RichardBronosky
Creating /boot/ssh and /boot/wpa_supplicant.conf (for a headless setup) works, but how?
Tue Nov 28, 2017 6:55 am
Have you ever wondered HOW this works? I did. And it was quite the rabbit hole to go down.
  • First I Googled and found the documentation about creating the file /boot/ssh
  • I never managed to find any official documentation on creating the file /boot/wpa_supplicant.conf (Though I did find lots of references that stated that it did work.)
  • Then I studied https://github.com/RPi-Distro/pi-gen extensively.
  • But I couldn't find anything that looked for /boot/ssh or /boot/wpa_supplicant.conf
  • Then I started looking for packages that may contain the implementation.
    ~/src/pi-gen $ cat $(find stage[012] -type f -name '*package*') | tr " " "\n" | grep 'pi' | sort
    libraspberrypi-bin
    libraspberrypi-dev
    libraspberrypi-doc
    libraspberrypi0
    pi-bluetooth
    python-rpi.gpio
    raspberrypi-bootloader
    raspberrypi-net-mods
    raspberrypi-sys-mods
    raspi-config
    raspi-copies-and-fills
    rpi-update
  • I grabbed all the matching packages I could find in https://archive.raspberrypi.org/debian/pool/main/r/
  • I got lucky with raspberrypi-net-mods and raspberrypi-sys-mods
I finally discovered that it is a bit of systemd magic that makes each happen.
raspberrypi-net-mods.service
[Unit]
Description=Copy user wpa_supplicant.conf
ConditionPathExists=/boot/wpa_supplicant.conf
Before=dhcpcd.service
[Service]
Type=oneshot
RemainAfterExit=yes
ExecStart=/bin/mv /boot/wpa_supplicant.conf /etc/wpa_supplicant/wpa_supplicant.conf
ExecStartPost=/bin/chmod 600 /etc/wpa_supplicant/wpa_supplicant.conf
[Install]
WantedBy=multi-user.target
Notice the ConditionPathExists and ExecStart! That's pretty clever.
Similarly, but slightly more clever.
raspberrypi-sys-mods.sshswitch.service
[Unit]
Description=Turn on SSH if /boot/ssh is present
ConditionPathExistsGlob=/boot/ssh{,.txt}
After=regenerate_ssh_host_keys.service
[Service]
Type=oneshot
ExecStart=/bin/sh -c "update-rc.d ssh enable && invoke-rc.d ssh start && rm -f /boot/ssh ; rm -f /boot/ssh.txt"
[Install]
Now that I've uncovered this, I can finally finish the project I started with this thread nearly 5 years ago. It's been a long journey of discovery, this $35 whim I indulged in back in May 2012
-- Bruno Bronosky
1x RPi 1 (B)
1x RPi 1+ (B)
2x RPi 2
11x RPi 3
4x RPi Zero W
2x RPi camera module
3x AIY Voice kits
https://github.com/RichardBronosky/pi-gen-extender
https://github.com/RichardBronosky/raspbian-boot-setup
RichardBronosky
Re: Creating /boot/ssh and /boot/wpa_supplicant.conf (for a headless setup) works, but how?
Tue Jul 02, 2019 7:59 pm
That simply states that it works. It doesn't tell you how/why. My post is about the technical implementation.
-- Bruno Bronosky
1x RPi 1 (B)
1x RPi 1+ (B)
2x RPi 2
11x RPi 3
4x RPi Zero W
3x AIY Voice kits
Tue Jul 02, 2019 8:19 pm
You can create both of those on Windows with Notepad++.
/boot/ssh can be an empty file.
/boot/wpa_supplicant.conf needs to look like
country=GB
update_config=1
network={
        ssid="your WiFi SSID goes here"
        psk="your WiFi password goes here"
Note: change the country=?? line to have your ISO 2-char country code.
snaiperis
Sat Aug 22, 2020 10:48 am
This doesn't help to understand, how it works.
Thanks, Richard, this was what I was looking for.
Seeking Sooth
Thu Aug 27, 2020 3:19 pm
Richard, I completely get your quest and appreciate it!
Clever and Elegant.
Thanks.
Return to “Raspberry Pi OS”
