chowwh422
how to install TP-LINK TL-WN823N on Raspberry Pi 3
Sun Nov 19, 2017 12:25 am
Dear any master,
I have read many posts for installing TP-LINK TL-WN823N driver on Raspberry Pi 2. Try them all but still can't find one solution working on Pi 3.
for example: https://raspberrypi.stackexchange.com/q ... -tl-wn823n
pi@raspberrypi:~ $ lsusb
Bus 001 Device 006: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 001 Device 005: ID 2357:0109
Bus 001 Device 004: ID 03f0:034a Hewlett-Packard Elite Keyboard
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
May anyone share any experience here . thanks
Calvin
MrEngman
Re: how to install TP-LINK TL-WN823N on Raspberry Pi 3
Sun Nov 19, 2017 1:39 am
Dear any master,
Calvin
The TL-WN823N v2 you have uses the 8192eu driver. The driver in not included in the Raspbian image and needs installing.
I have a script that will install a driver I compile if you are using the RASPBIAN OS.
You can download and install the script using commands
sudo wget http://fars-robotics.net/install-wifi -O /usr/bin/install-wifi
sudo chmod +x /usr/bin/install-wifi
With the wifi dongle connected to the Pi to install the driver run command
sudo install-wifi
broe23
Sun Nov 19, 2017 3:14 am
You may have to go old school and use the Windows driver with NDiswrapper. The other would be to check Debian's repositories for those drivers for the chipset on the wifi adapter.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good.
brumorino
Tue Jun 12, 2018 9:08 pm
Dear any master,
Calvin
sudo install-wifi
TKS Bro worked for me!!
Can I use this driver for wifi acess point too?
wakeuteu
Wed Nov 21, 2018 5:58 pm
Hi, arriving late on this, but just completed adafruit how-to on Raspberry PI 2 and it works with a bit of adaptation for latest version.
(https://learn.adafruit.com/setting-up-a ... l-software)
Changes (wlan0 can have another name if you're using Raspberry PI 3):
1. Instead of using /etc/network/interfaces, I've added the definition block to /etc/dhcpcd.conf
interface wlan0
static ip_address=192.168.42.1/24
static ip6_address=fd0d:e8cf:c363:2605::1/64
static routers=192.168.42.1
2. Comment out driver line in the proposed /etc/hostapd/hostapd.conf version
3. No need for Update hostapd (maybe) section (kernel v4.14 at the time I'm writing this).
4. Did not need to remove wpa_supplicant. Beware of this if you want to keep using your Raspi 3 as a wifi client (I assume this is what you wanted buying an extra wifi device).
5. I used systemctl instead of service command
buzzlightyear2
Wed Apr 17, 2019 12:27 pm
Dear any master,
Calvin
sudo install-wifi
Thank you for the installation, it works as expected, very easy if you have a LAN connection. First time I did not have LAN connection, so I followed the script and manually executed the steps after downloading the driver package onto USB at another PC.
Upgrading is also seamless after a kernel upgrade. Thank you!
marcelogando
Wed Dec 16, 2020 1:20 am
The previous link has been expired.
Here's the new way to install it:
sudo wget http://downloads.fars-robotics.net/wifi-drivers/install-wifi -O /usr/bin/install-wifi
sudo install-wifi
