pwinwood
Problem with installing libgtk-3-dev on Raspberry Pi Desktop
Fri Jan 05, 2018 12:49 pm
I am attempting to build my project on Raspberry Pi Desktop.
To achieve this I need to install the gtk 3 development package but there is a dependency problem.
>sudo apt-get install libgtk-3-dev
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libgtk-3-dev : Depends: libgtk-3-0 (= 3.22.11-1) but 3.22.11-1+rpi3~iso is to be installed
Depends: gir1.2-gtk-3.0 (= 3.22.11-1) but 3.22.11-1+rpi3~iso is to be installed
E: Unable to correct problems, you have held broken packages.
I know how to overcome this by downloading the deb package and installing it manually using dpkg.
Perhaps this should be fixed in the repository?
ShiftPlusOne
Re: Problem with installing libgtk-3-dev on Raspberry Pi Desktop
Fri Jan 05, 2018 1:00 pm
Could you run apt update and try again?
Fri Jan 05, 2018 1:04 pm
You are using Debian Stretch with RPD fully updated prior to attempting to install packages ??
https://www.raspberrypi.org/downloads/r ... i-desktop/
jonwitts
Raspberry Pi Certified Educator
Fri Jan 05, 2018 1:48 pm
Running:
sudo apt-get update && sudo apt-get dist-upgrade -y
followed by:
sudo apt-get install devscripts debhelper cmake libldap2-dev libgtkmm-3.0-dev libarchive-dev libcurl4-openssl-dev intltool
now allows me to successfully install all of the dependencies to build the latest version of PiServer.
Thanks!
pwinwood
Fri Jan 05, 2018 9:54 pm
Yes fixed thank you :D
Paul
Return to “Raspberry Pi Desktop for PC and Mac”
