hjdev
Color incorrect problems with rpi zero with DPI display
Fri Jan 12, 2018 1:34 pm
Hello, I've got probelms with pi zero with DPI display.
Please forget underscan problem.
All lines are connected correctly.
The problem is:
The Pi logo on top-left on screen shows invalid color of pi logo.
I ussed TM035KDH03 display.
http://datasheet.octopart.com/TM035KDH0 ... 047836.pdf
And here is my config.txt:
# not sure dtoverlay
dtoverlay=dpi24
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
overscan_left=100
overscan_right=-100
overscan_top=0
overscan_bottom=0
framebuffer_width=320
framebuffer_height=240
dtparam=spi=off
dtparam=i2c_arm=off
enable_dpi_lcd=1
dpi_group=2
dpi_mode=87
display_default_lcd=1
dpi_output_format=57367
Thanks for your help. :D
6by9
Re: Color incorrect problems with rpi zero with DPI display
Fri Jan 12, 2018 3:36 pm
Based on your colour bars gif thumbnail, normally they are:
grey, yellow, cyan, green, magenta, red, blue.
whereas you've got blue then red at the right hand end.
For a first test, try setting dpi_output_format to 57383 which is changing the rgb order from DPI_RGB_ORDER_RGB to DPI_RGB_ORDER_BGR (see https://www.raspberrypi.org/documentati ... /README.md).
