Hmm, if you want to test transceivers you generally buy them in pairs so they can talk to each other. That's a pretty fancy one, the receivers and transmitters I have are basically a single transistor with a crystal. You can find those for around $3. But the two types aren't very compatible.
If you have access to an rtl2832 dongle to serve as a receiver, try running rtl_433 on it.
https://github.com/merbanan/rtl_433 I've been using it about a year and a half logging temperature data from an Oregon Scientific outdoor temperature sensor that transmits in the 433 band. It should be smart enough to decode the numbers sent from the other end. As for any software that came with yours I have no idea. You could maybe build rtl_433 under Windows, it's mostly for Linux. You'd need at least a C compiler. Dealing with USB is more problematic under Windows than Linux, you should probably have a copy of Zadig running.
Spend at least the $11 to get a ZeroW and have another Linux machine. $35 for a Pi 3B and it's about 4 times as fast. Actually a Zero might not be fast enough for this, I haven't tried it. Rtl2832 dongles start under $20. There are many brands, I have 3 from here:
http://www.nooelec.com/store/
When rtl_433 starts up it lists what drivers are built in, even with the old version I have I see:
Registering protocol "Silvercrest Remote Control"
Registering protocol "Rubicson Temperature Sensor"
Registering protocol "Prologue Temperature Sensor"
Registering protocol "Waveman Switch Transmitter"
Registering protocol "Steffen Switch Transmitter"
Registering protocol "ELV EM 1000"
Registering protocol "ELV WS 2000"
Registering protocol "LaCrosse TX Temperature / Humidity Sensor"
Registering protocol "Acurite 5n1 Weather Station"
Registering protocol "Acurite Temperature and Humidity Sensor"
Registering protocol "Oregon Scientific Weather Sensor"
Registering protocol "Mebus 433"
Registering protocol "Intertechno 433"
Registering protocol "KlikAanKlikUit Wireless Switch"
Registering protocol "AlectoV1 Weather Sensor (Alecto WS3500 WS4500 Ventus W155/W044 Oregon)"
Registering protocol "Cardin S466-TX2"
Registering protocol "Fine Offset Electronics, WH-2 Sensor"
Registering protocol "Nexus Temperature & Humidity Sensor"
Registering protocol "Ambient Weather Temperature Sensor"
Registering protocol "Calibeur RF-104 Sensor"
Registering protocol "X10 RF"
Registering protocol "DSC Security Contact"
Registering protocol "Brennstuhl RCS 2044"
Registering protocol "GT-WT-02 Sensor"
Registering protocol "Danfoss CFR Thermostat"
Registering protocol "Energy Count 3000 (868.3 MHz)"
Registering protocol "Valeo Car Key"
Registering protocol "Chuango Security Technology"
Registering protocol "Generic Remote SC226x EV1527"
Registering protocol "TFA-Twin-Plus-30.3049 and Ea2 BL999"
Registering protocol "Fine Offset WH1080 Weather Station"
Registering protocol "WT450"
Registering protocol "LaCrosse WS-2310 Weather Station"
Registering protocol "Esperanza EWS"
Registering protocol "Efergy e2 classic"
Registering protocol "Inovalley kw9015b rain and Temperature weather station"
Registering protocol "Generic temperature sensor 1"
Registering protocol "Acurite 592TXR Temperature/Humidity Sensor and 5n1 Weather Station"
Registering protocol "Acurite 986 Refrigerator / Freezer Thermometer"
Registering protocol "HIDEKI TS04 Temperature and Humidity Sensor"
Registering protocol "Watchman Sonic / Apollo Ultrasonic / Beckett Rocket oil tank monitor"
Registering protocol "CurrentCost Current Sensor"
Registering protocol "emonTx OpenEnergyMonitor"
Registering protocol "HT680 Remote control"
Registering protocol "S3318P Temperature & Humidity Sensor"
Registering protocol "Akhan 100F14 remote keyless entry"
Registering protocol "Quhwa"
Registering protocol "OSv1 Temperature Sensor"
Registering protocol "Proove"
Registering protocol "Bresser Thermo-/Hygro-Sensor 3CH"
Registering protocol "Springfield Temperature and Soil Moisture"
Registering protocol "Oregon Scientific SL109H Remote Thermal Hygro Sensor"
Registering protocol "Acurite 606TX Temperature Sensor"
Registering protocol "TFA pool temperature sensor"
Registering protocol "Kedsum Temperature & Humidity Sensor"
Registering protocol "blyss DC5-UK-WH (433.92 MHz)"
Registering protocol "Steelmate TPMS"
Registering protocol "Schraeder TPMS"
Registering protocol "LightwaveRF"
Registering protocol "Elro DB286A Doorbell"
