denismosolov
Web UI for creating Debian images
Sun May 22, 2016 10:22 pm
Hello!
Let me introduce https://cusdeb.com - a web UI for creating OS images. Just follow these steps to get your own customized Debian:
1. Select Raspberry Pi 2 or Raspberry Pi 3 under 'Target Device' and 'Debian Jessie' under 'Distro'.
2. Add packages from the official Debian repository.
3. Set up root password.
4. Choose language, timezone etc.
5. Download the image and write it to SD card.
Any comments and suggestions are welcomed!
denismosolov
Re: Create a customized Debian image for RPi using SaaS
Fri Dec 02, 2016 7:33 am
CusDeb alpha version released. It uses jessie/stretch bootstrap script for RPi2/RPi3 (32bit) until we've managed to use Linux 4.4
Any feedback are welcome!
cjan
Fri Dec 02, 2016 9:48 am
does it play under x86-debain only?
denismosolov
Fri Dec 02, 2016 5:39 pm
cjan wrote:does it play under x86-debain only?
It's armhf. It generates Debian Jessie images for Raspberry Pi 2/3.
cjan
Fri Dec 02, 2016 10:36 pm
but miss all dependency file to build and can not found from raspbian.
ps. does it play under x86-debain only? --> does it build under x86-debain.
denismosolov
Mon Dec 05, 2016 7:59 am
It builds under x86-debian, right. Sorry for the confusion.
denismosolov
Re: Web UI for creating Debian images
Mon Feb 20, 2017 7:39 pm
Added:
- More timezones and locales.
- E-mail notification when the image is built.
Fixed:
- Fix the initialization step failure when AdBlock is enabled in the browser
denismosolov
Tue Sep 19, 2017 5:43 pm
Added:
- Debian Stretch
Fixed:
- Bunch of issues
Thu Sep 21, 2017 4:58 am
No way am I going to use OS images created by some random stranger on the internet. No way can I hand over user names and passwords to my operating system installations.
I don't mean to imply there is any shenanigans going on here or that our OP means harm.
But this is nuts.
denismosolov
Sat Nov 11, 2017 7:14 am
Thanks for your comment.
Our goal is to develop a tool that can be used for generating OS images for various devices. We suppose our web-based tool is easy to use because it requires only a web-browser, but we realize nobody trust it. So, we start a new project called pieman and it's a bash script: https://github.com/tolstoyevsky/pieman
feelslikeautumn
Sat Nov 11, 2017 3:44 pm
Except pretty much all Linux OS images (including Raspbian) are created by some random stranger on the internet. Even if it is made by a group of people, they've probably never met in person and barely know each other.
Sun Nov 12, 2017 2:32 am
For free, open-source software then it's all about trust and being able to check the credentials so you know the stuff you're downloading is coming from the trusted source.
Note:The use of baseball bats for educational purposes is completely disallowed on this forum.
denismosolov
Thu Dec 07, 2017 1:16 pm
We replaced https://github.com/drtyhlpr/rpi23-gen-image with https://github.com/tolstoyevsky/pieman on https://cusdeb.com/en/
So, now CusDeb can build Raspbian Stretch, Ubuntu Xenial Xerus and Ubuntu Artful Aardvark(64 bit) images
denismosolov
Fri Mar 16, 2018 8:23 pm
We've added Devuan 1 «Jessie» support to https://github.com/tolstoyevsky/pieman and https://cusdeb.com
So, CusDeb can build customized Devuan 1 «Jessie» (32-bit) images for Raspberry Pi 2 and 3.
Return to “Debian”
