UV4L supports the TC358743 chip now:
https://www.linux-projects.org/2017/07/ ... -tc358743/
- Contact: Website
Re: UV4L adds support for the TC358743 HDMI to MIPI converte
I can't seem to get this to work with a B101 and a Pi3. I keep getting "Remote I/O Error". I have tried many different changes of the raspicam config file (but, most importantly setting -tc358743:yes). I have ensured that both the Camera and I2C are enabled. I am not sure what else to try.
Is the uv4l-raspicam-extras package installed as well? It's required. Furthermore, it's exactly "tc358743 = yes" in the config file or "--tc358743=yes" from command line (I suggest modifying the config file).bryanbailes wrote:I can't seem to get this to work with a B101 and a Pi3. I keep getting "Remote I/O Error". I have tried many different changes of the raspicam config file (but, most importantly setting -tc358743:yes). I have ensured that both the Camera and I2C are enabled. I am not sure what else to try.
- Contact: Website
Yes, uv4l-raspicam-extras is installed. I have tried both adding tc358743=yes to the config file as well as utilizing the command line argument. I have also been testing the kernel driver being developed by 6by9, and it worked with that, so I know it is not the device. The second I installed uv4l, it stopped working with the 'Remote I/O error'. I have also tried with a clean install of Jessie, with no success.
pi@raspberrypi:/etc/uv4l $ sudo pkill uv4l
pi@raspberrypi:/etc/uv4l $ sudo apt-get install uv4l-raspicam-extras
Reading package lists... Done
Building dependency tree
uv4l-raspicam-extras is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
pi@raspberrypi:/etc/uv4l $ uv4l --driver raspicam --auto-video_nr --width 720 --height 480 --encoding mjpeg --framerate 60 --tc358743=yes
<notice> [core] Trying driver 'raspicam' from built-in drivers...
<warning> [core] Driver 'raspicam' not found
<notice> [core] Trying driver 'raspicam' from external plug-in's...
<notice> [driver] Dual Raspicam Video4Linux2 Driver v1.9.50 built Jul 2 2017
<notice> [driver] Selected format: 720x480, encoding: mjpeg, JPEG Video Capture
<notice> [driver] Framerate max. 60 fps
<notice> [driver] ROI: 0, 0, 1, 1
<notice> [core] Device detected!
<notice> [core] Registering device node /dev/video0
pi@raspberrypi:/etc/uv4l $ dd if=/dev/video0 of=snapshot.jpeg bs=11M count=1
dd: failed to open ‘/dev/video0’: Remote I/O error
There was a problem with the new debian packages. The following should fix everything:bryanbailes wrote:I installed uv4l, it stopped working with the 'Remote I/O error'. I have also tried with a clean install of Jessie, with no success.
sudo apt-get update
sudo apt-get install uv4l-tc358743-extras
- Contact: Website
Re: UV4L adds support for the TC358743 HDMI to MIPI converter
Im trying to use this but not working for me.
Im sure that the auvidea board its working as i can see it with raspivid.
I follow the instructions on https://www.linux-projects.org/uv4l/installation/ and i checked that tc358743=yes its in raspicam.conf.
I did and always get a black 1920x1080 screen...
¿What im doing wrong?
I did
black? You might need to skip the first frames? Check if you get any video from the streaming server web page in the first place.natxo wrote: ↑Tue Oct 31, 2017 6:53 pmI didand always get a black 1920x1080 screen...Code: Select all
Thanks will try what you say and post results
I'm also getting the "Remote I/O Error" with the tc358743 (B101):
I'm using Raspian stretch 2017-11-29 and uv4l is reporting v1.9.60. When not using uv4l (just raspivid) I'm able to get a 720p feed from the B101.
pi@raspberrypi:~ $ uv4l --driver raspicam --auto-video_nr --width 1280 --height 720 --encoding mjpeg --framerate 60 --tc358743=yes
<notice> [core] Trying to loading driver 'raspicam' from built-in drivers...
<notice> [core] Loading driver 'raspicam' from external plug-in's...
<notice> [driver] Dual Raspicam & TC358743 Video4Linux2 Driver v1.9.60 built Jan 6 2018
<notice> [driver] Selected format: 1280x720, encoding: mjpeg, JPEG Video Capture
pi@raspberrypi:~ $ dd if=/dev/video0 of=snapshot.jpeg bs=11M count=1
dd: failed to open '/dev/video0': Remote I/O error
