measurement code looks very similar to your pwm code.....
You might want to correct that.
PINN - NOOBS with the extras... https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=142574
bensimmo
Mon Jan 22, 2018 1:17 pm
Scratch 3 is due out, testing versions should be due out shortly (end of January iirc from the Twitter post).
Just to add another one ;-)
Though these 'blocks' should all be accessible to anyone that has used blocks based, or scratch, before.
Google App creater uses the same basis.
bensimmo
Mon Jan 22, 2018 1:26 pm
Have Fun ;)
My opinion is you should move from the RPI.GPIO backend to the GpioZero module instead.
They use easy to access blocks of code that should be transferable pretty easily.
As things come along adding more should be simple, that and it gives you a target of devices you can aim for.
Plus you'll be able to switch to pinfactories and pigpio easily and remotely program from another device to the Pi.
e.g. the x86 desktop to the PiZ
Your site doesn't work very well at all on a mobile device.
Nice to see how it progresses :-)
ejolson
Mon Jan 22, 2018 5:47 pm
One of the difficulties observed with Scratch is that students get stuck and never make the transition from a picture-based programming environment to a written one. From a computer literacy point of view, being able to use a written language is important. It seems likely that being able to generate equivalent Python code would significantly reduce the barriers that prevent some students from making the transition.
As an aside, my brother just started an introduction to programming course in college. The first week they used a flow-charting system that could output Python, C++, JavaScript and many others to compare how similar the same algorithm looks in the different programming languages.
mattmiller
Mon Jan 22, 2018 8:06 pm
That's a good idea :)
Mon Jan 22, 2018 8:24 pm
ejolson,
...they used a flow-charting system that could output Python, C++, JavaScript and many others to compare how similar the same algorithm looks in the different programming languages.
I would love to see the output of said flow-charting system.
I can imagine that any traditional flow chart design looks much the same in any traditional programming language. Give or take the syntactic differences.
But Javascript is based on an asynchronous, event driven programming model. Not something that is amenable to a typical flow chart design.
mattmiller
Mon Jan 22, 2018 9:02 pm
I just call it witchcraft!
ejolson
Tue Jan 23, 2018 12:24 am
I think he said it was called flowgorithm. I haven't tried it. I think they were only using it for a week or so to get started thinking about what computers do and how--a sort of educational icebreaker so that students can get involved right away. It's currently only available for Microsoft Windows. It would be interesting if a version for Raspberry Pi were ever released.
asandford
Tue Jan 23, 2018 1:04 am
Ironically, Node-red is very good at being a batch scheduler with exception handling (although the scipts I run are shell scripts).
asandford
Tue Jan 23, 2018 1:06 am
Understatement of the year
Tue Jan 23, 2018 9:13 am
node-red is very different from the traditional idea of flow charts as presented by flowgorithm and other block structured programming tools.
Flow charts are all about the control flow of a program. With their diagramatic representations of expressions, decision statements, loops, etc.
node-red is a picture of data flows.
It's not clear to me how a flowcharting tool, or these new block based attempts, can produce sensible Javascript code.
hippy
Tue Jan 23, 2018 9:38 am
I think you are confusing how node-red uses Javascript, leverages and enhances it and what Javascript is. Javascript can be used as an entirely traditional procedural language.
Windows Script Host (WSH) used to run traditional Javascript programs. Many Block-style editors produce Javascript code. It is perfectly possible to have event driven Javascript in Block-style programming.
ExpertDeveloper
Tue Jan 23, 2018 11:34 am
Correct Node-red is a good batch scheduler and has the exception handling feature.
App Developer
asandford
Wed Jan 24, 2018 2:01 am
I have no idea what node-red does 'behind the scenes', but I use it as a scheduler like Autosys ~2007 (I've not used that since), and it's very much cheaper
asandford
Wed Jan 24, 2018 2:25 am
In my mind a program flow chart is a data flow chart
