Wifi video
Hi, does anyone have or know of a video on the setup of a wifi adapter on the r-pi as I am struggling to understand the instructions
Re: Wifi video
1) plug in your usb wifi dongle
you can type lsusb to see if the usb device is detected.
lsusb
you can type iwconfig or ifconfig and should see wlan0 has appeared.
iwconfig
you can next see if your pi is picking up any available wifi networks by typing
sudo iwlist scan
If you get this I doubt any videos will help you
lo Interface doesn't support scanning.
eth0 Interface doesn't support scanning.
wlan0 No scan results
If you see available wifi networks though, your well on your way , look for the videos
lsusb
iwconfig
sudo iwlist scan
Re: Wifi video
uh, missed lsmod,
lsusb will list the devices installed
Bus 001 Device 004: ID 0846:4260 NetGear, Inc. WG111v3 54 Mbps Wireless [realtek RTL8187B]
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
lsmod will list the modules installed (the driver software)
lsmod,
Module Size Used by
ipv6 290227 18
fuse 73593 1
arc4 1319 2
rtl8187 50761 0
mac80211 253889 1 rtl8187
cfg80211 180459 2 rtl8187,mac80211
eeprom_93cx6 1643 1 rtl8187
spi_bcm2708 4815 0
i2c_bcm2708 3818 0
If you don't have the software for the device you can search for it
For me as my wifi dongle is same as example
sudo apt-cache search RTL818
only that does not seem to work !!!!!
sudo apt-cache search Realtec
firmware-realtek - Binary firmware for Realtek wired and wireless network adapters
so
sudo apt-get install firmware-realtek
followed by lsmod to check you got the firmware
and
sudo iwlist scan
but all I get is
I think its because I have a
realtek RTL8187B
lsmod,
Module Size Used by
ipv6 290227 18
fuse 73593 1
arc4 1319 2
rtl8187 50761 0
spi_bcm2708 4815 0
i2c_bcm2708 3818 0
so
and
sudo iwlist scan
but all I get is
realtek RTL8187B
