WillBoxGaming1
Power Supply for a Raspberry Pi 3
Thu Jan 04, 2018 7:14 pm
Hello there! First of all, sorry for the stupid question :P
Im currently using the power supply provided in this kit: https://www.52pi.com/all-products/266-t ... el-bb.html
However, time to times, a lightning bolt appears on the corner of my screen. Secondo, atleast one time per day, my Pi crashes in a way that I didnt knew it was possible! Let me explain:
My Pi3 have:
- A fan (from the kit above) connected to these pins: Image
- Wireless mouse
- Apple keyboard
So when my Pi crashes, the lightning bolt appears for a few seconds, the fan goes litteraly CRAZY (gets really fast and loud) and the red led is flashing. Of course, when this happens, I lost the signal on my TV. When the power goes OK again, my Pi simply reboots.
So now that I know that my "charger" is defective, now I want to buy a new one from amazon.
Im planning on overclocking my Pi @1.35Ghz, with the fan running. I was planning about buying this one:
https://www.amazon.com/NorthPada-Raspbe ... op?ie=UTF8
Am I doing the good choice? Sorry for the long post! XD
Any help is appreciated, thanks guys.
Re: Power Supply for a Raspberry Pi 3
Thu Jan 04, 2018 7:19 pm
My Pi3 have:
- Wireless mouse
- Apple keyboard
http://www.microcenter.com/product/4626 ... 5A_-_White
Retired disgracefully.....
rpiMike
Thu Jan 04, 2018 7:22 pm
As fruitoftheloom suggests - buy the official 5.1 Volt 2.5 Amp 18AWG cable psu (built in cable, no power switch)
WillBoxGaming1
Thu Jan 04, 2018 7:29 pm
So even with a 1.35Ghz overclock and a fan on it, I should be okay right?
Thu Jan 04, 2018 7:35 pm
Yes it is a good stable PSU:
https://www.raspberrypi.org/help/faqs/#powerReqs
rpiMike
Thu Jan 04, 2018 7:36 pm
Yes, my Pi3 is overclocked with fan.
Thu Jan 04, 2018 7:37 pm
There are no guarantees with overclocking.
Try it and see. It may work or it may not.
rhubarbdog
Fri Jan 05, 2018 9:34 am
The information regarding the fan going crazy before the raspberry pi dies. Is there enough current supplied to those gpio pins to power a fan. I would have thougth a transistor and seperate power in the collector emitter circuit.
davidcoton
Fri Jan 05, 2018 10:26 pm
Those pins (as per photo) are not gpio, they are power pins on the GPIO header. Permanently on with plenty of oomph (that is a technical term worth learning :lol: ). In fact the +5V pin is what you would use when a fan is conneccted via a transistor.
Signature retired
