RickleusYBH
Compute Module 3 not detected for re-flashing
Tue Sep 26, 2017 6:54 am
I'd been doing "re-formating" for my Compute Module 3 (with eMMC), I'm using a Raspberry Pi 3 B to perform the format according to the Official website Documentation.
But the
sudo ./rpiboot
stops at Waiting for BCM2835/6/7 like forever
Any idea to perform a hardware reset?
Just a tiny lil potato in this gigantic syntax
r3d4
Re: Compute Module 3 not detected for re-flashing
Mon Oct 30, 2017 2:40 pm
:) i'm sorry i haven't a clue! ( or Compute Module 3 ;) )
fyi more rpiboot problems / solutions @ https://github.com/raspberrypi/usbboot/ ... 3Aissue%20 !
& historically
https://github.com/raspberrypi/tools/is ... %20usbboot
perhaps you might find some mention of `hardware reset` methods or more relevent info wrt Compute Module 3 @ usbboot/issues
Im curretly trying to use './rpiboot' with pi0 and piA and have seen abit of 'stops at Waiting for BCM2835/6/7 like forever'
after messing about abit with different cables , adapters
and
rpiboot -d [directory] : Boot the device using the boot files in 'directory'
+ firmware copyed from the fat pertitions of various images
at least in the case of pi0 and piA the firmware version used appears critical to success :!:
- > EG
raspberrypi/usbboot/issues/13#issuecomment-305230383 wrote:usbboot has been updated but you'll need to wait for a new version of start.elf
... are you using latest version of rpiboot?
Mon Oct 30, 2017 4:44 pm
But the
sudo ./rpiboot
If you are using the Official CM3 Development Base Board did you set the Jumper in the correct position ???
RPi 4B 4GB (SSD Boot)..
John Westlake
Thu Nov 09, 2017 4:59 am
Can you see the CM3 in device manger (on a windows PC)?
I seem to have manage to brick a CM3 by interrupting the download at about 10% - this is REALLY worrying as a we must offer OTA updates to our customers in the future!
When you say you reformatted the CM3 I wonder if you have effected something in the memory that needs to be there... but from what I understand this should not happen???
Return to “Compute Module”
