Preetilatha
Wifi access point number of clients
Thu Nov 02, 2017 5:46 am
HI all,
I created a wifi access point with Rpi3. The number of devices that can be connected to the wifi access point is only 5 :cry: .
How to increase the number of clients connected to wifi access point?
Thanks in advance
SurferTim
Re: Wifi access point number of clients
Thu Nov 02, 2017 10:22 am
I haven't tried connecting that many clients, but what indication do you get that the RPi will not accept any more client associations?
New clients don't see the SSID?
See the SSID but won't associate?
Associate but don't get network settings?
My advice applies to RaspiOS only. Please mention if you use another OS.
Thu Nov 02, 2017 10:31 am
What's the range of addresses in your dnsmasq config?
 dhcp-range=192.168.3.14,192.168.3.44,255.255.255.0,24h
Preetilatha
Thu Nov 02, 2017 11:05 am
When I try to connect the 6th device , SSID is seen but its not getting associated. The wifi hotspot is not in range :(
Preetilatha
Thu Nov 02, 2017 11:10 am
In dhcpd.conf file my configurations are
subnet 192.168.42.0 netmask 255.255.255.0 {
range 192.168.42.10 192.168.42.50;
option broadcast-address 192.168.42.255;
option routers 192.168.42.1;
default-lease-time 600;
max-lease-time 7200;
option domain-name "local";
option domain-name-servers 8.8.8.8, 8.8.4.4;
SurferTim
Thu Nov 02, 2017 11:28 am
The hostapd service sets a default number of stations to 2007. Six stations should not exceed that.
# Maximum number of stations allowed in station table. New stations will be
# rejected after the station table is full. IEEE 802.11 has a limit of 2007
# different association IDs, so this number should not be larger than that.
# (default: 2007)
max_num_sta=255
https://w1.fi/cgit/hostap/plain/hostapd/hostapd.conf
Preetilatha
Fri Nov 03, 2017 6:32 am
HI,
Can I use external wifi adapter to increase the no of clients. If so, which wifi adapter can I use?
Fri Nov 03, 2017 11:38 am
This is not an adaptor problem, but a configuration one I think, but you could try a USB adaptor just to see if it makes a difference.
SurferTim
Fri Nov 03, 2017 11:53 am
Did you try adding this to /etc/hostapd/hostapd.conf?
max_num_sta=100
hanene
Mon Nov 11, 2019 1:57 pm
i have the same problem , can i know if you have found a solution ?
mina
Tue Nov 12, 2019 6:47 pm
Maintainer of MoodleBox, a Moodle server on Raspberry Pi
