i updated PINN 2.4.4c to PINN 2.4.5 by using the build-in update option.
i have an issue with reinstalling retropie.
i have retropie 4.2 installed (by using previous version of PINN 2.4.4c) and thought i can reinstalling it to retropie 4.3 in PINN 2.4.5.
but there i get an error "File Not Found" (root_rp4.tar.xz)
(i haven't setted up retropie 4.2 - so i thought that option would be the simplest and cleanest to get retropie 4.3 to SD card)
and the background=r,g,b option does not change the background of all stages of PIN boot process.
at boot with the logo, the background option takes effect. but the following boot menu where you chose where to boot into of the installed OS is still white.
e.g.
when booting and holding left [shift]-key, PINN starts in the menu to maintain OS. there all the backgrounds ist changed.
but by using exit you change to the boot menu, and there the background is back to bright white.
