darthpaul74
Looping multiple videos with OMX player
Wed Sep 20, 2017 8:07 pm
Im trying to loop multiple videos using OMX player.
The following command works great for one video in /home/pi/.config/lxsession/LXDE-pi/autostart
x-terminal-emulator -e omxplayer --loop /home/pi/test1.mp4
But I'm not having much luck finding documentation on using several videos.
Any help would be greatly appreciated!
RobSteele
Re: Looping multiple videos with OMX player
Mon Oct 16, 2017 12:37 pm
I'm actually trying to do the same and all of the tutorials I have found are dated and do not seem to work anymore. Anyone know of any newly updated tutorials?
tvjon
Tue Oct 17, 2017 5:38 pm
So you mean to play several videos, & then repeat playing those videos?
Tutorials? Where? How did you use them?
You can try this fairly simplistic approach:
loop-several.sh.zip
(267 Bytes) Downloaded 839 times
Place this file in one of your executable paths, eg.,
/home/pi/bin
then from the folder containing your videos to loop:
$ loop-several.sh
RobSteele
Sat Dec 23, 2017 10:46 pm
thanks tvjon, does this work for using a usb thumb drive to hold the videos ?
tvjon
Mon Dec 25, 2017 8:23 am
You are welcome.
Yes, any attached storage that the RPi knows about will work.
Also, X-windows is not required, so Raspbian-lite will work for example.
Omxplayer is a very useful application. The script can also be used for audio files, so handy in a museum for example.
Attached is an improved version.
loop-several.sh.zip
(292 Bytes) Downloaded 440 times
kgn
Mon Feb 19, 2018 10:17 am
between the two videos comes a desktop view. How to play all videos unbroken continuum.. :?:
tvjon
Tue Feb 20, 2018 8:07 pm
Well, one simple way is to set your RPi to boot to cli.
When it has booted to the console prompt, type
startx
& you'll arrive at your desktop.
When you're ready to start your videos, mouse to the Raspberry menu, select the Shutdown submenu, then press on
Exit to cammand line
$ cd wherever-your-files-live
wherever-your-files-live $ loop-several.sh
I've also made a small change to one of the script's statements, attached.
loop-several.sh.zip
(290 Bytes) Downloaded 416 times
Return to “Raspbian”
