paulwratt
verify EXPR bug in SHELL
Thu Nov 09, 2017 1:21 pm
can a few people verify a bug in different versions of Raspbian, on a console:
expr 85 * 3
I dont use X, Bash is the $SHELL
I just verified this works:
expr 85 \* 3
Cheers
Paul
jahboater
Re: verify EXPR bug in SHELL
Thu Nov 09, 2017 1:28 pm
Try doing
echo *
You will see that the shell expands * into all the visible filenames in the current directory.
\* stops that expansion.
There is no bug.
n67
Thu Nov 09, 2017 1:29 pm
This has nothing to do with BASH (other than that is common behavior in all Unix shells) or the Pi. It is a basic limitation of 'expr'. As you've deduced, you need to escape any arguments to 'expr' that are "special" to the shell. This includes, as you've noted, the * character.
'expr' is pretty much obsolete in the modern world. Back in the day, it was all we had, but there are better tools available now.
Using bash, the simplest way to do math in the shell is to use $(()) like this:
$ echo $((85*3))
255
$ foo=85;bar=3
$ echo $((foo*bar))
255
Now, if you are maintaining old code that uses 'expr', then the original authors would have been aware of these limitations and coded accordingly. If you are writing new code, don't use 'expr'.
"L'enfer, c'est les autres"
G fytc hsqr rum umpbq rm qyw rm rfc kmbq md rfgq dmpsk:
Epmu Sn!
J lnacjrw njbruh-carppnanm vxm rb mnuncrwp vh yxbcb!
Thu Nov 09, 2017 1:30 pm
If you want to do complex maths in bash pipe it into bc with suitable use of apostropes and/or quotes.
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
piglet
Thu Nov 09, 2017 2:50 pm
Yup: echo '(85 * 3)^2'| bc
65025
Return to “Raspbian”
