Hoping this will help with my problem lol
[17:13:59] [main/INFO]: [OptiFine] *** Reflector Forge ***
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.model.Attributes
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: mods.betterfoliage.client.BetterFoliageClient
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.common.asm.transformers.BlamingTransformer
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.event.world.ChunkWatchEvent$UnWatch
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.relauncher.CoreModManager
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.DimensionManager
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.GuiScreenEvent$DrawScreenEvent$Pre
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.GuiScreenEvent$DrawScreenEvent$Post
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.EntityViewRenderEvent$CameraSetup
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.EntityViewRenderEvent$FogColors
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.EntityViewRenderEvent$RenderFogEvent
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.common.eventhandler.Event
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.common.eventhandler.EventBus
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.common.eventhandler.Event$Result
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.property.ExtendedBlockState
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.client.FMLClientHandler
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.common.FMLCommonHandler
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: anh.getWaterColorMultiplier
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.addDestroyEffects
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.addHitEffects
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.canCreatureSpawn
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.canRenderInLayer
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.doesSideBlockRendering
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getBedDirection
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getExtendedState
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getFogColor
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getLightOpacity
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getLightValue
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getSoundType
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.hasTileEntity
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.isAir
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.isBed
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.isBedFoot
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.isSideSolid
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: and.isSideSolid
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: vg.canRiderInteract
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Field not present: vg.captureDrops
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Field not present: vg.capturedDrops
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: vg.shouldRenderInPass
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: vg.shouldRiderSit
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.event.ForgeEventFactory
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.ForgeHooks
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.ForgeHooksClient
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Field not present: ain.delegate
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.getDurabilityForDisplay
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.getRGBDurabilityForDisplay
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.isShield
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.onEntitySwing
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.shouldCauseReequipAnimation
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.showDurabilityBar
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: bwa.handleItemState
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: agv.hasOverlay
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: bhy.setKeyConflictContext
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: bhy.setKeyModifierAndCode
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: bhy.getKeyModifier
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.ForgeModContainer
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: bvv.parseFromReader
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: uz.shouldRenderHUD
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: uz.renderHUDEffect
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: va.isCurativeItem
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: avj.canRenderBreaking
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: avj.getRenderBoundingBox
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: avj.hasFastRenderer
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: avj.shouldRenderInPass
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: ceb$b.preDraw
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: ceb$b.postDraw
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: amu.countEntities
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: amu.getPerWorldStorage
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: amu.initCapabilities
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aym.getCloudRenderer
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aym.getSkyRenderer
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aym.getWeatherRenderer
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.client.GuiModList
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.property.IExtendedBlockState
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.model.IModel
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.IRenderHandler
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.ItemModelMesherForge
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.settings.KeyConflictContext
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.settings.KeyModifier
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.model.pipeline.LightUtil
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.MinecraftForge
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.MinecraftForgeClient
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.model.ModelLoader
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.gui.NotificationModUpdateScreen
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderBlockOverlayEvent$OverlayType
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.client.registry.RenderingRegistry
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderItemInFrameEvent
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderLivingEvent$Pre
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderLivingEvent$Post
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderLivingEvent$Specials$Pre
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderLivingEvent$Specials$Post
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.ScreenshotEvent
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.client.SplashProgress
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.event.world.WorldEvent$Load
[17:13:59] [main/INFO]: [OptiFine] *** Reflector Vanilla ***
[17:14:00] [main/INFO]: LWJGL Version: 2.9.4
[17:14:02] [main/INFO]: [OptiFine]
[17:14:02] [main/INFO]: [OptiFine] OptiFine_1.12.1_HD_U_C5
[17:14:02] [main/INFO]: [OptiFine] Build: 20170807-181132
[17:14:02] [main/INFO]: [OptiFine] OS: Linux (arm) version 4.4.38-v7+
[17:14:02] [main/INFO]: [OptiFine] Java: 1.8.0_151, Oracle Corporation
[17:14:02] [main/INFO]: [OptiFine] VM: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
[17:14:02] [main/INFO]: [OptiFine] LWJGL: 2.9.4
[17:14:02] [main/INFO]: [OptiFine] OpenGL: Gallium 0.4 on VC4 V3D 2.1, version 2.1 Mesa 17.0.7, Broadcom
[17:14:02] [main/INFO]: [OptiFine] OpenGL Version: 2.1.0
[17:14:02] [main/INFO]: [OptiFine] Maximum texture size: 2048x2048
[17:14:02] [Thread-3/INFO]: [OptiFine] Checking for new version
[17:14:02] [main/INFO]: [Shaders] ShadersMod version: 2.4.12
[17:14:02] [main/INFO]: [Shaders] OpenGL Version: 2.1 Mesa 17.0.7
[17:14:02] [main/INFO]: [Shaders] Vendor: Broadcom
[17:14:02] [main/INFO]: [Shaders] Renderer: Gallium 0.4 on VC4 V3D 2.1
[17:14:02] [main/INFO]: [Shaders] Capabilities: 2.0 2.1 - - -
[17:14:02] [main/INFO]: [Shaders] GL_MAX_DRAW_BUFFERS: 1
[17:14:02] [main/INFO]: [Shaders] GL_MAX_COLOR_ATTACHMENTS_EXT: 1
[17:14:02] [main/INFO]: [Shaders] GL_MAX_TEXTURE_IMAGE_UNITS: 16
[17:14:02] [main/INFO]: [Shaders] Load ShadersMod configuration.
[17:14:02] [main/INFO]: [Shaders] Save ShadersMod configuration.
[17:14:02] [main/INFO]: [Shaders] Shaders can not be loaded, Fast Render is enabled.
[17:14:02] [main/INFO]: [Shaders] No shaderpack loaded.
[17:14:02] [main/INFO]: Reloading ResourceManager: Default
[17:14:02] [main/INFO]: [OptiFine] *** Reloading textures ***
[17:14:02] [main/INFO]: [OptiFine] Resource packs: Default
[17:14:02] [Thread-3/INFO]: [OptiFine] Version found: C6
[17:14:04] [Sound Library Loader/INFO]: Starting up SoundSystem...
[17:14:04] [Thread-4/INFO]: Initializing LWJGL OpenAL
[17:14:04] [Thread-4/INFO]: (The LWJGL binding of OpenAL. For more information, see
http://www.lwjgl.org)
[17:14:04] [Thread-4/INFO]: OpenAL initialized.
[17:14:05] [Sound Library Loader/INFO]: Sound engine started
[17:14:12] [main/INFO]: [OptiFine] Mipmap levels: 4
[17:14:12] [main/INFO]: [OptiFine] Multitexture: false
[17:14:12] [main/INFO]: [OptiFine] BetterGrass: Parsing default configuration optifine/bettergrass.properties
[17:14:16] [main/INFO]: Created: 512x512 textures-atlas
[17:14:20] [main/WARN]: ERROR : Couldn't load Narrator library : Unable to load library 'fliteWrapper': Native library (linux-arm/libfliteWrapper.so) not found in resource path ([file:/home/xynus/.minecraft/libraries/optifine/OptiFine/1.12.1_HD_U_C5/OptiFine-1.12.1_HD_U_C5.jar, file:/home/xynus/.minecraft/libraries/net/minecraft/launchwrapper/1.12/launchwrapper-1.12.jar, file:/home/xynus/.minecraft/libraries/com/mojang/patchy/1.1/patchy-1.1.jar, file:/home/xynus/.minecraft/libraries/oshi-project/oshi-core/1.1/oshi-core-1.1.jar, file:/home/xynus/.minecraft/libraries/net/java/dev/jna/jna/4.4.0/jna-4.4.0.jar, file:/home/xynus/.minecraft/libraries/net/java/dev/jna/platform/3.4.0/platform-3.4.0.jar, file:/home/xynus/.minecraft/libraries/com/ibm/icu/icu4j-core-mojang/51.2/icu4j-core-mojang-51.2.jar, file:/home/xynus/.minecraft/libraries/net/sf/jopt-simple/jopt-simple/5.0.3/jopt-simple-5.0.3.jar, file:/home/xynus/.minecraft/libraries/com/paulscode/codecjorbis/20101023/codecjorbis-20101023.jar, file:/home/xynus/.minecraft/libraries/com/paulscode/codecwav/20101023/codecwav-20101023.jar, file:/home/xynus/.minecraft/libraries/com/paulscode/libraryjavasound/20101123/libraryjavasound-20101123.jar, file:/home/xynus/.minecraft/libraries/com/paulscode/librarylwjglopenal/20100824/librarylwjglopenal-20100824.jar, file:/home/xynus/.minecraft/libraries/com/paulscode/soundsystem/20120107/soundsystem-20120107.jar, file:/home/xynus/.minecraft/libraries/io/netty/netty-all/4.1.9.Final/netty-all-4.1.9.Final.jar, file:/home/xynus/.minecraft/libraries/com/google/guava/guava/21.0/guava-21.0.jar, file:/home/xynus/.minecraft/libraries/org/apache/commons/commons-lang3/3.5/commons-lang3-3.5.jar, file:/home/xynus/.minecraft/libraries/commons-io/commons-io/2.5/commons-io-2.5.jar, file:/home/xynus/.minecraft/libraries/commons-codec/commons-codec/1.10/commons-codec-1.10.jar, file:/home/xynus/.minecraft/libraries/net/java/jinput/jinput/2.0.5/jinput-2.0.5.jar, file:/home/xynus/.minecraft/libraries/net/java/jutils/jutils/1.0.0/jutils-1.0.0.jar, file:/home/xynus/.minecraft/libraries/com/google/code/gson/gson/2.8.0/gson-2.8.0.jar, file:/home/xynus/.minecraft/libraries/com/mojang/authlib/1.5.25/authlib-1.5.25.jar, file:/home/xynus/.minecraft/libraries/com/mojang/realms/1.10.17/realms-1.10.17.jar, file:/home/xynus/.minecraft/libraries/org/apache/commons/commons-compress/1.8.1/commons-compress-1.8.1.jar, file:/home/xynus/.minecraft/libraries/org/apache/httpcomponents/httpclient/4.3.3/httpclient-4.3.3.jar, file:/home/xynus/.minecraft/libraries/commons-logging/commons-logging/1.1.3/commons-logging-1.1.3.jar, file:/home/xynus/.minecraft/libraries/org/apache/httpcomponents/httpcore/4.3.2/httpcore-4.3.2.jar, file:/home/xynus/.minecraft/libraries/it/unimi/dsi/fastutil/7.1.0/fastutil-7.1.0.jar, file:/home/xynus/.minecraft/libraries/org/apache/logging/log4j/log4j-api/2.8.1/log4j-api-2.8.1.jar, file:/home/xynus/.minecraft/libraries/org/apache/logging/log4j/log4j-core/2.8.1/log4j-core-2.8.1.jar, file:/home/xynus/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl/2.9.4-nightly-20150209/lwjgl-2.9.4-nightly-20150209.jar, file:/home/xynus/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl_util/2.9.4-nightly-20150209/lwjgl_util-2.9.4-nightly-20150209.jar, file:/home/xynus/.minecraft/libraries/com/mojang/text2speech/1.10.3/text2speech-1.10.3.jar, file:/home/xynus/.minecraft/versions/1.12.1-OptiFine_HD_U_C5/1.12.1-OptiFine_HD_U_C5.jar])
[17:14:21] [main/INFO]: [OptiFine] *** Reloading custom textures ***
